Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Cycles improperly My dishwasher does not cycle properly. It races through the cycles, even when set to pots & pans, in about ten minutes. At first I thought it not filling properly, checked the fill switch, it's fine and water does come in. Then when it's finished it does not always drain completely. I have checked everything on the drain end as well. It seems to have a mind of it's own. I replaced the $145 computer control with no luck. It actually sped up from the original 16 minute full cycle to the now ten minute full cycle (start to finish). My next guess is the sensor that somehow monitors how clean the dishes are??? or the clock? which I thought was part of the computer control. I accidentally ordered the LED readout, which I guess is also the clock. I sent it back without trying it first, thinking the computer was the problem. The pump has plenty of power and drains with good velocity, but the wash cycle, although brief, does not seem to spin the arms. Any clues would be appreciated.
    Sergeant:
  • 409 Answers
please let me know the make and full model # off your d/w.
thanks
Posted on Sep 13, 2008
Wash cycle won't start
I'm so sorry to hear about your issue. I know it can be frustrating. I did a little search on Google and it may be a shorted circuit board from steam/heat getting behind the panel. Here's the link I found on "Just Answer" have Kenmore 1374 Dishwasher that is driving me crazy
Nov 21, 2017 | Kenmore Dishwashers
Long cycles
Hello Shawn, thank you for your question!
If your dishwasher is taking too long to complete a cycle, first you need to make sure the water is 120F at the sink. If water is less than 120F it causes a delay in the performance and advancement of the timer until proper water temperature is reached. Run the sink to its hottest point, start a "pots and pans wash cycle". If that cycle runs over 4 hours, then I recommend reaching out to a service technician since more than likely the issue lies with the control board. If it runs under 4 hours it is possibly fine, it is only heat delays causing it to run so long.
Hope this helps!
Dec 25, 2013 | Frigidaire 24 in. FDB1050RE Built-in...
Model 664.15732000. The Normal Wash light on control panel will not light up however the Pots and Pans light will. I ran the cancel/drain cycle and re-tried. See my video. Could if be the fuse in the
Hi there, can you put it through the pots and pans wash cycle , see if it works with that first ?
also the drainage pipe might be blocked making the normal cycles unusable.
you might need to get in a plumber or somebody that can unblock a pipe.
Hope this helps .
Dec 29, 2012 | Dishwashers
Cycles
normal cycle is the best load for normal loads you should be able to go to frigigdaire.com and print a manual
Jun 02, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
WHY DON'T DISHES DRY? MODEL ADW1100N10WW
water tempt too low . use longer cycles like pot & pans . if d/w has a heater turn it on . always run tap at sink till water is hot then start dw . this is a common problem it's probably not the dishwasher . but how ou are setting the cycles .. mm hope this helps . feed back pls ..
Dec 22, 2009 | Dishwashers
My whirpool quiet wash plus will not completey drain
lets see here you want at least ten bucks to just help me w/ my diswasher problem but if gee i figured it out all by myself i get squat thanks but no thanks.
Aug 28, 2009 | Dishwashers
Soap not Disolving
possibly the water is not hot enough, it needs to be hooked up to a hot water line ONLY. also check to see what cycle the dishwasher is set at, there are three or four different settings. start off by using the pots and pans cycle because that cycle will delay the wash to superheat the water.
remember hot water only and water should be set at 120 degrees.
good luck to ya
Dec 29, 2008 | Frigidaire 24 in. PLD3465REC Stainless...
How long is wash cycel in dishwasher. dishwasher does not seem to advance beyond the wash cycle
Normal wash cycle is as follows..
Wash1 8 min
Rinse1 10 min
Wash2 21 min
Rinse 10 min
Rinse 12.5 min
Dry(hot or cool) 23.5 min
Total of 85 min
thats just a normal cycle. Pots and pan cycle is of course longer
Nov 13, 2008 | Frigidaire 24 in. FDB1050RE Built-in...
Wash Cycle
Pot and pans takes like an hour to wash other than that it is probably a malfunction in front panel board or curcuit board in side door.
Sep 24, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Not enough water in tub
Mderford, on a normal fill, the water should be just above the filter screen. 1.8 gallons first fill, 1.7 on all other fills. Don't think it would be a siphoning problem as you are not having this on the pots/pans. Check the float, make sure it is not sticking. You can check the inlet valve filter screen to see if it is not plugged. Run it through the diagnostics cycle by pushing high temp-air dry-high temp-air dry. Some models it's heated dry-normal-heated dry-normal. It will run through a self test for about 20 minutes. See if any error codes come up. Fill time should be approx. 1:30 to 1:40 seconds. If any of the aformentioned doesn't turn up any results, then it's possibly a faulty fill valve drive circuit on the control itself...Catriver..post back.
Oct 02, 2006 | Whirlpool 24 in. DU900PCD Built-in...
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
77 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
