Question about Aircat Nitrocat Xtreme By Impact Wrench 1/2in., Model# 1000TC
How much oil goes in a nitrocat 1000 tc hammer housing and what kind
2 Suggested Answers
SOURCE: i have a nitrocat 1000rg with a broken hammer pin
I have same impact and have had same problem, I got mine from Mac tool distributor that comes to dealership I work at and also purchased sets of new hammer pins from him also, take note that the round cam that hammer pins ride on will get nicked and damaged and take out new hammer pins so watch out for that too.
Posted on Sep 22, 2012
What kind of oil grease goes in a. Hm1301 makita
A-90582 2 tubes of grease 30cc http://www.acetoolonline.com/Makita-Tools-A-90582-Hammer-Grease-30Cc-p/mak-a-90582.htm
Sep 11, 2014 | Hammering
How do i chack bosch 60 lb jackhammer oil leval
Bosch hammer uses grease available in repair kit. Check ebay or parts house. Remove four hex bolts on the mid section of the hammer and pull off the lower end. Most of the grease goes here. There is a side cover to expose the drive gears if you hear gear noise. Depending on use, only needs grease once a year. Good luck.
Jun 30, 2014 | Makita HM1500B 42 Lb. Demolition Hammer
Hilti TE17 - what kind of oil does it take? this one has a black filler cap
You can use an AW46 hydraulic fluid. Around 35cc's if the gear housing is still wet with oil or 50cc's if you washed it out. The black cap just means that you don't have a safety clutch.
Dec 01, 2010 | Hilti Drills
How do u set the timing on a oil pump for a 76 harley sportster xlh 1000 lay down pump
On the oil pump shaft housing, just below the gear, there's a small square slot cut out of the housing. If you rotate the oil pump shaft, you'll see a dot on the shaft. You want this dot on the shaft in the slot in the housing when the Top Dead Center mark is in the timing hole on the other side of the engine. You have to install the oil pump like you would a distributor. You turn the dot away from the hole and when you put the pump into position, the oil pump drive gear turns the shaft while the pump goes up on the studs. When you get seated, the marks should be aligned.
Good Luck
Steve
Oct 27, 2010 | 1979 Harley Davidson XLH 1000 Sportster
What kind of oil does my 08 scion tc take?
there should be a label under the hood telling you what kind of oil you need if not stop by your local Toyota or Scion my wife 2005 Scion XB use 5-30- Synthic wish you the best of luck Michigan Man
Oct 24, 2010 | 2008 Scion Tc
I have a nitrocat 1000rg with a broken hammer pin were do i get more?
Feb 22, 2010 | Aircat Nitrocat Xtreme By Impact Wrench...
What kind oil use for makita hm 1304bx1
What kind of oil is used in a Makita Demolition Hammer?
Oct 01, 2009 | Makita Hm1304bx1 Demolition Hammer +...
TE-72 sporadic hammer
You should have no more than 70cc of oil in the housing. AW46 Hydraulic fluid will work.
Aug 12, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Which type of oil goes in the chuck of the jcb
use 3 in 1 oil, its light and wont hold a lot of dirt or gunk. easy to clean chuck and reapply
Jun 10, 2009 | Drills
I need to know what kind of oil to use for a Honda motorcycle.
You need an SE oil, Wal Mart used and maybe still does sell a motorcycle oil (not their brand). You probably will need 30 weight or a multi viscosity (which I use 20-50). Buy a good oil, maybe a synthetic with that rating. Rear final takes 90 weight in most instances except cold weather. A parts house or bike shop will sell the right oil. Just buy the best oil you can, and keep it changed frequently & the wing will just about go forever, Hope this helps you with your scoot, Rick
Apr 25, 2009 | 1976 Honda GL 1000 (K1)
Aircat Nitrocat Xtreme By  Impact Wrench 1/2in., Model# 1000TC Logo
99 people viewed this question
Top Aircat Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Aircat Air Tool and Compressor Expert? Answer questions, earn points and help others
