Agitator is loose and won't pull the clothes down
    President:
  • 1,937 Answers
DOESN'T
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only
one way.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the Sears site for Agitator, basket and tub.
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of
the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator
should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
See the following illustrated steps to replace the "dogs"
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136
Posted on May 04, 2010
What will cause this washer to tare up cloths
If you are getting ripped or torn clothes then most likely they are getting bunched up underneath the center piece that turns. These usually go back and forth and not all the way around in order to keep from bunching and tangling. It may be getting caught up on a lose bolt or something inside and under the center piece. If you can't figure it out just get a new one and part that one out or sell it at a garage sale. The electrical board and dials alone are worth a hundred bucks to the right buyer.
Mar 23, 2015 | Whirlpool WTW6400SW Cabrio Washer
How to remove clothes stuck under agitator
the agitator should pull straight up, you may have to twist it back and forth as you pull upward. when you put it back on make sure its all the way down and in place, this may be the reason your clothes are getting stuck under it.
Aug 23, 2014 | GE WBSR3140DW Top Load Washer
Clothing stuck under agitator, how can I get it out? Won't release from pulling or unwinding.
Most agitators will just pull straight up. If not, remove the top cap and remove the bolt inside.
May 07, 2011 | Kenmore Washing Machines
Agitator loose does not swish clothes around .... can't figure out how to remove the agitator in order to see what may have come loosened or if splines are stripped .... how do you remove the agitator ?
Hello, on the style GE washer there is an agitator coupling under the agitator that will sometimes strip out. To repair this remove the agitator by pulling it straight up and out.
TIP: If you can't get your fingers under the agitator, you can slip a belt under the agitator and then pull by that, once the agitator is off you should see a yellow coupling held on by a 7/16 bolt, remove that bolt and pull the coupling up and off the transmission shaft. Sometimes it will be hard to remove and you might need to knock it up with a hammer. Once it is off you should be able to slide the new one back on, bolt it down and push the agitator back on.
Thanks
Jun 14, 2010 | GE WBSR3140DW Top Load Washer
Cloth stuck under agitator in washing machine.
there is a bolt under the fabric softner dispenser (if you have one) if not, its a plastic cap on the top of your agitator which pops off by hand or a butter knife.. then there is a bolt under there that holds the unit down..grap the bottom of your agitator and loosen the bolt and remove it...then lift up carefully on the whole thing..careful not to loose the seal and bolt to put the agitator back in place....good luck..
Apr 15, 2009 | Amana ALW480DA Top Load Washer
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
Kenmore Series 90 Washer Triple Action Agitator
THERE IS EITHER A 3/8 BOLT OR 1/2 ADAPTER TO REMOVE AGITATOR
Nov 22, 2008 | Washing Machines
Agitator not spining properly to pull clothes down into water
remove agitator cap remove boplastic cover underneath remove bolt remove upper portion of agitator replace agitator dogs part # 80040
Jun 06, 2008 | Roper RAB2121KW Top Load Washer
Agitator not washing clothes
check and make sure the agitator hasnt come loose or broken pull up on it and see if it comes out if not the bolt is in it, then grab ity and twist it do you feel any drag on it if not look under the machine and see if the pully has slipped down or if something looks loose. you should norice any problem
Sep 24, 2007 | GE Profile Prodigy WPSE4200A
Washing Machines Logo
80 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
