Top of the AKG C98 mic is missing - the screen
Top of the AKG C98 mic is missing (bought as part of the Olympus DS2200 conference kit)- the screen, just looking for a replacement part instead of having to order new mics.
  • 8 Answers
SOURCE: akg sr 60
help me please akg sr60 , when torn on just mute
Posted on Sep 09, 2008
SOURCE: akg mic buzzing
constant unrelenting hum?
check the fuse housing and make sure it is setup for your local voltage(120/240)
Posted on Nov 28, 2008
yooperbud
  • 8637 Answers
SOURCE: Gigaware PC camera and mic, mic not working
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 12, 2009
Cableg Eye
  • 22 Answers
SOURCE: AKG Perception 200 Mic stopped working. I use it
The simple thing to check would be to see if your 48V phantom power switch on your mixer is turned on. Sometimes there is an individual button to turn it on and off for each channel strip. Good Luck
Posted on Oct 12, 2009
SOURCE: mic for wii rockband not working
Beatles Rock Band Microphone is not being detected even though my mic is plugged it
Posted on Dec 28, 2009
I have the AKG wms 40 dual mini mic set with two wireless mics. When mic on ch 2 is in the off position, I get lots of static. Works perfectly fine when on. What do you think is the issue?
Channel 2 mic's receiver needs the Squelch adjusted. The squelch control mutes the receiver so that when the transmitter stops transmitting, erroneous noises are not picked up and amplified.
Jan 23, 2013 | AKG WMS 40 Professional Microphone
Hum which is made worse on touching top half of mic. clearly an earthing matter. engineer has checked bottom half but does not know how to get into top half.
I have the same mic, same problem. I disassemled the mic, put it back together, and the problem fixed itself. I can't explain exactly why.
To disassemble the top part of mic, turn the 2 plastic posts inside the mic clockwise.
http://www.akg.com/mediendatenbank2/psfile/datei/96/C4000b4055d1f13eb44.pdf
Mar 18, 2011 | AKG C4000B Professional Microphone
Hello, I hope you can help. I have been using my akgd112 mic for my kick for about 1 1/2 years and now I notice that when I hit the drum hard the sound is distorted. I always store the mic in a pouch and...
Get the Caig Labs connector chemical cleaner kit and clean up the XLR connectors. Test a different mic cable as well. If it is not the connectors that are the problem, you have a damaged diaphragm. That mic will handle very high SPL's, but if you put it on a snare drum or guitar amp at high volume you may have toasted it. AKG service dept. will fix it for a fee.
Sep 18, 2017 | AKG D112 Professional Microphone
My akg perception 200 is not responding
Have you tried using a another XLR cable..,or are the other mics phantom powered condensers..ie try to locate if its a mic problem or the cable..2 other points are 1 - XLR leads for phantom mics need to be XLR to XLR male to Female plugs[ends] 2- is that often an XLR to XLR cable will be not soldered or wired right,so that the power [phantom power is not getting to the mic] so ensure you have a proper cable for that job...Sorry i can't be more specific but from reading your problem all these issues come to mind..If you have ruled all these things out,then it could be the capsule or loose joint or component in the mic which means contact AKG,pro audio services or find a DIY mic person to help..G luck!!
Jan 11, 2010 | AKG Perception 200 Microphone
Akg c1000s replacement grille
Maybe you could find a local music store that repairs equipment to replace the grill. Sometimes you can find parts on websites like Ebay.
Oct 07, 2009 | AKG C1000S Professional Microphone
Akg c3000b Low output all of a sudden
Buy the Caig Labs De-Oxit kit and clean up/treat the XLR connections on the mic itself.
Apr 27, 2017 | AKG C3000B Professional Microphone
C 518 ML Isnt Working
Make sure that you are supplying phantom power. This mic requires it. Without phantom power, the mic will appear to be dead.
Let me know if that resolves the problem.
Dan
Mar 19, 2009 | AKG C 518 ML Microphone
Akg D8000S
need to buy the proper sound card ,or a mixing board built for your comp.thier is a usb cord out there,i have one with 1/4 inch on end and usb other end,im sure someone makes one with xlr.
Jan 30, 2009 | AKG C451B Professional Microphone
Samson CO3U USB mic pattern selection switch broken
I have not used that particular mic, but have a AKG 414 which offers the same three patterns and there are three distinct and separate settings on the switch. Maybe take it back into the store where you bought it and ask for clarification there? Hope this was helpful. Peace
Dec 24, 2008 | Samson Audio C03upak Co3u Microphone with...
Akg sr 60
Dec 05, 2007 | Lands Phones
208 people viewed this question
 Grubhead
Grubhead
