Question about JVC KD-S570 CD Player
Cd player broken
My JVC cd player that I currently have installed in my truck will suddenly for no reason make a loud screeching sound that you can not get to stop. I have tried to take the face plate of to clean it but it seems to be stuck on. When you press the button to take the face plate of it will release from one side but not from the other.
  • 113 Answers
Unplug the radio from its harness for about a minute then plug it back in try the radio again if you still get that squeal-it is possible that either one of your speakers is shorted or your wiring has a problem- cleaning will not help this problem!
Posted on Mar 27, 2008
I have sound, but the microphones are not working
Read the manual is the easiest way to get it to work- check Mic volume and make sure the mic you are using is wired correctly. If it is a condenser mic, the JVC does not provide power to it so that could be one reason.
Dec 14, 2012 | JVC XL-SV22 CD Player
AWRC1G Bose radio/CD I have....when I turn on there is nothing but a tremendous screeching sound and thats all I hear.
I know this is an old post, but more likely than not you have a liquid damaged unit. This is very common and symptoms such as that which you describe are the result. We service hundreds of these units with great success. CET Services, 117 Windsor Ave., Hurley, WI 54534 // don.miller60@outlook.comS2XL9M
Aug 23, 2012 | Bose Awrc1g Wave Radio Cd Player Only -...
New cd player installed but no sound!!!!!
First be sure thet all wires are properly connected and that the units output sound controls are adjusted (balance & fade etc.)
www.installdr.com has many valueable resources that may assist you.
Good luck
Feb 22, 2009 | JVC KD-G110 CD Player
Mine is a FDB635RFS4 model - issue is loud screeching noise
i recently had the same problem of a loud screeching noise. my unit was installed new in 1999 and has worked well up to this point.
when i disassembled the tub water filter i found the filter was heavily clogged (it is supposed to be self cleaning), and i also found glass shards from a broken wine glass. i further disassembled the plastic housing under the filter ( held in place by three torx drive screws ) which covers the pump impeller and holds the lower spray arm. while i did not find any blockage in the pump area, and no abnormal sound when i turned the impeller by hand, i did find that one of the pump impeller vanes has a small chip which probably makes the impeller unbalanced resulting in more than normal vibration. i cleaned the water filter and reassembled the parts and the original screeching noise is now gone.
Sep 03, 2008 | Frigidaire 24 in. FDB635RF Built-in...
I have a problem with the CD player turning on.
sounds like u got a bad unit if only certain things get power then it sounds like an internal problem
Jun 25, 2008 | JVC KD-G200 CD Player
HIGH PITCH SOUND
sounds like a ground issue, or a problem with the deck, id take it back to where u had it installed
Mar 13, 2008 | Kenwood KDC-135 CD Player
Help with installation for car audio jvc model no. kd s585
HOW TO HOOK UP A JVC CAR CD PLAYER TO A 1993 COUGAR
Jan 12, 2008 | JVC KD-S580 CD Player
Shuts off after a loud sound
Hmmm...not sure but sounds like the vibration from the loud sound is causing the disk to jump. Not sure why that would power it off, but I think your thought to junk it sounds reasonable.
Dec 24, 2007 | Onkyo DV-CP704 DVD Player
Installing
You should test all of the speaker wires by putting the negatieve wire (the ones with the stripes) to the negative end of a AA battery and the positive wire to the positive end. You will hear a light, high pitched noise if the speakers are working correctly.
Nov 30, 2007 | JVC KD-G210 CD Player
JVC KD-S570 CD Player Logo
69 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
