I have actually opened my ipod 30 G.B photo and cut the wire that connects the ipod with the back cover with have the lock/unlock button & the earphone jack , what can i do to manage this problem !!!
Ur ipod is done
Posted on May 04, 2010
How to fix the backlight
hi
Things You'll NeedSmall flat-head screwdriverPhillips-head screwdriverReplacement screen
Tips & Warnings
This will void your warranty, so if your iPod is still under warranty, you might as well allow Apple to fix it.
Read more: How to Replace The iPod Display ' eHow.com http://www.ehow.com/how_5763780_replace-ipod-display.html#ixzz1gn0Sfes3
Replacing your iPod's screen is actually a lot easier than you would expect. The kind folks at Apple have made access to the inside of the iPod very easy, making for quick upgrades and fixes. While you have the iPod open, you can also upgrade the internal hard drive to a much larger capacity to hold more movies, music and photos. Replacement screens for the iPod are very easy to come by these days, so get a hold of one of those from an online retailer and replace it yourself, instead of getting charged by Apple to do something you can easily do at home.
Instruction
1 Replacing your iPod's screen is actually a lot easier than you would expect. The kind folks at Apple have made access to the inside of the iPod very easy, making for quick upgrades and fixes. While you have the iPod open, you can also upgrade the internal hard drive to a much larger capacity to hold more movies, music and photos. Replacement screens for the iPod are very easy to come by these days, so get a hold of one of those from an online retailer and replace it yourself, instead of getting charged by Apple to do something you can easily do at home.
2 Use your flat screwdriver and gently insert it into the small crack between the iPod case and the iPod backing. Once you have the tool slightly inside the crack, slide it around the entire iPod to pry the pieces apart. Be very careful not to pull them apart, as there are three ribbon connectors that need to be disconnected first.
3 Lift up the ribbon connector that connects to the hard drive, which is large and blue, and disconnect the hard drive. Release the ribbon that connects to the battery, the smaller blue object, and disconnect it. Release the final ribbon by lifting up its tab. Unhook the final ribbon to disconnect it.
4 Use your Phillips screwdriver to remove the six screws around the iPod front cover. Remove the frame of the iPod front cover. Unhook the screen's ribbon and pull out the iPod screen. Insert your new iPod screen and work backward to put everything back together. Don't forget to connect all of the ribbons
5 Turn on your iPod to test your new iPod screen.
Nov 25, 2011 | Apple iPod nano
Ipad backlight repair
hi
Tips & Warnings
Instruction
Need wiring color codes, cord pulled out.
form top to bottom, for the wires on the power connection side (right) Aqua (A), Brown (S), orange (LR), yellow (LG), black (G), red (L). The letters in parenthesis indicate the letter by the connection on the circuit board.
Oct 06, 2010 | Griffin Technology iTrip Auto with...
My wire tht plugs into the iPod fell out the rest
If you still have the connector take it to a tv repair shop actually they have to solder it it may look kind of odd after they do because they have to cut it open or ask if they can find a replacement for the connector (that would be hard) that is if it broke on the jack side but if it was closer to the headset that should be easier but the process is the same they have to open it and solder it.
if they know you they may charge you about 20 bucks if not you may have to get a new headset
:-( sorry
if it works for you don't forget to rate me
thx
May 21, 2010 | Skull Candy Icon Headset
I need a new 20gb hard drive
u need a new 20gb...is ur ipod full with song? not working correctly? my suggestion is this (if you are willing) plug the ipod to pc....itunes will pop up...(make sure all video,photos and music is saved in itunes by syncing it).now x out of itunes...go to my computer open the ipod drive and copy software and hidden software to your pc (do not rename any part of this)....software is copied, format the ipod drive (yes you wish to erase it)...format is complete...now copy the software back on to ipod from pc.......go to start or click on itunes icon to open itunes....if ipod not found in 30-45 seconds disconnect the ipod for 10 sec and plug it back to pc..add your photos/video/music back to ipod...its working like brand new
now here is the site for replacement harddrives http://www.mymacstore.com/advanced_search_result.php?keywords=20+gb&x=8&y=13
just trying to save u $ and time
hope this is helpful feel free to rate
Jun 16, 2009 | Apple 20gb Ipod Mp3 Player With Click...
After fixing new battery, my ipod is not working?
open ipod again....be real careful...check all wires make sure they are still connected and not squashed by the cover make sure battery is connected snugged..put cover back watch the wires
May 25, 2009 | Apple iPod nano
Reddy heater 35,000 torpedo heater
unit needs photo cell,or cell is dirty.to check photo cell disconnect the two blue wires from reset switch nad put a wire between where the blue wires were connected.that takes the photo cell out of system.fire unit up.if it stays running photo cell is bad,change it and all will be right again
Jan 27, 2009 | Reddy Heater-30-55,000 BTU Variable
Ipod will not play properly after connected to Vm9512
Well, the screen issue you are describing with the ipod sounds like the ipod's clickwheel is malfunctioning. A malfunctioning clickwheel will allow you to reset the ipod, but not actually make selections. At this point, you can either replace the clickwheel or if your ipod is under warranty, take it in for service.
*I am assuming that you are actually resetting the ipod correctly. For example, when reset, after bootup, the ipod will ask you to select a language. If you are not getting to that screen when you "reset" it, then you are likely doing it incorrectly. If that is the case, I'd suggest checking your HOLD button before suspecting a bad clickwheel. Since there are slightly different procedures for resetting ipods depending on model and generation, I'd suggest doing a search online (or going to Apple's website) for instructions on how to reset your particular model. Note that ipod generation can be easily found printed on the back case of the ipod.
Jan 06, 2009 | Audiovox VM9512 Car DVD Player
Need battery for the Nextar GPS model x3-02
Actually, it's quite easy to replace:
i. Take off four screws at the back.
ii. Between the body and the front bezel, insert a utility knife. The bezel is fixed to the body with tabs. I started from the left hand side from front. The tab is in the center. Careful not to scratch the bezel or the body. Once one tab is open, you can slide the knife or whatever tool you're using to open the rest. Be careful not to scratch.
iii. Once the front bezel comes off, you'll see that the touchscreen is held to the bezel with the help of four tabs. take the touchscreen off.
iv. Next, take the ribbon cable off from behind the screen. You'll have to flip the flap holding the cable open.
v. The screen is held to the main board with the help of a tape. Don't take it off. Take off three smaller screws which fasten the circuit board to the back body.
vi. Take the antenna off. It's quite easy. It's the same connector that is used for Blue-tooth or wireless antenna on laptops. It'll just flip off.
vii. Next, take the board off from the back plastic body. The circuit board will still be held to the back by two connectors, one (two wire, smaller one) connecting the circuit board to the speaker, and another (larger one, four wires) connecting it to the battery. Both the battery and the speaker are for now fixed to the back plastic body.
viii. Once you've done that, the battery is exposed. Take the battery off (held by two tapes, and some double sided sticky tape to the back body).
The battery is 35mmx55mmx5mm. Buy any 3.7v battery from ebay. That'll cost you about $10, including shipping. The only problem is that on ebay, you might not be able to buy the same connector. Most of the batteries that you get from there also have protection circuitry to protect against overcharging etc. So you'll only have to replace the connectory. For this, take apart the battery from top. Just peel off the green tape. That will expost the connections. Solder them off, and replace the entire chord on the new battery.
Sorry, I'm too depressed right now on account of loosing my job :-) Otherwise, I'd have included pics too. But I guess if you're not afraid to do DIY projects, you should be able to change the battery yourself. Quite easy.
-pkrobot
Nov 20, 2008 | Nextar X3-02 GPS Receiver
Can I view photos on my iPod photo/"Color"? nano?
Depending on the model, to view photos on your iPod photo/"Color", you either need to import photographs using Apple's iPod Camera Connector, or transfer images from your computer through iTunes 4.7 or higher to the iPod. For the current iPod U2 Special Edition "Color", iPod "Color" (20.0 GB), the version of the iPod photo (60 GB) introduced on February 23, 2005 and renamed iPod "Color" (60 GB) on June 28, 2005, as well as the discontinued iPod photo (30 GB), the simplest way to transfer photos from many digital cameras to your iPod is to purchase and use Apple's iPod Camera Connector (US$29). This device simply allows you to directly connect a digital camera to the camera connector and in turn connect the camera connector to the iPod "dock" port. Photos imported using the iPod Camera Connector are immediately viewable, with the exception of RAW format images and video clips. However, photos imported using the iPod Camera Connector cannot be immediately viewed as a slideshow with transitions. On versions of the iPod photo (40 GB, 60 GB) released prior to February 23, 2005, photos transferred directly from a digital camera using an iPod-compatible media reader are not immediately viewable, but photos transferred through iTunes 4.7 or higher, which converts photos into a "thumbnail" format, can be viewed on the iPod photo itself or displayed using the iPod photo connected to a TV or projector. The iPod nano, introduced September 7, 2005, can display photographs on the internal display "loaded" from a computer, but as it lacks video out, it cannot display photographs on a television or projector. The iPod nano also does not support the iPod Camera Connector or third-party solutions, so photos cannot be transferred from a camera. For information regarding the iPod nano and accessory compatibility, please refer to Apple Support
Sep 29, 2005 | Apple iPod nano
139 people viewed this question
 Grubhead
Grubhead
