Question about Health & Beauty
Unit is a three wheel Triumph purchased used, that uses the box type remote charger that plugs into the right rear of the machine. Batteries are fully charged, key activates the red-to-green lights on the control panel but when the paddles are pressed, there is only a clicking noise in the mechanism alongside the single motor transmission drive axle. The clicking is followed by the mechanism trying to move...it is the same item, something like a solonoid switch, that has the "free wheeling" level attached. This a full adult model...I can't find any reset button underneath, only a two amp Buss fuse that was not blown. Unit is likely 20 years old, no papers came with, so no manuals and nothing much on line. I can get to the serial number if there is a chance parts are available. It seems to be nothing more than something jamming the drive or the activating switch...I've worked the reset pins that are attached to a strap across the lower back, that lock into the wheels...The torque makes the switch mech move, but it just can't break free.. We really like the scooter and would order manuals/parts if available. Any clue as to what the problem might be? I could take pictures and provide the serial number if there is any glimmer of hope for the old girl...the only active site seems to be in Canada. Thanks Bill Leahy wleahy@centurytel.net 636 488 1602
    President:
  • 1,469 Answers
Hi see if this can help out . check the link out. allelectricscooters.com/cache/1214503818000/resources/.../76.pdf. Take care.
Posted on May 04, 2010
  • Egwe Emmanuel Onyedikachi
    Or you can use the contact address to contact the customer service for help.
S600 schwinn electricscooter.I just purchased three new batteries.I hooked them all up then plugged charger in it reads charge ok.But soon as I un plug the charger and turn to poweron it doesnothing.
Use a voltmeter to verify your batteries are indeed fully charged. Double check all connections for solid contact and signs of corrosion. Keep all contact points shiny clean.
If the batteries are all good, we could be talking control circuit.
Mar 02, 2016 | Health & Beauty
My gogo elite traveller wont chrage. The charging light isnt on when i plug the scooter in.
Sounds your batteries are to low in voltage for the charger to recognize. Also check the fuse on the battery box, normally a red one 10amps.
Feb 13, 2015 | Pride Mobility Products GoGo Elite...
I am plugging my charger in and it is not charging the batteries
There are 2 charging and battery related fuses on this model that should be checked and if burnt open replaced with the same color and fuse type. One fuse is located under a rubber boot near the charging port. Use needle nose pliers or your finger nails to remove and inspect. The second fuse is hidden under the battery box. Pull up and out to remove the battery box and inspect the fuse in the base underneath. If both of the fuses are OK open the battery box and check all the connections. You will need a long phillips #1 screwdriver to do this. Hope this helps
Aug 05, 2012 | Pride Mobility Products GoGo Elite...
I bought an MPV5 used. Batteries won't charge. Charger light is green after 24 hours...slight power surge then dies. The seller said it hadn't been plugged in for a long time. I also noticed the batteries...
Lets solve this, one question at a time ....
First your batteries are not charging,This may be because of it siting for too long without a charge.The batteries may be so dead that your charger cannot reconize them. dont losse hope there are ways to check your batteries and charger with out spending alot of money on a tech coming over.
1) Unplug and remove your batteries from the chair
2) Find your self a charge that trickle charge
(Note: If you have a batterie charger ,trickle charge is the lowest set charge)
3) Trickle charge each batterie to about 50%
4) Install batteries back on to chair
5) Plug in chair charger
The chairs charger should come on ,and that right there tells you that you have a good charger!
The batteries that came with this chair are not bad and are considered ok to use .These type of batteries are what you call maintenance batteries ,which your always having to check if the leaking or need water.The gell type batteries are what they call non-maintenance.That you dont have to always look after but are more money.Thats why they recommend the gells so that the user doesn't have to work on there chair.
I hope that was helpful ,Happy Riding
Feb 10, 2011 | NRS Hoveround MPV 5 - Used Power...
My scooter battery won't charge. Felt mild shock or short when attempted to insert connector. That seemed to disable the charger because the charger powers on, but will not run the charge to the...
Make sure that the charger is fully connected to the scooter; ususally the controller lights will go slowly left to right to indicate it is charging. Make sure the charger is plugged directly into the grounded wall outlet, not into an extension cord or power bar. If the charger is not being recognized by the scooter, you may need to replace the charger, or at least the power cord to the charger.
If your scooter has been sitting unused for a while? If so, the batteries might not charge anymore and will need to be replaced. Contact the manufacturer for a service call or troubleshooting over the phone.
Nov 04, 2010 | Pride Mobility Products Go-Go Elite...
I own a 2002 Triumph Bonneville. I have just purchased a new chain and both front and rear sprockets. I had intended to change all three. However despite several attempts I could not release the drive...
97 foot pounds plus age make this a tough one to break loose. put it in first gear and have someone stand on the brake. a 1/2 inch air impact should help too.
Oct 23, 2010 | 2001 Triumph Triumph Bonneville
Charging sterling elite 2001 scooter batteries
If you use the scooter every day then plug the scooter in each night for 8-10 hours.
Jul 20, 2009 | Pride Mobility Products Go-Go Elite...
Wii charger not charging
problem is either one battery is discharged and the other is full or corrosion on battery terminal tops or batteries are defective. the red lights flash when the unit sences that the batteries have a problem with the induction charge. simple test is to using a meter measure the batteries or discharge the unit with a wire and a 2.2 volt bulb (flashlight bulb) once discharged, unplug the charger unit for over 10 secs to reset it. then plug it in and try the batteries in the packs again. if still inop then they are done for.
Aug 15, 2008 | Nintendo Wii Console
Car Power Unit
I'm not sure that there is a car charger available for the GPS 310. There is no external port where you could plug it in, the only thing you can do for power is take extra AA batteries with you.
Jul 02, 2008 | Magellan GPS 310 GPS Receiver
Health & Beauty Logo
43 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
