Question about Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag
Black and Decker MM275 mower just stopped running
Hi, my B&D MM275 9 volt electric mower just stopped running in mid mow last week. It was as if I had unplugged it. I didn't hit anything before it stopped. The extension cord works. It didn't make any funny noise. It just stopped.
Does anyone have any ideas what might be the problem?
5 Suggested Answers
  • 313 Answers
SOURCE: I was mowing with my
possible broken armature & magnetic ring.mower need max repair.
Posted on May 29, 2008
  • 183 Answers
SOURCE: We have a Black and
You can get another end for it at any hardware store...Good Luck!!!
Posted on Aug 06, 2008
SOURCE: Black & Decker Lawn Hog 19" Mulcing Mower MM875 won't start
The rectifier is a flat plate with 4 posts that attach the electric wiring inside. You will need a flathead screwdriver to remove the four screws holding down the cover on your mower. on top where all the wires run (you will probably see one burned) There is a screw in the middle holding down the plate, you will need to replace the plate and resplice the wires that may be burned.
Posted on Jun 28, 2009
  • 23 Answers
SOURCE: have a black and decker 19in electric mower. was
The "wedge" of the plastic lever wears, so you need to replace the lever or build up that section of the lever. Some cyanoacrylate (Super Glue / Krazy Glue) and a piece of a zip tie will work.
Posted on Sep 27, 2009
What wires go where it's a black and Decker electric mower 18 inch mulching mower mm275
Obtain the wiring diagram for your model and connect the wires one at a time by the length and color.
Apr 03, 2016 | Electric Garden
My electric lawn mower power keeps cutting out IT RUNS WHEN PLUGGED IN BUT VERY SLOW,TIPPED OVER RUNS FAST.bLACK AND DECKER CORDED 19 INCH REARBAG
if it runs slow when mowing then when its tipped upside down there is no pressure on the blades its faster the bearing is gone worn out
Sep 25, 2008 | Black & Decker 19" Electric Lawnhog...
Why does my MM275 mower stall or not start?
The power switch is not operating properly and needs to be replaced or adjusted if possible.
May 11, 2015 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Black decker 36v won't start
Sounds like its burnt out. Or shorting out.
Jul 04, 2012 | Black & Decker 19" Electric Lawnhog...
Black & Decker cordless lawn mower won't start
Hi Sandi-
This could be an issue with the battery itself or charger. The best way to know is to have the battery tested. You can follow the link to locate your nearest service center to have them tested.
Thanks
Black + Decker Customer Care Find Service Center
Jan 15, 2012 | Black & Decker Black Decker Cordless 24...
My lawn mower just stopped working. I was mowing along and it just stopped. It is an electric Black and decker. I was mowing regular grass, nothing complex. It was working fine before that. It is very new...
Open your circuit breaker box. Locate the breaker that has tripped. Turn the breaker OFF (it is in a mid position). Then turn it back ON. Before you do that you need to ask yourself, why did the circuit breaker trip? They trip because of an overload of current. Is something else running on that same circuit, say for example an electric heater or something similar? Depending on the rating of that circuit breaker (15 or 20 amps) you may be drawing too much current. Look for anything else that could be running on the same circuit (only so many outlets can be put on the same circuit). Disconnect or turn off all other devices. Attempt to operate your mower again. If the breaker trips again, then there is something wrong with your mower (electrical short?).
Nov 29, 2017 | Electric Lawn Mower
Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
Mar 28, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Lawnmower won't start up
I have the EXACT same problem with my mower. I called the Black & Decker number listed above, and learned that the mower is under recall for this problem. So call them and find out where the nearest dealer is, and they will fix it for free.
May 27, 2009 | Black & Decker 19" Electric Lawnhog...
Rechargeable lawn mower lacks power even with replacement battery. Six or seven year old rechargeable Black and Decker 24 volt mower. Replaced the battery last year after it became unable to mow my...
just to let u know CMM1000 mower are on recall for pcboard.
if ur mower is type 1 to 4 then its the subject for recall for convertion to CMM1200.see ur nearest service center right away.
Aug 09, 2008 | Black & Decker 19" Electric Lawnhog...
B & D mulcher mower stop while mowing
electric & battery operation mower are not suppose to be use when grass are too long & wet, it draws lot of power that appear to runs slow.when you see try to restart i think the brake is trying to kick in.
Jun 15, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker 19" Electric Lawnhog Mulching Mower with Rear Bag Logo
254 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
