Question about Kenmore 63792 Microwave Oven
Reduce heat How do you cook at 60% on kenmore microwave?
  • Kenmore Master
  • 9,085 Answers
Normally it's one of these two sequences to cook at 1 minute at 60% power:
Time Cook, 1, 0, 0, Power Level, 6, Start
or
You can download many Kenmore owner's manuals free.
Enter your full model number at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
On the resulting page, look to the right for the blue "View manuals" button. Click there.
That Sears-related site has many free manuals. While the manuals they list there are all free, they will ask you to register.
Many times, the owner's manual will also have the installation instructions inside.
If yours is not listed there for free, you would have to order it through the
Sears parts site.
Posted on May 06, 2010
Kenmore microwave recall
Call Sears and complain. Visit the Consumer product Safety Commission website. Between the two you should get all the info you need.
Jul 16, 2014 | Kenmore Elite Microwave, Model...
The microwave comes on and seems to cook but does not cook . It makes a very loud humming noise and the turntable goes around but there is no heat to cook anything.
you either have a bad magnatron, that is trying to heat but won't or you could have a capacitor or diode (rectifier) that is bad. if you order a magnatron replace capacitor and diode (rectifier)
Feb 24, 2011 | Kenmore Microwave Ovens
Small amount of white smoke coming out of kenmore convection microwave in oven mode
That is usually caused by a build up of fat from microwave cooking on the heating element. It will clear under normal conditions and return if one cooks foods like bacon etc, un covered to prevent splashing of the food that is being cooked.
Hope that helps.
Oct 31, 2010 | Kenmore 63793 Convection / Microwave Oven
Kenmore microwave model 721.80033700 won't heat
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
Jul 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Kenmore Elite Mod 721.63683300. At first I would occasionally get an F9 error once every 5 or 6 times I would use it. Now, I no longer get an F9 error, but power is reduced to about 50% as...
No, the magnetron gets its power from the inverter assembly. The actual issue here is a defective or damaged inverter. Replacing the inverter assembly will correct this issue.
Sep 29, 2009 | Kenmore 62622 Microwave Oven
Kenmore Microwave Oven Sudden Power Reduction
I would be sure to check the microwave's outlet under a load.
One good way is to use a toaster or hair dryer for about a minute to see if they run at full power and run without their heating elements dimming.
If the power at the outlet is steady, I would suggest a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails to heat properly, I would say you have a failing magnetron, and it would just be a coincidence that the failure began after the new wiring was installed.
If you need to order the magnetron, Sears sells it for $73.13, but you can get it for $41.84 here.
Feb 14, 2009 | Kenmore 62622 Microwave Oven
Kenmore microwave stopped heating
simply stated.. if it fails to cook.. you may have either a bad magnetron tube ( that's the part that generates the microwave energy that cooks the food) or the filament transformer feeding that magnetron is bad. In either case.. you're probably better off replacing the entire appliance than repairing it.. Hope that helps...
Aug 30, 2008 | Kenmore Microwave Ovens
Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Nov 23, 2007 | Kenmore 62622 Microwave Oven
Microwave makes loud buzzing sound when on and no heat
Have you tried putting a cup of water in it and cooking on a low power level? If it buzzes only when it is on the cook cycle, that would narrow it down. More detals might help us help you, including the model number.
Mar 20, 2007 | Kenmore 62622 Microwave Oven
Kenmore 63792 Microwave Oven Logo
236 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
