Question about Acomdata (HD080U2FE-72) 80 GB Hard Drive
My drive is not doing doing "plug and play."
My drive is not doing doing "plug and play." went to website and loaded drivers but still no luck with that. year back or so, broke the installation cd so im in a pickle. can somone please help me.
  • 1 more comment
  • larrel4good Mar 26, 2008
    its the Acomdata 80gig external hd080u2fe-72. Aswell, is there another way to install. (from previous post...more info)
  • Anonymous May 17, 2008
    701 Samba Hard Drive Enclosure will not work with Seagate 80Gb Barracuda
  • lilianpadill Nov 07, 2008
    I have the same problem, i unplug from my desktop computer to my laptop to get something from my laptop to transfer to the drive and when i tried to plug it back in to the desktop computer it doesn't recognize the drive.
Upgraded from Mac OS 9.1 to Mac OS 10.5 and system will not recognize my hard drive. Can you help?
Posted on May 08, 2008
SOURCE:
I have a logitech flash drive that is not picked up by my computer when I slot it into the USB port - I went to my computer and checked under disk management but it is not even coming up under there - do I...
Hi.
USB flashdrives are usually all plug and play so you don't need any additional drivers for them.
Try plugging the flash drive into a different computer. If it works on another computer your USB slots maybe faulty.
If the flash drive is not picked up by another computer then the flash drive is probably faulty.
Regards.
Jun 07, 2011 | Computers & Internet
How to solve usb not reconized error in sony vgn-s36gp?
Hello
Disconnect the flash drive from your computer, then plug it into a different USB port. On occasion some USB ports do not detect inserted equipment (either because the port is damaged or because the flash drive is not supported by the particular connection).
Connect the flash drive after the computer has powered on. If you plug the drive into the computer before starting the system, the computer may not detect the USB device.
Open an Internet browser and navigate to the drive manufacturer's website. Although most USB flash drives are plug-n-play, the computer may not have the appropriate drivers installed, which means you must install the driver before the system can use the flash drive.
Select the "Support" option, then choose "Drivers and Downloads". Click on the model of flash drive you are using, then the operating system. Click on the driver download link and wait for the driver to download to the computer. Double-click the downloaded file to load the installation wizard. Accept the license agreement, then follow the prompts to install the driver. Restart the computer and the system is ready to use the USB flash drive.
Oct 12, 2010 | Sony VAIO VGN-CR220E/P Notebook
Can I download pictures from my digital camera onto my Dell Latitude d410? If so, how?
You can download from any digital camara.Load the CD that came with the camara or obtain one if you can. You need the interface cable that is purchased seperately. You do not specify the camara spec so you will need to Google the" model and pc interface cable". If you have the cable then the next step is the camara driver which should be on your cd that came with the camara. Plug in the cable to the camara and to the USB port on the PC (make certain the camara is set to the Play position or PC). Windows will ask for the driver location. Insert the cd and continue. If windows does not see the driver you will need to locate it manualy from the cd or on line and download it to your desktop from the manufacturers web site. All camara companies have a support website for the drivers. Once the drivers are loaded then you need to switch the camara to the Play position so it can be seen by the computer. Go to the control panel in windows and select system then hardware then devices. If all went well you should see the camara listed as a device. Now you need the camara software or a picture viewer from the web. Here is the web kocation http://en.kioskea.net/telecharger/telecharger-653-picture-viewer
If all went properly 1. driver 2. picture software then you should be all set to handle your pictures. Good Luck Phil [email protected]
Feb 20, 2010 | Dell Latitude D410 Notebook
I downloaded that SD 608 Zip driver and now the machine
Ok - here we go - try going to the mother boards website and updating the motherboard at the Emachines website.
Jan 25, 2010 | E-Machines etower 500id PC Desktop
Pls get me sound driver for model AWRDACPI manufacturer is BGT___
please try this :
http://downloads.viaarena.com/drivers/audio/ComboAudio_A1u370b.zip
hope this work and good luck
or try this one
Sep 18, 2009 | Intel Premier Resources 4-Channel 32-Bit...
Same problem
Check with your computer manufacturers website for any driver updates for the motherboard and also be sure to check with microsoft's optional driver and software update section which may hold a driver update for your computer.
Aug 21, 2009 | SimpleTech 1TB External USB 2.0 Hard Drive...
Hp 530 laptop
NO OS STATED, XP? (can also be VISA)
http://support.microsoft.com/kb/314060
DVD drive like that is complex.
those yellow marks are clear, bad driver !!!
but getting a good driver can be horrific. in 2017
XP is dead. at MS and almost dead at HP,
are you connected to the internet when you up date
said driver (DVD)
DVD can be formatted vast ways.
you never said whats on it, a store bought movie
or a disk full of UDF files (PDF)
or other vast ways to use any DVD?)
then pick "software solutions"
and HP SoftPaq Download Managersystem software Manager Icon
Softpaq, install, it to your matched OS
then run it
and it magically (if connected to internet)
will install all the correct HP drivers for this PC>4f82b1ea-f17e-4c02-a67a-a95d3adabd58.jpg
Apr 17, 2017 | HP 530i (Q6750A) DVD±RW Dual Layer...
I have an eMachines T3616 with Vista on it and want to change to XP-Pro. Vista is just too darn slow. The problem is the drivers. Any ideas? TYIA, Russ
i think the only problem you encounter is about the sound driver. Because the other driver is plug and play for the other devices.
Open the link below and download the realtek audio driver.
Good luck....
http://www.realtek.com.tw/downloads/
Apr 18, 2008 | Computers & Internet
Laptop wont recognise dvd drive
Here is the explanation and solution for the error code 41:
Code 41
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41) Recommended resolution
A driver was loaded but Windows cannot find the device. This error occurs when Windows does not detect a non-Plug and Play device.
If the device was removed, uninstall the driver, install the device, and then click Scan for hardware changes to reinstall the driver. If the hardware was not removed, obtain a new or updated driver for the device.
If the device is a non-Plug and Play device, a newer version of the driver might be needed. To install non-Plug and Play devices, use the Add Hardware wizard. Click Performance and Maintenance on Control Panel, click System, and on the Hardware tab, click Add Hardware Wizard.
On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
Good luck.
Apr 07, 2008 | Computers & Internet
GMA 4082n device driver not working properly code 39
no this is basic drive if this driver do not load on ur system check ur drive configuration means jumper setting if that is in master change and get it into slave any , primary or secondary.
Sep 23, 2007 | Computers & Internet
Acomdata (HD080U2FE-72) 80 GB Hard Drive Logo
289 people viewed this question
Top Acomdata Computers & Internet Experts
Ekse
Joe Goldman
Joe Goldman
Are you an Acomdata Computer and Internet Expert? Answer questions, earn points and help others
