Question about Remington Polesaw Wizard
ADJUSTING CLAMP IS BROKEN AND OIL FILLER CAP IS BROKEN AND SHOULD BE REPLACED AND I NEED PART NUMBERS THE TWO ITEMS PLEASE.
  • dontbother10
    dontbother10 May 11, 2010
    Remington(Power) is no longer in production. The pole assembly, coupling nut and thumb latch that replaced it are all NLA. If you want the oiler cap you have to buy 3 from Master Parts. Still interested? reply below if affirmative.
  • 193 Answers
You can order by calling 1-800-654-8534
Posted on May 10, 2010
Leaking oil from the top of the cap...
Oil cap leaking - Harley Davidson Forums
www.hdforums.com/forum/sportster.../550364-oil-cap-leaking.html
Aug 13, 2010 - There is always a big amout of oil at the bottom of the bike (probably all from oil cap) and it's drippin' all the time especially if bike is hot. 2007 sportster 883 leaking oil
May 31, 2009
Sportster Oil Leak
Oct 3, 2006
More results from www.hdforums.com
Oil leak at filler cap - Stromtrooper Forum : Suzuki V-Strom ...
www.stromtrooper.com/v-strom-service.../78495-oil-leak-filler-cap.html
Aug 24, 2012 - but more so it seems to me that a new bike shouldn't be leaking oil at all. ... Do I just need to have the dealer replace the seal on the filler cap?
Harley Davidson Motorcycles : About Slobbering Oil ...
? 2:20
https://www.youtube.com/watch?v=lB2DpvxKTGw
Dec 1, 2008 - Uploaded by expertvillage
Jan 20, 2016 | Motorcycles
Can I use 50/50 engine oil in my W reg Ford Focus
You should only use the oil recommended for your vehicle as shown in the manual - and sometimes printed on the oil filler cap of the engine. Thinner oils (lower numbers) are usually used in cold weather and thicker oils (higher numbers) in hot weather.
Oct 20, 2015 | Ford Cars & Trucks
How do i fix this my Ford focus 2000 broken top off oil filler cap, how do i get the rest out?
measure across the opening . then find a piece of steel about that size and Jam it down in the hole , use an adjustable wrench to see if it will unscrew the piece out .Or take it to a FORD dealer and have them replace it
Aug 16, 2015 | Ford Cars & Trucks
2003 Honda Civic LX code 1457 HELP
Error Code: P1457 Description - Evaporative Emissions Control System Leakage.
Causes:
- Fuel is filled with the engine start.
- Missing Fuel cap
- Wrong fuel filler cap is used
- Fuel filler cap seal is leaky.
- VSV Valve connector near air filter box is detached or wire broken.
- VSV Valve vacuum pipe near air filter box is detached.
Jun 01, 2015 | 2003 Honda Civic
Find dipstick on a 2004 jeep liberty
For What?
Those items are shown in your owners manual
You need one of those,find it or buy one
The Oil Stick has yellow loop on the end, of most
vehicles, so you know that is for oil
The other fluids not so much,those are all over the
place & different shapes & colors & fastened different
ways
Oct 04, 2014 | Cars & Trucks
Niian 350z exhaust gas from oil filler cap
check the pcv valve is operational
Feb 16, 2014 | Nissan Cars & Trucks
I have a 97 jeep grand Cherokee. I start it and it misses every so may secs. Almost like a chug in reverse and drive its worse taking off. Always fine when I'm giving it gas. Some times it runs fi
Have you replaced the pcv line correctly. Is the oil filler cap tight and sealing correctly. Check for broken cracked vacuum lines that you may have moved in removing the rocker cover.
Mar 10, 2013 | Cars & Trucks
Bmw 318i oil leak
make sure that the filler cap seal is in place and not gone hard over time also has the rocker cover been off at some stage if it has check that the gasket has not moved the other thing to look out for is that the PCV (breather )valve is in good working order if it is damaged the sump compression will rise and push oil out
Feb 08, 2013 | BMW X3 Series Cars & Trucks
The oil cap on my car will not open. is there a special way to twist the cap? all i get is a wratchet sound while turning it but it won't open.
hi.
most modern cars have a ratchet on the filler caps to prevent overtightening (oil and fuel)
it should only click when you turn it clockwise.
when you turn it anticlockwise, it should not click, but if it has not been removed in some time it could be very tight.
if it clicks both ways, then the ratchet is probably broken and the cap may have to be carefully broken off making sure not to drop any parts into the engine, and replaced
Jun 07, 2011 | Jeep Grand Cherokee Cars & Trucks
P0456 error code on a 2003 Mits. Galant
P0456 = "Evaporative emission (EVAP) control system leak detected (very small leak)."
Feb 25, 2011 | Mitsubishi Galant Cars & Trucks
Remington Polesaw Wizard Logo
49 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
