Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave ge spacesaver touchpad does not work except for the
Microwave touchpad does not work except for the clock setting control
  • GE Master
  • 9,098 Answers
You have a failed membrane keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
But please note that for some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
Either way, we can let you know what your options and costs would be and send you other helpful info.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Posted on May 04, 2010
Testimonial: "Thank you for your detailed response. Nice to know you are there for support."
    Problem Solver:
  • 5 Answers
I just had the same problem with my keypad (GE Spacesaver Model JVM2070CH02). I sent it to Matt Fadorsen at eM-Ka Ventures in Chesterland, Ohio and he fixed it as good as new for only $100. GE wanted $80 just to come take a look, and a local parts distributor priced the entire control panel (GE does not make available just the membrane) for $548. Needless to say, I'm tickled to death to have my microwave working again for a fraction of the cost a GE serviceman would have charged. Matt's the man to see.
Posted on Jul 26, 2013
Control panel on GE Profile Spacemaker microwave not working
You are right the control panel is very expensive, you can try the filter to see if you can get it working, but I must admit a new microwave oven sounds appealing.
Jun 25, 2012 | GE SpaceMaker Microwave Ovens
Start botton on touchpad not working
Try unplugging unit for 5 minutes then plug in and clear cancel. Re-set clock and tryto program. If this does not work, call service tech. A quilified tech will open up & test touch panel and control board.
Mar 27, 2012 | GE JES1142SJ Microwave Oven
Model # JVM150001 GE Spacesaver Microwave stopped working. Clock & keypad are still working
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Keypad number buttons not working on ge spacesaver microwave - auto program buttoms work?
Very angry. Fairly new, little-used Spacesaver Microwave [3][Clock][Surface Light] buttons now do not work. We never even press [3], just [1] and [2] to warm sandwiches.
Unplugged for an hour. Still not working. Everything else works. We never use anything else. Bad solder joint in circuit board or keypad?
Thank you.
Aug 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacesaver xl1800 microwave. Unit comes on, but no heating
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
agf
Jun 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
No heating, turntable does not turn, but clock & lights work.
Check to make sure the plastic on the shelve holders or tuntable guide did not wear and expose metal. If these holders or brackets are wore and exposed metal it shorted out your micro wave. They need to be replaced and a fuse needs to be replaced inside the control panel,
Sep 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Reset clock, ge spacemaker xl1800 times out after 2-3 seconds
There's a simple fix for this. Unplug the unit. Take off the top grill with 2 screws. Remove the 1 screw that holds the touch pad unit. Lift up on touchpad unit and lift out. Put a piece of aluminum foil inside a large zip lock bag and tape it to the back of the touchpad unit and reassemble. GE put the magnetron to close to the control board causing stray microwaves to interfere with the board. The foil shields it.
May 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver Microwave Oven JVM1640BB
unplug the unit and if you can open the housing and slowly remove the ribbon cable of the touchpad console to the main board. put it back after 5 minutes and try it. let me know what happen.
Feb 20, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave JVM3660SD001 Control Panel Removal Procedure
Remove the grill, should be screws on the top of the unit. There should be one screw behind the grill at the top of the control panel. Remove it and pop the control panel up to remove it. Make sure the mw is unplugged first. Then you can remove the board.
Oct 02, 2007 | GE JVM3660 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
905 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
