Question about Broderbund Mavis Beacon Teaches Typing Deluxe 16 for PC, Mac
Fingers position on the key board ,can you display that?
  • 20 Answers
Hii,
The exact fingers position on the keyboard is as following
For Left Hand
Little finger on A, Ring finger on S,Middle finger on D and Index finger on F
For Right Hand
Little finger on ;, Ring finger on L,Middle finger on K and Index finger on J
You can gain speed by placing your finger this way..GO for it
Posted on Jun 12, 2010
How to Position Hands on a Keyboard?
"Touch typing" is where you want to look...
Left center (left traffic) finger located above the "F" key...
((check it out: feel the key with your finger tip))...
~~Right center (traffic) finger located above the "J" key...
((check it out: feel the key with your RIGHT finger tip))
Oct 18, 2016 | Computers & Internet
Tip
How to reset the service/spanner interval light on vauxhall holdon opel
1 foot on brake
2 finger on milage trip switch
3 turn key till dash lights come on
4 hold for about 3mins or intill light flashes and goes out
5 key to off position
6 foot of pedal
7 finger of button
8 key to lights on position
9 light should go out
10 if light is not out try steps again with foot on clutch as well as brake
hope this has saved you money!!!! (maindealers are expensive)
thanks jezza
on Feb 09, 2010 | Acura CL Cars & Trucks
My key wont turn to off in order to remove my key from ignition while in parking
Ignition - Key Stuck In Ignition Switch/Won't Turn Bulletin No.: 06-02-35-005 Date: February 28, 2006 TECHNICAL Subject: Key Stuck in Ignition, Key Will Not Return to Off Position, Shifter Button Won't Release in Park Position (Adjust Shifter Detent Finger) Models: 2002-2005 Chevrolet Monte Carlo Condition Customers may comment on any of the following conditions: - The key is stuck in the ignition cylinder. - They cannot return the key to the off position to remove the key. - The shifter button won't release in the park position. Cause This condition may be caused by the detent finger shifting over time. This may result in mis-alignment and binding of the shift rod on the shift position guide.
WHERE YOUR SHIFTER IS YOU WILL HAVE TO TAKE IT APART ..MAYBE THE RUBBER BOOT IS IT THE WAY,OR THE SHIFT LOCK SELINOID WHENT BAD
Aug 05, 2011 | 2005 Chevrolet Monte Carlo
Healthrider will turn on and is in demo mode. will not do anything else.
1) IF THE MACHINE ONLY RUN IN DEMO MODE, TRY TO RUN IN NORMAL POSITION.
2)PUSH AND HOLD ON THE STOP BUTTON BY 5 SECONDS.
3) IF THE PROBLEM PERSIST, TRY TO TIGHT THE FLEXIBLE CORD FROM KEY PANEL VS DISPLAY BOARD.
4)TIGHT THE DISPLAY BOARD VS LOWE BOARD(MAIN MOTOR BOARD)
5) IF THE PROBLEM PERSIST THE MAIN MOTOR CONTROLLER BOARD IS PROBABLY FAULTY.
6)bEFORE TEST THE MAIN MOTOR.
SINCERELY.
12_13_2011_9_19_40_pm.gifSeethe block diagram
Jul 19, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
I am a slow typer in keyboard,what can i do to make my typing fast? And i want to learn more about the techniques how to type faster. thank you
Ok, here's the short version.
On the "F" key, there is a bump or a line which you can feel reaised above the key. There is also one on the "J" key. Your left index finger rests on the "F" key and your right index finger rests on the "J" key. the rest of your fingers rest on the keys leading out from those keys. Your fingers can use the keys the key they rest on and the keys above and below that position eg, left index finger operates keys "F, T&V" keys and so on. Try to train yourself to only use certain fingers for certain keys. After a whilw, it will become more natural and your speed will increase.
Also, Google "Touch-typing" for more tips and probably exorcises to help you.
Good luck.
Jan 24, 2011 | Computers & Internet
Key pad mis aligned
In order to calibrate the nuvi 700 or 705 series touch screen, follow the instructions below.
  1. Start with the unit powered OFF and unplugged from power supply.
  2. Press and hold your finger anywhere on the touch screen.
  3. Next, slide the power switch ON and immediately slide it into the Lock position. There is no need to wait for the screen to flash on or show the Garmin logo before moving the switch into the Lock position.
  4. Leave your finger on the screen for about 45 seconds.
  5. Two intersecting lines should display on the screen along with the message: Press Dot.
Follow the rest of the on screen prompts to complete the screen recalibration. Once it is completed the unit will display Calibration Complete
Oct 25, 2010 | Garmin Nuvi 760 Car GPS Receiver
Key popped off, how do i put it back on?
hello, take the key with two fingers, put it on its position on the keyboard, now gently press it with one finger until you here a "click", wich means it went back to its original position
Jul 31, 2010 | Sony VAIO VGN-N250E/B Notebook
We tried to rekey our kwikset smart key, but couldn't and now the original key doesn't work
I had mine do the same thing right before I was leaving to the airport [re-keying for the house-sitter]. I was setting the lock and I hear a spring-type ping and the keying was lost.
The tumbler can be reset to your key. However, it involves disassembling the device and has small parts.If you are feeling lucky, you can do this yourself or take it to a qualified person.
If you are feeling lucky:
A: Disassemble the lock from the door
B: Remove the door handle from around the key side.
C: Remove the U retaining-clip from the outside of the lock that is securing it to the shaft.
D: Remove the lock from the shaft
E: Remove the U retaining-clip from the tumbler body and the case
F: You will have to press the five fingers down evenly on the length of the case to slide the cylinder out of the case. (I cut a plastic card with small wire cutters to make a tool, but you could probably use thick card-stock and some scissors.)
Be careful; you will have to watch for and secure the check ball on one side of the tumbler and the finger lock bar on the other side as you slide this out.
G: Remove and store the check ball securely as well as the finger lock bar. (careful with the plate surrounding the fingers that the finger lock bar resides in)
H: Remove the finger locking plate. Carefully, make sure the fingers are still inside and oriented correctly and the spring at the back of the finger locking plate is left in place.
I: You will notice a u channel groove in the fingers and the finger locking plate. Align the fingers in the finger locking plate evenly so that the grooves in the fingers match the groove in the finger locking plate.
J: Replace the finger locking plate with fingers aligned evenly with the u channel groove back onto the tumbler body and hold back against the spring left on the rear of the tumbler body. This puts the tumbler into re-key position.
K: Replace the finger locking bar onto the finger locking plate while holding the assembly against the spring and tumbler body. (If this is done correctly, the finger locking bar will now be flush with the side of the finger locking plate and not raised as normal.)
L: While holding the tumbler assembly together and maintaining the locking plate pressed against the spring, Insert your new key into the tumbler body.
M: While holding this assembly in this position, add the check ball to the tumbler assembly.
N: While holding the assembly in position, slightly depress the black plastic block at the back of the finger locking plate and slide this tumbler assembly back into the tumbler case taking care to rotate the case 90 degrees clockwise from normal. (Note the U channel groove inside the tumbler case that normally receives the finger lock bar and use that for orientation.)
If the tumbler does not insert cleanly, verify the finger locking bar is flush. If it is not, redo while maintaining proper pressure to keep the finger locking plate firmly against the spring in re-assembly. Also, verify the fingers are not protruding from the tumbler body. If they are, redo the procedure taking care to align the fingers properly on assembly and maintain proper force on the finger locking plate against the tumbler body during re-assembly and new key insertion
O: Rotate the key and tumbler body in the case to the normal position (counter-clockwise 90 degrees).
P: While holding the tumbler body firmly against the case, remove the key.
Q: Re-insert the key and verify smooth rotation.
R: Align the tumbler body and case back to the normal position and while holding the tumbler body firmly against the case, remove the key.
S: Replace the U retaining-clip that belongs on the back of the tumbler body to secure it within the case.
T: Replace the tumbler body in the main lock shaft and secure with the shaft U retaining clip.
Mar 24, 2010 | Kwikset Professional Door Lock...
Reset prosedures for volvos
Ok when you move the key to start the car. you need the following definitions.
pos 0 equals car off
pos 1 equals acessory position
pos 2 equals run position (NOT START)
pos 3 equals start position
check your drivers information module, and see that your triip display is in trip 1 (T1)
then put your car into position 1. push and HOLD the trip reset meter. WHILE HOLDING the reset button, rotate the key to position 2. Hold the reset button until you see the triangle in the dash flash yellow. Once this starts flashing remove your finger from the reset button. Shut the car off, verify light is out. repeat once if necessary.
Jul 22, 2009 | 2004 Volvo S60
My Magellan RoadMate 700 GPS Receiver won't locate my position.
If out of warranty time frame, open her up and check the grey cables that you will notice right after you crack the case. Make sure the cable is un damaged and connects to the main board (the big one) to the I/O board (attached to rear housing). If no change, then try resetting GPS user data. At User Menu (after reboot), press "-" key and repeat key at the same time. select reset GPS user data and cross your fingers. -Daniel
Nov 10, 2006 | Magellan RoadMate 700 GPS Receiver
Broderbund Mavis Beacon Teaches Typing Deluxe 16 for PC, Mac Logo
296 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
