Question about Canon PIXMA MP160 All-In-One InkJet Printer
E 2 I keep getting an out of paper error after I have already added paper. The paper begins to enter the printer, then stops and the error signal comes on.
    Guru:
  • 377 Answers
Hi dear
may the error code or how many blinking can solve your problem
this is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED
lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
cropp
Posted on Mar 27, 2008
SOURCE:
Canon LBP 5050N Printer keeps coming up with paper jam. Have turned off, then turned on. Still did not fix. Can you help?
My LBP 5050N would print one page normally then stop with the next sheet just starting to feed (i.e. just touching the first feed wheel). When I took the paper tray out, there was one sheet left behind and I could pull that out easily without it tearing. It was gripped lightly at the beginning of the feed path.
Starting the printer again gave me another copy of the already-printed sheet (I guess that's Windows getting an error message from the printer and treating it as not having printed the first sheet).
As it will always print one page properly before jamming on the next one, the problem was obviously not a small piece of paper stuck somewhere.
I cleaned the rubber wheels with Isopropyl Alcohol as best I could, but they were not obviously dirty or slick/hardened with age. The result was the same.
Then I noticed that the two blue paper grips on each side of the tray showed a small gap of 1 or 2mm. I pushed them in to tighten them gently against the paper and the problem was solved.
I've been searching in many places for an answer to the 'frequent paper jam problem' and not seen this mentioned, so thought it would be useful to have it on record here.
Yeah, I was mentally challenged - I focused on the wrong thing from the beginning.
Feb 18, 2013 | Canon LBP5050N A4 Colour Laser Printer...
Error Code #380
check in back side of printer there should be small paper jam check it.
Jul 13, 2009 | OKI C5100n Laser Printer
Out of paper error in Zebra 110XiIII plus
There is a small thumb screw under the paper guide that has an adjustable stop to hold the paper. If you load it correctly, you should have one on each side to guide the paper into the printer. Also, the machine has either a roller or a bar to hang the labels on, correct? The bar has an adjustable stop to keep the roll from moving around while you print. You may want to setup the media sensor about 1 cm from the left of the printer to make it less subject to this type of error. They come from the factory very close to the edge of the paper to allow for some card printers to work well out of the box. Most people use labels and this is not necessary. I hope I have given you some helpful information.
May 06, 2009 | Zebra 110Xi III Plus Thermal Printer
OUT OF PAPER ERROR
You don't say so in your post, but I'm assuming you ran out of paper and you added more paper to the printer. You could try unplugging the printer's power cord, waiting about 30 seconds or so, and then plugging it back in to see if that will clear the error message.
The HP web site also has a page that offers more solutions:
Out of Paper Error
Hope this helps. Good luck.
Aug 29, 2008 | HP PSC 1610 All-In-One InkJet Printer
Adding paper
I had this problem, try half filling the paper holder and move the slider tight against the paper. This worked for me.
Aug 29, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Open Door. Clear carriage jam, and then press Enter
Sounds like you have a jam. Open the back of the printer and checl for any paper large or small. If there is no paper, just opening the door and closing it may get rid of the message. All it takes is a piece of paper the diameter of a pea to send a signal that there is a paper jam. After yuou have finished close the door and push enter to let the printer know you are finished. See if this helps. I don't think it has anything to do with the ink cartridges. It sounds more like something stuck causing the jam. Be sure not to have anything like a staple attached to the paper you are printing on to. A speck of dirt could casue a jam message too.
Aug 28, 2008 | HP PSC 750 All-In-One InkJet Printer
HP PSC 1315 Problem
Glad to know that your problem is solved.
Thank you for using fixya..
Jun 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer is not working
Try pushing the print head carriage with a bit of gentle force. It is getting stuck, and hence the error. You may have to open side and top covers to reach this. Note: this is not the cartridges, but another device that moves back and forth on the slider carriage.
May 15, 2008 | Canon Office Equipment & Supplies
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
263 people viewed this question
Clive
Clive
old marine
old marine
Ekse
