Question about Apple Macintosh Keyboard
I recently have been having problems w/certain keys on my Apple Keyboard with Numeric Keypad. I used some wipes to clean it the other day...and almost immediately the spacebar & a lot of of other keys where not working properly. Then a few hours later some of the keys including spacebar started to work. But there are a few buttons left specifically on number pad that just don't seem to respond or work when pressed
  • Macs R We
    Macs R We May 17, 2010
    It would be helpful if you could specify which keys "just don't seem to respond or work when pressed." Some keys on the numeric keypad have no visible effect, and others are only active in certain contexts.
    Problem Solver:
  • 6 Answers
Some of the fluid from the wipes must have short circuited the keyboard! you may have to invest in a new keyboard and keep it away from water based wipes this time!
Posted on Aug 01, 2010
I NEED A MANUAL TO SHOW HOW TO GET MULTIFUNCTION KEYS TO WORK. FOR EXAMPLE HOW DO I GET THE ALTERNATE USE OF THE "NUMERIC 6 "KEY ie THE" QUESTION MARK" FUNCTION
You must have a different keyboard selected other than the standard US keyboard My numeral 6 has ^ on it and the numeric keypad 6 has a right arrow. One generally uses the SHIFT key to access symbols that are written above the main alpha or numeric key. The numeric keypad on side of PC has a button labeled key marked NUMLOCK that is engaged to allow use of the numerals as a calculator or to also be inserted into text.
Please rate my help++++Thanks for using FIXYA
May 09, 2010 | Acer NSK8458AN Keyboard
Cant get the at button to work even by pressing shift or not,every other key function works.
You may have a bad key, or a key with something under it.
Try this:
Turn the netbook upside down so that the keysj face the floor.
Bang on the back side that way you would to burp a baby.
Then, take a vacuum cleaner and **** out the spaces between the keys.
If this doesn't work, you may have to make an @ symbol manually by using the ALT key. (ALT plus 64). This should work in most Word Processing programs.
  1. Make certain that the Num Lock key has been pressed to activate the numeric key section of the keyboard.
  2. Depress the Alt key.
  3. While the Alt key is depressed, type the proper sequence of numbers (on the numeric keypad) of the ALT code from the table above.
  4. Release the Alt key, and the character will appear.
  5. On a laptop computer, there usually is no numeric keypad. So, instead, depress the Fn (function) key, then the Alt key, then the numerical code sequence. The numbers are on the fronts of certain keyboard keys: M=0, J=1, K=2, L=3, U=4, I=5, O=6, 7=7, 8=8, and 9=9.
http://www.tedmontgomery.com/tutorial/altchrc.html
Nov 13, 2009 | Acer Aspire One AOA110-1113 Netbook
Numeric keypad seems to have died. Is there any fix for this besides throwing it out the window?
There is little to fix on these as the cost of repair would be more than a new keypad would cost.
Oct 08, 2009 | Verbatim Speaker Keyboard Keyboards
I'm having a similar problem with the wired aluminum keyboard
If you feel there may be some moisture in the keys then blow thekeyboard with your hair dryer with its heat turned off.
Aug 07, 2009 | Apple M9034LL/A Keyboard
Numeric Keypad doesn't work after windows XP logon
pause your antivirus and plug ur keyboard pin
Jun 18, 2009 | Computers & Internet
Numeric Keypad
if you search on the keyboard keys there will be one key that says "NUM LOCK" on it pressing which you will be able to turn on or turn off the numeric keypad on the keyboard.
Apr 22, 2009 | Computers & Internet
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Lock 9 light is on
The numeric keypad functions like the numeric keypad on an external keyboard. Each key on the keypad has multiple functions. The keypad numbers and symbols are marked in blue on the right of the keypad keys. To type a number or symbol, hold down <Fn> and press the desired key.
  • To enable the keypad, press <Num Lk>. The keyboar2.jpg light indicates that the keypad is active.
  • To disable the keypad, press <Num Lk> again.
Mar 20, 2009 | Dell Latitude D410 Notebook
Logitech MX 3200 wireless keyboard Numeric (right side) keypad does not work.
maybe it is full of dust on those buttons. Try cleaning it with a duster of mini-brush because it interrupts the function.
Jan 30, 2008 | Logitech MX3000 USB PS/2 Wireless...
Apple Macintosh Keyboard Logo
292 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
