Question about Brother MFC-8440 All-In-One Laser Printer
'Unable to Print 6F' on Brother MFC 6490CW. How do I fix. need to print items urgently.
komguy
  • 2306 Answers
SOURCE: Brother MFC-6490CW is not printing black
If it's under warranty you're in luck, you need a new printhead,LK3197001, around $80.00. I just replaced one yesterday in the shop for the same problem. I would call Brother customer service and see if they'll help cover the cost.
1-800-276-7746
Posted on Sep 04, 2009
Testimonial: "Thanks, 'komguy' :) !! That's helpful. I'll get hold of them ASAP! Cheers!"
  • 526 Answers
SOURCE: I have a Brother MFC 6490cw and can't Get The
if you have done a couple cleanings and it has not helped, its one of 2 things, either your ink cartridge is empty and needs to be replaced, or the nozzles are clogged on the printhead, also air can be in the turbing causing it not to let the liquid flow.
thanks adi
Posted on Dec 03, 2009
komguy
  • 2306 Answers
SOURCE: Brother MFC-6490CW printer error unable to print
Any of the 30 series errors say that the carriage is not free to move from side to side across the paper. You need to look close on each side of the machine where the carriage travels to see if there's a paper scrap stopping it. Also the encoder strip could be out of the slot in the carriage assembly. If all is OK you need a shop repair to determine if the logic or carriage pcb's are OK.
Posted on Feb 09, 2010
pineworks
  • 4041 Answers
SOURCE: Print Brother Mfc-290c Error Print unable 4F
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 18, 2010
pineworks
  • 4041 Answers
SOURCE: My brother MFC-6490cw injet printer does not print
Hi There
steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
Posted on Apr 28, 2010
Unable print 73
Hi Subnash,
I have this site for you to check the resolution for your issue. Hope it helps.
FAQ Troubleshooting MFC 6490CW Others Brother
May 08, 2014 | Brother MFC 6490CW InkJet Printer
Unable print 5a printer message unable print
how to solution 5a print unable pring Dcp 125 prin
Aug 18, 2013 | Brother MFC 6490CW InkJet Printer
Print job frozen on Brother MFC-6490CW
Power down your printer to clear the cache and re load from page 3.
Jun 20, 2017 | Brother MFC 6490CW InkJet Printer
I have recently installed a Brother MFC-6490CW printer on an iMac with OS X 10.6.6. When attempting to print, I have a choice of two printers: 1) Brother MFC-6490CW (default) or 2) just MFC-6490CW. When...
You have 2 printers because it was inadvertently installed twice. You need to un-install both of them and reinstall the printer again.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 11, 2011 | Brother MFC 6490CW InkJet Printer
Is Brother MFC-6490CW printer can print double sided?
No, that model does not print Double Sided (Duplex). You can see all the features and specifications here: http://www.brother-usa.com/mfc/modeldetail.aspx?productid=mfc6490cw
Mar 10, 2011 | Brother MFC 6490CW InkJet Printer
Paper jams??
click here to download yor required drivers
May 12, 2010 | Brother MFC 6490CW InkJet Printer
Brother MFC-8440 All-In-One Laser Printer Logo
2,598 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
