Question about Whirlpool GEW9250 Electric Dryer
My dryer stop working, when I pused the button for it to come on nothing happens Is my belt broke, or too much lent in the vent.
    President:
  • 1,382 Answers
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Posted on May 05, 2010
Roper by Whirlpool
send the model number,
Jan 06, 2012 | Dryers
I have power to the dryer. The control panel lights up. I hear beeps and clicks. However, nothing else happens when I press the start button. The motor does not come on, the door latch feels like it is...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 26, 2011 | Dryers
My kenmore dryer wont click on, it will light up and click but nothing happen's I cleaned out the lent trap and the lent funnel and it still wont click on
heatman101
Jul 19, 2011 | Dryers
My dryer does not dry clothes as fast as it used to - does this mean it is saying goodbye? It is a WTA 3500 vented dryer and is about 12 years old.
No, it might just mean your venting is stopped up with lent. Take the 4" hose off the back of the dryer and take a look up into to venting. If it is all stopped up, you should clean it out all the way through and your dryer just might say "hello" again.
Apr 20, 2011 | Bosch Dryers
Push start and motor hums, but nothing else works.
Hi, If you release the start button, does the hum stop? It sounds like hte start winding in the motor is bad. You can try and start it manualy by truning the timer on, open the door so that you can turn the drum with your hand. You will need anoth person there so that one of you can hold the door switch button in and the other push the start button. While pushing the start button, try turning the tub and see if it starts. This will give you an idea on the motor bad or not.
I hope this helps. Please let me know if you need any more assistance.
Thanks
Vic
May 12, 2009 | Dryers
We have a Kenmore 110 6092299 90 Series dryer. The motor still runs - but no hot air, at all. I've tried timed and heat dry. Nothing. It just tumbles and it takes 4-5 rounds to dry. At first we were told...
Sounds like the heating element or the thermo-cut off. A vent being clogged for some time, can cause too much heat to build up and make the element or cut off fail. These are the 2 most common things.
May 05, 2009 | Kenmore 63942 Dryer
Power going to switch but no action in the drum
check the belt, it may have a broke belt switch.
Nov 24, 2008 | Kenmore 63942 Dryer
MAYTAG DRYER LDE4914ACE BELT CHANGE
The belt goes around the pully so that the pully tension takes the slack out of the belt. Just like the serpentine belt on your car.
Nov 15, 2007 | Maytag PYE2300AY Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
104 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
