Question about Sony VPL-FX51 Multimedia Projector
My sony vpl-fx51 projector shows a blue glow on the side (left and under) of the screen. on the bottom some vet blue lines. the longer the projector is on, it wil get worse. only time its not visible is when the screen is blue or white. the projector tells me to replace the lamp, but i don't think thats the problem. I also discovered that there is something loose in the projector. because when i pick it up i hear something. I sure do not hope its the prism block. its also not the cable because i tried different cables. I can also send a photo.
SOURCE: Blue Haze on screen Sony cineza vpl-hs50 projector
I also have the same problem -- the fix is to replace the optical block ( Internal lamp engine ) which is a $1,100 part. I just purchased a used projector for half the price of the part.
Posted on Feb 17, 2009
SOURCE: Sony LCD Projector - burned prisms
I have the same projector, but my problem is with red.
A replacement prism assembly is about $2k.
If you can get your hands on another projector for cheap, that's your only hope. You can swap out the blue lcd panel from your prism with someone else... it's a bit of mucking around, but worth it of you can.
Posted on Feb 27, 2009
welcomejee
  • 10594 Answers
SOURCE: how to reset lamp on sony lcd projector xga vpl-px20
After replacing lamp, connect projector AC power cord and turn the projector in standby mode.
Press following keys on control panel for less then 5 seconds each..
RESET, <==, ==>, ENTER.
That will reset lamp timer in projector.
Thanks.
Posted on Jun 01, 2009
Its your blue polarizer going bad. This happens over time due to the excessive heat generated in the projector. The main problem is that your projector has organic LCD panels that degrade over time and in turn degrades your blue polarizer. The same thing happened to my sanyo Z2. It took 5 years for it to show on my Sanyo because I only use the projector for sports and movies. not daily tv watching. In any case, it isnt worth it to spend the money ti fix it...jut put tat towrds a new projector. The latest crop of LCD projectors almost all use in-organic LCD panels that last much longer. Hope this helps.
Posted on Oct 28, 2009
  • 59 Answers
SOURCE: How can i reset the lamp timer ???? Typ of beamer:
Connect with power cord and turn the projector to the standby mode.
Press the following keys on the control panel in the following order for less than in five seconds each: RESET, LEFT arrow key and RIGHT arrow key and then ENTER.(showing in the picture below)
(NOTE projector must be in standby mode and keys pressed less than five seconds)
now press power/standby key to ON the projector and check lamp hoursgood_help_1.png
Posted on Jan 31, 2011
My projector shows a blue tint to the right of the screen. I am afraid that it might be the blue LCD panel gone bad. What might the diagnosis be? Sony VPL-HS51
Does the blue tint show up as small rectangular pixel shapes when you get up close to the screen when focused properly. This would indicate a blue LCD panel fault. If it's fuzzy then possibly a blue polarizer overheating
May 14, 2011 | Sony VPL-HS51 Multimedia Projector
I have Sony Projector XGA VPL FX51 and the COVER LAMP LED is Blinking. Please Guide me to solve it?
check that the cover is secured properly and the little switch inside the init is activated by the plastic protusion on the inside of the cover, when installed correctly
Apr 06, 2011 | Sony VPL-FX51 Multimedia Projector
Image is bright but there is a slight issue - on the left hand side a purple line displays vertically. Anybody knows why is this fault appeared and how could it be solved.
There is three LCD in the projector red, green and blue. If green LCD make any fault mean line or dot or dots then screen show these line or dot in purple color:
If line is very straight and sharp edges then green LCD is faulty and need to be replaced.
If line is not straight and faded edges then some thing in LCD block so your projector need service
Feb 22, 2011 | Sony VPL PX40 Multimedia Projector
How can i reset the lamp timer ???? Typ of beamer: Sony VPL-FX51 E-Mail:francois.humbert-prince@vtg.admin.ch
Jan 31, 2011 | Sony VPL-FX51 Multimedia Projector
Holding left and right scroll while powering on and pressing menu did not reset lamp timer.
Set the projector in standby mode. Press the reset and enter buttons for about 5 seconds. That should reset the timer.---Rick
Sep 01, 2009 | Sony VPL-FX51 Multimedia Projector
Sony vpl cs5 projector - after lampchange
Having same problem without lamp change. Did you ever find a solution?
Your response would be GREATLY appreciated. :)
Mar 28, 2009 | Sony VPL CS5 Multimedia Projector
Nov 29, 2008 | Sony VPL-HS51A / VPL-HS60 Multimedia...
VPL-fx51 Sony projector "Please replace the lamp"
Hi there
It is quite easy to reset the lamp timer nd remove the prompt.
Start up the Projector and hold down the right and left scroll buttons on your remote and then press Menu.
This will reset the timer.
Mar 24, 2008 | Office Equipment & Supplies
Blue tinting appearing on the right side of screen on vpl-es1 projector
A warning in the manual was given as to be carefull when using this projector with games as some parts of the screen will not move, just like if you watch Tv on it and there is a channel logo in one corner that doesn't move! It burns the display like it would on a pc monitor if no screen saver set. This is not a problem you can fix, that is perminant damage to the lcd in the projector!! S Platt
May 13, 2007 | Sony VPL-ES1 Multimedia Projector
Sony VPL-FX51 Multimedia Projector Logo
156 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
