Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
FreeAgent Hard Drive will not stay on, Power source does not seem harmed or damaged,
  • 416 Answers
The might be an issue with the power adaptor inside the enclosure. suggest that you take it to a repair shop. if you are technically savvy, try swapping with another enclosure.
Posted on May 06, 2010
Hi, I have a seagate freeagent external disk with 500 Gb capacity, I had long time without to use my diks, then when I tried to use, It doesn't work, the power source is Ok, but my disk it It doesn't...
is the hdd getting detected....??? if it got detected then format it and try to use... if it is not detected then, let me know, i shall assist you further...
May 17, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent Go inaccessible! Suspect MBR corrupted!
This always depends upon how valuable the data is.
fixmbr in the recovery console will not harm the drive IF you can get into it by way of the USB interface. You might consider removing the hard drive and putting into a desktop , directly connected to the SATA IDE controller to eliminate the eSATA USB interface as the cause of the problem.
Run chkdsk /r as soon as you find a way to get access.
Use command line options that you know what they do, but I would tread lightly since more damage can be caused.
Get to know and understand recovery console commands
Mar 11, 2010 | Seagate FreeAgent Pro 500GB External USB...
Seagate Freeagent 1.5TB hard drive beeping
remove hard-drive and put it start in to your computer this sounds hard but isn`t. it sounds as the internal board has gone.
Dec 07, 2009 | Seagate Computers & Internet
Freeagent doesnt start
I think you have already diagnosed the problem sufficiently, the tolerance of the free Agent is less than +/- 1.5v so you have undoubtably fried the controller board in the freeagent case. The real question is wether the PCB board in the case was kind enough to blow out quickly and save the drive itself.
First step is to take it to the local computer shop and have the hdd swapped into a fresh case. If it works in the new case you're done, if not, you'll likely need the help of a pro to recover the data off the drive.
Give it a shot and report back, if it's not successful, let me know what country, state and city you're located in and I'll make a recommendation for a professional facility that can help you with the recovery.
Chris
Jun 07, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate FreeAgent Pro Desktop 250GB - no power
go get a external drive enclosure from computer supplier
compusa
best buy
circuitcity
Feb 04, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate hard drive will not power up
You have to be running NT, XP or Vista to access the drive. I take the power cable out, then plug it back in. Or try rebooting with the hard drive plugged in. Also purchase a USB Extension port so you can unplug the USB when not in use to stave off overheating. Go to Seagate and download Seatools. Also Download the source code for the drive while you are there.
Jan 27, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Freeagent desktop external hard drive will not power up
I have my own Seagate hard drive and with mine you have to plug it into the computer and power source for it to power on.
Jan 10, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate freeagent pro 500GB power on/off unsure
I believe it's normal as the Freeagent is responding to data on the input (eSata) cable. If you don't like the light always ON, hook it up first via USB to a Windows PC and set the light to "off" and the drive to spin down "never". If the drive loses power, you will have to do the procedure again. Otherwise, the light stays mostly constantly ON and make a nice companion to Tivo lights. ZT3000 "Beta tester of "0"s and "1's"
Aug 18, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
118 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
