XEROX TELECOPIER 7024
Message display keeps saying clear paper jam.  There is no paper jam.  You can fax, but you can't copy or get fax confirmations HELP!
    President:
  • 2,072 Answers
Does it say clear jam immediatly or does it start to run then declare a jam?
If it starts then tells you to clear a jam and no paper is in the machine, your feed rollers are shot. Smooth like trying to drive a car on ice.
If it says that all the time, no attempt to feed then you have a sensor either dirty, knocked out of place or something stuck on a sensor.
Either in the paper path or in the scanner.
Posted on Mar 26, 2008
  • Rick Kasper Mar 27, 2008
    Did you find anything??
    Can I offer you more help?
Xerox workcentre 5765 paper jam message but no paper is jammed
Check all the paper detecting sensors once more, may be there is something over the sensor.clean all the sensors with VIDEO 90. if after that problem persist please restart the machine and go for software and firmware upgrades.
GOD BLESS YOU
Oct 20, 2012 | Xerox WorkCentre 5765 5775 5790 Fuser...
Clear paper jam
may be there is small pice of paper inside just remove that.
Jan 20, 2010 | Canon FAX JX200 - Fax / copier - ink-jet...
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Need help on lexmark x 4270
To whiom it may concern my printer wont allow me to fax or copy do to it saying paper jam,so I cleared the jam and made sure that nothing is in it but it keep saying paper jam and will not allow me to fax or copy. Can you kindly help me with this problem please.
Oct 28, 2008 | Lexmark X4270 All-In-One InkJet Printer
Xerox Phaser 3200mfp Memory Issue
Do you have the receipt for the machine? You have a 1 year warranty from Xerox on that machine, Here is the copy and paste from the warranty information on the Xerox website.
Xerox warrants that the Phaser 3200MFP product and its Consumables, Routine Maintenance Items, and Options/Upgrades (related items) will be free from defects in materials and workmanship for the periods set out below:
Product: a period of one (1) year from the date of shipment.
Aug 21, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Promblem with xerox printer
This is solved with if you do a clear all Memory procedure under the Maintenaince settings
Aug 13, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
Replace Drum
your toner has nothing to do with sending/receiving faxes. If you can print to the xerox...something is wrong with the software..
delete and re-install software..Xerox website is useless
check the black sensor that dangles into the paper tray. wiggle it up and down, ahten resintalled the tray
Faxing
Hi:
You may have removed the paper but the reason why it is still saying paper jam can be caused by at least two things.
If you removed the paper, but it tore while you were taking it out then a small piece could be blocking a sensor or a sensor flag ( a spring loaded finger that the paper has to activate as it moves through the machine) It's possible that a small piece of paper could be blocking a sensor or you may have disloged one of these 'flags' in the area where you first removed the paper. Go back and look closely in that area for a piece of paper or a sticking ''flag'. Until you do that the fax keeps thinking that there is something in the paper path and will keep displaying that message.
Andrew
Jul 20, 2008 | Brother FAX-575 Plain Paper Thermal
349 people viewed this question
jasbo
jasbo
