Question about Garden
I went to plug in my water fountain and it wouldn't work.It has a single pump that attaches to a tube.I put some water in the fountain and it started to work,then stopped.Can you help?
    Problem Solver:
  • 8 Answers
Pump has no or low water shutoff built in make sure pump is fully submerged at all times of operation or you will loose pump hope it's not to late.
Posted on May 09, 2010
Dirt dobbers
I used flexible wire to stick in the tubing to get any dirt out close to opening, put clorox in a dropper and put in one end of tubing to let it drain through and a bicycle pump to push air/debris out. Took awhile but finally worked!
May 28, 2013 | Little Giant Submersible Fountain Pump
Water pump and ignitor do not work
took coleman away for weekend wouldn't work. Very dissapointed, was cold would have loved a hot shower. Had charged battery, when I went to start it. It wouldn't go, light come up as battery low tried it on car charger still no luck. Got home and looked up this site told me to try taking filter off pump and putting a long nail inside to turn pump to make sure it wasn't seized. And guess what every thing works well thank god, water temp was dodgy as well but now all good. Thanks to people that do reply to these sites, it has saved me a lot of money and frustration.
May 23, 2011 | Coleman Hot Water On Demand
Did not use th machine for several months. After cleaning the machine only makes a lot of nois, no espresso only te stamer works. Pump broken?
The method of Jacked worked fine, but I had to force-feed quite some water into it. I finally attached a plastic bottle that I could squeeze at the end of the tube, in order to feed it enough water.
Dec 24, 2009 | Saeco VIA Venezia
The pump is not sucking up the water into the filter.
filter must be full of water to start.check that pump is spinning.check that suction tube is submersed & not too long some fish tank filters have a knob on top of the elbow between suction tube and pump housing,turn it back & forth to control flow.give the suction tube a wiggle where it meets pump housing.
Sep 24, 2009 | Tetra Second Nature 8.4oz. Desafin
Need a water pump
you can get an equivalent size pump at a store like home depot or Loews.
May 15, 2009 | Little Giant Submersible Fountain Pump
Water fountaian will not work
The curcuit should be simple. The pump is the heart or this system it draws water to the pump(if it can't then the hose is plugged, or damaged) or the pump is bad. If the pump is working then it should be pushing water to its destination. if the water comes out the pump but wont or cant push the water to its destination then the impeller is bad.
Apr 26, 2009 | Beckett Water Gardening Beckett 7124110...
Missing a owners manual for a Garden Treasures biological filter
I have the manual, and I can scan it as PDF, but dunno how to send it to you.  I guess this site won't want us to post email. The Canister is very easy to use, just DO NOT remove the metal tension seal ring.  To prep it, you first have to remove the 4+1 top screws; remove the top part (be careful do not pry the clear plastic cover off, that should stay intact); plug the UV in its socket and carefully insert the UV light into the center chamber; reassemble the top with 4+1 screws; attach the two cone-shape nozzles to the "In" and "Out" of the canister, if you use 3/8" tubing for the pump, then no need to cut the nozzles, if you use 1/2" tubing, then cut the 3/8" section off, likewise for the 3/4" tubing, make sure the In and Out should have the same flow to balance the pressure inside the canister; turn the handle to "Work" plug the tube from the pump into "In" and connect the "Out" with the tube return to the pond or water fall; Turn on the water pump and plug in the UV light (use GFCI), wait 30 secs, and you should see the flow from the return tubing. Note:  use a 650+ gph bump at least; DO NOT submerge the canister in the water; put the canister on an even surface; cover the canister against rain and moisture.  My 800-gallon "green" pond clears up in 7-days. Good luck!
M
Apr 12, 2009 | Garden
Pump no longer working
I have a 2901cs01that I use to pump water into a statue in the middle of my pond but it has stopped working. I have put a hose ontp the pipe which is usually attached to the pump and water is getting through. I have checked the pump and cleaned it with the hose and the little impeller goes round well. I have cleaned the solar panel very well and still there is no joy. Please can you help me?
Mar 20, 2009 | Smart Solar Sun Jet 150 Fountain Pump
3-Tier Henry Fountain Problem
the best thing to do is this bucket of water plug in pump put hose from pump in water to find out whats in and out. out hooks to top in hooks to bottom
Jan 23, 2009 | Henri Studios Henri Studio 5215f17 Three...
Garden Logo
271 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
