Question about Dell Ethernet Card Network Adapter
Getting a no network adapter detected message after a nearby lightning strike. No Network folder listed under device manage either. Windows ex sp2
  • 78 Answers
This network cards are the most commun problme on computer if the card is not detected on device manager remplace it
they cost about 10 to 15 dlls
Posted on May 04, 2010
Wireless adapter not found
uninstall the drivers
click on start then right click on my computer, then click on manage, the a page will come up, on the left side of the page you will get the option of device manager on the left, once you will get the device manager, click on device manager, you will get the list of devices, in the list of devices, click on network adapters
once you click on network adapters there would be an option of wireless adapter, right click on wireless adapter and click on uninstall, once it is uninstalled, restart the computer, it will detect the drivers automatically
Aug 14, 2011 | NetGear Push2TV TV Adapter for Intel...
I keep getting an error message indicating that my wireless device is disabled. It's a HP mini. for work serial CNF0260923. HP MIni 210 - 1076NR
If you get that message, believe it.
You will have to enable it either through the software switch or a little switch that some computer manufacturers place on the computer case.
The first thing you can do is open your network connections and see if you can see the wireless connections. If it says disabled, you might be able to right-click on it and enable it.
You can also look in the control panel to see if the HP wireless assistant can be accessed through there (or possibly through the programs list).
Mar 24, 2011 | HP Mini 1000 Netbook
I am trying to copy the driver from the internet connected computer then install it on the PC that I am trying to get connected using the 2wire 802.11g usb adapter, help
what problem are you having - once copied across to the PC you should be able to install and then see the device in device manager if installed correctly to go into the device manager and see if its shown. Press the Windows key (bottom left of the keyboard} and at the same time press the R key, now in the search box that appears - type devmgmt.msc and see if you have a wireless adapter is showing under network adapters. see if there are any ? X or ! look under network adapters - click on the + and see if you have the adapter listed - check if it has any X or ! or ? A useful tool to use, if you can copy onto the PC, http://www.xirrus.com/library/wifitools.php this will detect all the networks broadcasting - so you can now see if the adapter is working and will detect your wireless network
Mar 15, 2010 | 2wire (1000-100052-000) 802.11g/b Wireless...
My computer does not recognize the adapter
You will need to check the device manager.
Open the device manager.
In that list you will see the option network adapter.
Under network adapter you will see your adapter.
right click and go to properties. you will get the exact error message.
If you don't seethe adapter under network adapter list.
then search for the option " other devices " there might be listed.
Unplug the adapter and check if you any change in the device manager list. Plug it back in and check if you see any change.
The change in the list will be the adapter. right click on it and check the error message under device status.
Click here for more info about networking
Dec 01, 2009 | Netopia 3-D Reach (TER/GUSB-N1)...
ECS p4m800pro m2 Onboard Network Adapter does not show up in windows
Try disabling the network adapter in the bios and removing any network adapter in device manager in Windows
Then reboot
Windows so it thinks there is no network adapter.
Then
Reboot into bios and re-anable the onboard network adapter.
Then see if windows detects the network adapter now that it is enabled.
Mar 03, 2017 | Computers & Internet
D-Link AirPlus DWL-G630 - problem after installing XP SP3 and new drivers
delete the previous profile and change the wireless channel to manual , try resetting the router and try  reconfiguring this will fixya
Aug 10, 2008 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Ethernet NIC card not seen in Network adapter (code 31)
Code 31 means that the device drivers are incorrectly installed.
In order to solve the issue fully, can you please tell me what Operating System you are using.
Jun 19, 2008 | Toshiba A205-S4577 Notebook
Computer cant detect device
Try going to add hardware. Then select yes, the hardware is installed. When it gives you the list of installed devices, go to the bottom and select add new hardware device. After that select the advanced option to select "install the hardware I manually select from a list". On the next page, select network adapters. Then click "have disk" you will now have to put your driver in a folder(usually on the desktop). After you select have disk you will browse for the folder which has the driver. Make sure your driver has a file that has the extension ".inf" as this is needed to install the driver.
Hope this helps
May 30, 2008 | Linksys Wireless-G WMP54GS 802.11g/b...
WG111T
The solution I have is quite simple. I use Vista premium x64 so someone else can test it on Xp but it should work for both. In Vista the 1.3 version doesnt work so Facid's solution doesnt work for me.
[LIST=1]
[*]Get the 2.1 setup for Vista and install it.
[*]Go to your NETGEAR folder wherever you installed it to (Program Files x86 for me) and copy the DRIVERS folder to your desktop.
[*]Uninstall the smartwizard and remove everything in the NETGEAR folder.
[*]Plug in your WG111T.
[*]Go to Device Manager and find your WG111T in the list, Right Click and Update Driver.
[*]Browse to the DRIVERS folder on your desktop when it asks where to look for the driver and the WG111T will install. It should popup with a little message when it is completed but you will not be online yet.
[B]I dont know what you would do in Xp x64 system but I believe it has its own wireless manager like Vista and should be quite simalar.[/B]
[*]IN VISTA go to the Connect To button in your Start menu, It should be under Computer and Network, it should show your router along with a 5 bar network strength graphic.
[*]For me all I had to do was double click on the network and put in my WEP hex key and it conected.
[/LIST]
Gamertag: NeoNMD
Nov 04, 2007 | NetGear WG111T 802.11g/b (E82321) Wireless...
Dell Ethernet Card Network Adapter Logo
250 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
