Question about Garden
Have a John Deere tractor LA145 Yesterday while mowing the mower blade suddenly stopped working. Turned on and off several times with no luck All pulleys and belts seem to be intact. There was nothing wrapped around mower blade. Tractor is one yr old and has been maintained - about 60 total hrs on it Hope someone can help Gary
    President:
  • 1,627 Answers
Either you need a seat switch or the reverse switch has failed.If the deck will engage while you are pushing down the forward pedal then the rio or reverse switch is not working or it's out of adjustment.If you can not get the deck to engage at all then the problem is likely the seat switch.
Posted on May 08, 2010
Mower deck on my la145 has stoped working,i changed the pto switch ,seat switch,and the reverce switch and it still does not work,when i get off the with thepto on sounds like it is trying to stop.moe
Posted on May 21, 2013
  • Steve McLaughlin
    Steve McLaughlin Mar 19, 2016
    same thing happened to me. the deck has an electric clutch and the battery was not strong enough to engage the clutch. replaced battery and all was well
Mower blades move but no gears forward or back, very suddenly quit.
Rex, check the drive belt,old stretched, loose, broke, fell out of position Tension er weak or seized if equipped, worn out pulleys.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Tightening the belt on John Deere L110 Tractor
https://jdagccc.custhelp.com/app/answers/detail/a_id/428/~/mower-belt-comes-off---100-series
How to Adjust John Deere Drive Belt
John Deere Fail LA145
Apr 23, 2016 | John Deere L100 Series
I have a 2010 John Deere 777 Riding Lawn Mower that stop cutting all of a sudden as I was mowing this morning. Do you have any idea why?
Cutting or running? Big difference..if stopped cutting most likely your belts came off the pulley or broke...have to take a look..Stopped running need more info...good luck..
Aug 25, 2015 | John Deere Garden
Mower blades stops running
check bearings in the spindles and check belt tensions.
Jun 15, 2013 | John Deere Garden
John deere LA145 manual
When I start the engine the mower blades start to turn. The blades turn as long as the engine is running. The PTO does not stop the blades from turning even when I stand up off the seat or when I go in reverse. What should I look for to fix this problem. I have a LA145 mower, 48" cut, bought in 2010. Thanks for your time & help.
Aug 02, 2012 | Garden
The left blade on my John Deere LT155 stopped working
Besides the drive belt, there is a timing belt inside the mowing deck. The left blade is run by the timing belt. I imagine the timing belt is broken.
Apr 27, 2012 | John Deere Garden
I have a John Deere LA145. It has 50 hours on it. I mowed the yard with it and then it wouldn't back up with the blades engaged and the rio button pushed. I turned off the PTO button and backed
With everything you said I never heard you say you checked the oil or put in oil Hope it didn't run tight on you.I'm not sure if your model has one but some also have safety switches under the clutch pedal . If not have you checked the hydrostatic oil im not sure if your is hydro but that could also keep it from shifting in gear and possibly keep it from starting to protect transmission. Just some ideas good luck
Apr 09, 2012 | John Deere 420,1020,2010,2020,2510,2520...
I have a John Deere LA145 lawn tractor. When I engage the mower, a loud noise (grinding) comes from the mower. What could be the problem? The tractor is 2 yrs old.
check and make sure all of your drive pulleys are spinning freely a bearing may be bad in one of the pulleys cause it grind metal on metal but the most common problem is a bent or warped mowing blade cause it wobble and shake and contact the underside of the deck.
Aug 26, 2011 | Garden
When mowing with my John Deere riding mower, it leaves a narrow strip of grass uncut in the center.
try sharpening the blades on the mower. dull blades can sometimes cause a strip of uncut grass
Aug 19, 2011 | John Deere 22HP VTwin 48" Riding Mower
Garden Logo
941 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
