Question about Whirlpool LER5636P Electric Dryer
My LER5636PQ0 wont heat up but it does run. Also the timer does not work or buzz when cycle is done. Help?
  • Whirlpool Master
  • 8,220 Answers
Check for blockages and correct that firstMy LER5636PQ0 wont heat up but it does run. Also - 7767bef.jpgThen unplug your dryer and remove the rear cover. This is your dryer.070f137.jpg
Posted on May 04, 2010
How do I fix my cycling dryer.
so you have not done any work on the electrical system at all changed anything or anything like that do you have a model number Appliance 911 Sea Breeze
Nov 15, 2015 | Maytag Dryers
Dryer wont stop buzzing
follow this steps and fix it. God bless you
Timer
The timer could be the problem. To check this, turn the timer to a timed cycle say 30 minutes or so then time it. If in 30 minutes the timer hasn't moved and the dryer is still on, the timer is bad and need replaced. If in 30 minutes the dryer is off, the heating element is your problem
Heating Element
This is the most likely cause for some dryers timer not advancing. Some dryers have two heating elements and if one goes out the timer will not advance if you use it on an automatic cycle but you will still feel heat inside the tub. replace the heating elements
Jul 09, 2013 | Dryers
Dryer wont turn on
try to spin the inner drum. You could have a broken belt. if it spins really easy, that's probably what it is. There should be some resistance when you turn it.
Sep 08, 2012 | Whirlpool Dryers
Wont go into spin cycle and wont drain but makes a buzzing sound while in the spin cycle
plugged or bad pump or bad drive motor. if it has a seperate pump and motor for drain could have somthing in it if the pump is driven by the main motor pump could have frozen up or motor could be bad in spin mode sometimes the timer won't make the motor run just hums ges are good for this make and model #s help us help you good luck
Dec 08, 2009 | Washing Machines
It wont stop running... dries perfectly but wont stop. Thanks! ;o)
either a timer or the heating element or a blocked vent also there is a resister on some kenmore/whirlpool dryers and if it is out it wont advance in the auto cycles. It should advance in the timed cycle with or without heat
May 11, 2009 | Dryers
My Amana Model NDG5800AWW dryer has ceased to dry clothes dependably. The Only setting that still sort of works is HIGH timed drying, and this heats up to what used to be the "delicate" setting....
if you are using the auto dry setting and the dryer is still running after 5 hours you either have a timer issue or a thermostat problem.
The timer is driven by a motor, if the timer motor is bad the timer wont time out.
in the auto dry cycle the thermostat has to cycle off and on which then sends power to the timer again advancing the timer.
set the timer in a timed dry cycle for say ten minutes, if the timer advances and turns off then you know the timer works. if it doesnt advance you have a timer motor issue,
if the problem is the auto cycle, you could replace the thermostat, about $20 american. however a clock timer would be cheaper.
Based on how old is your machine and do you want to stick a timer in it after already paying the service man is up to you.
A basic bath towel load should be dry in about 50 minutes, this varies on how good your seals are and how long a vent you are running, if the dryer vent was plugged you already have shortened the life of your heating element.
Sep 22, 2008 | Amana Dryers
Whirlpool LER5636P Electric Dryer Logo
449 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
