Question about Sony XR-CA330 Cassette Player
TV upgrade in my Motor Home
I have a Sony XR-CA330 Cassette Player w/10 disc changer option in my MH. I am upgrading the TV to a LCD 26 inch screen. I would like to feed the audio from the TV into the Stereo. The TV has only one audio output.
The output is labeled "Coaxial Digital audio output (PCM/Dolby Digital). How do I convert this digital signal to something I can use? I have a audio amp that has "left/right" analog inputs as part of the stereo system.
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
You have to convert the coaxial digital output to non digital right left output! this is done with an adapter which you can get from EBay for $7.79 and free shipping! go to mEBay and search Toslink Digital coaxial signal to Analog converter audio adapter rca! good luck!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/michael_8fc219ce5f384208
Posted on Jun 12, 2017
SOURCE:
  • 81 Answers
SOURCE: HDMI AUDIO NOT PASSING THROUGH?
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
Posted on Apr 08, 2008
  • 320 Answers
SOURCE: SONY DVP-NS57P does not display video
If your TV has no input selector but has a video input, the TV probably "hides" the video input between the lowest channel on the tuner and the highest channel. That means if your tuner goes from channel 2 to channel 119, the video input will be between 119 and 2. The best way to see if this is the case is to slect channel 2 and then use the up/down channel selector to go down and see if you find the video input. Let me know if this works!
Posted on Nov 02, 2008
  • 86 Answers
SOURCE: Digital optical from DVD player produces no audio
Hi, It sounds like your receiver is still looking for audio on the coaxial connection, rather than the optical.
1. Make sure the optical connection is between your DVD player and the LD/DVD Optical In on the back of your receiver.
2. If you have a monitor connected to the receiver to show the on-screen display, click Setup from the main menu, click Input Mode, then, next to LD/DVD choose Optical. It may be set to coaxial, analog or auto.
Alternatively, choose the input source on the front of your receiver (LD/DVD), then press Input Mode button (bottom right, near the input selector) till it displays Digital Optical.
If all else fails, reset the receiver by:
1. Turn off the receiver
2. Hold down DISPLAY and PANEL UP/DOWN buttons and press power.
3. All Clear should appear on the screen.
Use caution, however, as this will erase all the settings in your receiver.
Posted on Apr 20, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: mono to stereo
You can't convert mono to stereo since the TV only has a single input, and not the separate right and left channel circuits needed for stereo. If you are connecting a stereo source like a DVD player, what you can do is combine the right and left channels into one and connect that to the mono input. You need an audio Y-adapter with two RCA jacks going into a single RCA plug. These are available from Radio Shack. If you are outside the US, there should be local sources such as a stereo shop where you can find the adapter. This won't give you stereo, obviously, but you will have all the sound.
Posted on Jun 22, 2009
  • 67 Answers
SOURCE: I have a sony xr-6559 Cassette radio with cd
There is a guy online selling this radio with the CD Changer, and he calls it the cdx-51. There is one on ebay for around $45, and you can see it here http://cgi.ebay.com/ebaymotors/Sony-CDX-51-CD-Changer_W0QQitemZ290351379165QQcmdZViewItem. Hopefully, with the code, you can find the changer you need.
Posted on Sep 29, 2009
I am rigging up an indoor sound system using an old Sony Xplod cassette deck (xr-ca800). I have the unit powered up. I can listen to the radio and tapes, but what I really want is to utilize the R/L...
Those are for the optional CD/MD changer. The deck won't switch over to those inputs unless a compatible changer is hooked up via the bus control. The only way to make this work would require a changer.
Apr 20, 2017 | Sony XR-CA600X Cassette Player
Can you hook the sony 10 disc changer cdx-636 to a car radio?
I have the cd changer box but I dont have the supporting cables to connect to tha sony cassette player can you help me to purchase this item with imege
Jun 24, 2010 | Sony CDX-636 CD Changer
Sony XR-C350 - cassettes get rejected
Hi I do not have a solution but my XR-C350 is having the exact same problem. I just had some repair work done on the car and the baterry had to come out. I have not reset the the system so I might try that? Any help would be greatly appreciated
Tony
Oct 10, 2009 | Sony XR-C350 CD Changer
Cd player not playing
I would go to walmart and buy the disc....its like $10 and made by phillps. After you just put it in your disc slot and it plays you should hear some guy tellin you that its cleaned....this happened on my 2001 Jeep Liberty so it should work
Oct 06, 2009 | Jeep AM/FM Cassette with CD Changer...
How do you work the Aux input?
when something is plugged into the jack (mp3 player ect) there should work when you cycle through the options of the deck such as cd, radio, There should be an aux option when it is plugged in.
Feb 09, 2009 | Sony XR-C210* CD Changer
Wiring
Download Owners Manual and Connection Instruction of XR-CA330 from Sony Support. Manuals are free.
Jan 23, 2009 | Sony XR-CA330 Cassette Player
Sony Cassette Car Stereo - 10 disc changer - XR-C5120R/XR-C5110R/xr-c4120
NEED TO REMOVE POWER FROM UNIT THERE SHOULD BE A BLACK CABLE THAT GOES IN TO CHANGER REMOVE IT WAIT 5 SEC AND INSTALL BACK LIKE IT WAS AND THIS WILL CUT ALL POWER TO UNIT AND WILL 50% FIX THE PROBLEM
LET ME KNOW
Jul 14, 2008 | Car Audio & Video
Sony XR-CA330 Cassette Player Logo
136 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Mike Duncan
Mike Duncan
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
