Question about Frigidaire ATF6000ES Front Load Washer
How do I fix code LOC? My washer keeps putting a code LOC across the screen and it will not go off, and I can't get it to go through a cycle. I have misplaced my booklet and I don't know what LOC means. Can you help? Thanks.
  • 8 Answers
Press options and select at the same time and hold for 10 seconds.
Posted on May 05, 2010
  • Lori A Neely
    Lori A Neely Jun 25, 2014
    Wow here I was going through the manual and NOTHING on fixing this. THANK YOU!!! :)
What does a LOC code mean?
loc has to do with control lock:
control lock (press and hold)
to lock the controls between or during cycles, press and hold the add steam button for 5 seconds. loc will be displayed if you attempt to wake up a "between cycle" locked unite and loc will alternate with cycle time remaining in a "during cycle" locked unit. repeat to unlock the controls when you are ready to operate the washer. use this feature to reduce the likelihood of accidental operation by children.
Sep 03, 2015 | Kenmore Dryers
LOC showing on screen
Hello Annie, thank you for allowing me to assist you!
I see you are still receiving error code "LOC" even after replacing the door lock assembly. Let's try unplugging your washer once again to determine if it is a false error code. It is important to wait roughly ten minutes and then turn your washer on. Before selecting a cycle, press OPTIONS and SELECT at the same time for 20 seconds until "LOC" is no longer displayed. If the error code does not clear, then your washer more than likely may be experiencing an issue with the control board or wiring harness. I hope this information helps to some degree.
Feb 18, 2014 | Electrolux EW1000i Front Load Washer
Error message LOC
Do the following:
The Control Lock (child lock) is on: To prevent accidental operation of the washer or alteration of the cycle settings, press and hold the lock symbol until you hear 3 beeps and LOC is displayed. To cancel, press and hold the lock symbol until LOC is no longer displayed. To put the control into control lock you do the same thing.
God bless you
Sep 26, 2012 | Frigidaire ATF6000ES Front Load Washer
Cycle starts but shuts off. timer keeps running. when we press option select we get LOC. when we hold start/cancel button we get 5 beeps and ESE
Hello
LOC error code is displayed when the control panel is locked, to unlock it press the OPTION & SELECT button and hold them for 20 seconds. This should reset the control, if it does not then replacing the control is recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 14, 2010 | Frigidaire GLTF2940ES Front Load Washer
My washer won't start, it keeps flashing ERR and then the wash-time, and then LOC. My roommate says to fix it before, he held down three buttons, but can't remember which ones. Any idea?
Try the following two buttons: press Options and Select together for 10 seconds (or until the LOC disappears). The pair of buttons held for 10 seconds also sets this control lock.
To find out the error code, turn the Program knob to the start position, Spin Only. Press Start/Pause to start the cycle. Press Cancel to stop the cycle and turn off the LEDs. Press Cancel again and within 5 seconds press and hold the Options and Start/Pause buttons until the LEDs start chasing. Then release the buttons. Turn the Program knob seven clicks clockwise from the Start position. The control will signal the last error code. To clear the error, press and hold Options and Start/Pause for 3 seconds. Then either unplug the washer for 5-8 seconds before plugging it back in. Alternatively, press and hold Options and Start/Pause together for a few seconds until the Wash LEDs appear.
http://www.applianceblog.com/mainforums/frigidaire-electrolux/12950-frigidaire-atf6000es1-wont-drain.html has a link to the service manual for the listed washer (the link is half-way down the page).
I hope this helps.
Oct 12, 2010 | Frigidaire ATF6000ES Front Load Washer
"loc code"
Found the operating manual on the internet. We thought it was the child lock button but we couldn't release it. We found out that you have to hold both the "select" and the"option" button for 10 seconds to release the loc.
Hopes this helps someone else.
Sep 14, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire washer will not start. Get err and LOC codes.
All the lights are on, but the door lock. We have unplugged it, doesn't help. Our washer is the front load, model LTF 2140ES0.
May 18, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
LOC message
This sounds like a faulty micro switch on the door catch. Try pressing inwards on the door glass at the catch area whilst you press start and hold it oressed for a few seconds until it either starts or displays the error again, if the error shows it may require a new switch, the switch can be tested by bypassing it and joining the two wires together that plug onto the switch. The switch can be accesses by removing the dor seal from the outer most edge.
Jan 26, 2008 | Washing Machines
Kenmore Ecocycle Front Loading Washers ERR ??? LOC???
Try to fix it by unplugging the unit for few hours and then plug it back in. Good luck !
Jun 20, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Frigidaire ATF6000ES Front Load Washer Logo
1,779 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
