Question about Dell Inspiron 5160 Notebook
Dell 5160 orange light
My Inspiron 5160 DELL laptop went to hibernation mode yesterday, and one hour late when I tried to recharge it with adapter, laptop didn't work.
When I plugged in the AC adapter, the laptop appeared to be dead.
The light on AC adapter was green all the time (before and after I connected it to the laptop), but when I pushed the power button on, nothing happened and only solid orange lights on the front part of the laptop appears for 2-3 seconds and then they go off.
I removed the battery and tried only AC adapter, but still I could not turn the laptop on by pushing the power, and three orange lights would become on for 2-3 sec, and then would go off.
Could anybody tell me what's wrong with my laptop?
P.S. yesterday I was watching DVD while the laptop was unplogged for about 1 hour.
Thanks in advance,
Ninian
  • Ninian Mar 26, 2008
    Thanks so much for your help.
    I did what you did that was I removed the battery and then adapter from the laptop and I hold down the power button for 60 sec.
    Then I connected the adapter to the laptop again, this time with no battery. Noe the orange lights are gone , instead every 7 sec green lights are flashing in the front part, but still I can not turn the laptop on.
    ninian
Can you removed the hard drive, cd rom, and any removable device
and try to power up unit.....I am hopping that it is not your system board????????
I need the service tag No. so that I cam look up the unit
Posted on Mar 27, 2008
  • 26 Answers
Removed battery, and acadapter FROM UNIT, HOLD DOWN THE POWER BUTTON 60 SECOND That should drain the power from it
Posted on Mar 26, 2008
  • Yves Morency Mar 27, 2008
    If the main power button LED is flashing or solid yellow, this could indicate a hardware problem
Dell Inspiron 5160 doesn't charge
you mite have fried the power supply. or the battery.. try removing the battery and pluging it in,and then power it up
Jun 13, 2012 | Dell Inspiron 5160 Notebook
Battery led blinks orange on dell inspiron 5160
if the battery LED blinks orange, most likely there is a problem with the battery itself. Try to remove the battery and have the power cable connected to it. If there is no battery LED blinking, call Dell to replace the battery itself..
Aug 20, 2011 | Dell Inspiron 5160 Notebook
I have a dell inspiron 5160 and the batery light and the power light is flashing at the same time what will cause this to do that
Hi there, I would like to try and help you solve this, please let me know if you replaced your motherboard. Is your computer turning on?
May 26, 2010 | Dell Inspiron 5160 Notebook
Dell inspiron 5160 labtop backlight
It seems to me the inverter is busted. That is why the backlight just went out. If you are still covered by your warranty Dell technical support will replace the inverter and i believe they will also include the LCD kit.
Hope this helps
Jan 16, 2010 | Dell Inspiron 5160 Notebook
DELL Inspiron 1525 Notebook
go into msconfig and then click on the startup tab. Click on the button that says disable all and then apply the changes. Let the laptop reboot and when it gets back into windows try to go into hibernation mode again and see if it still reboots on you. If it does then its an operating system issue. If it doesn't reboot on you, then go back into msconfig and only enable the programs that you feel you need to run when windows boots up.
Feb 17, 2009 | Dell Inspiron 1525 Notebook
Orange blinking power light on inspiron laptop
I recommend purchasing a new Dell Inspiron battery.
The code 4 blinking orange or amber and one green, means a defective battery.
Thank You, Raphael
Jan 24, 2009 | Dell Inspiron 5160 Notebook
Dell Inspiron 5160 flashing orange / green power LED
If your Dell notebook battery flashes four orange one green, there might be a problem with your battery.The battery life is also shorten and doesn’t last longer than an hour.gets hot sometimes.
pls see this if it helps
http://www.wareprise.com/2007/07/05/dell-notebook-battery-flashes-four-orange-one-green/
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
pls do rate me FIXYA if i helped u
Nov 29, 2008 | Dell Inspiron 5160 Notebook
I have never found hibernation to work successfully.
Disable hibernation if you ever get it started.
Try reading the manual on how to restart for hibernation, press "spacebar", "enter" or something.
Oct 10, 2008 | Computers & Internet
Laptop won't turn on
I am facing a similar problem with 5160 and my power button will not power up the laptop. I presses the shift key, it got powered up (offcourse only fan started but the screen is black)
Try pressing shift key to power up.
Jul 11, 2008 | Dell Inspiron 5160 Notebook
Problem Dell Inpiron 5160
Hello Maciekpl,
This is Romeet,i would like to try and help you solve this, please let me know if you have a replacement motherboard for your laptop ready? also let me know how comfortable would you be with opening up the thing and replacing it?
B.Regds
Romeet
Dec 01, 2007 | Dell Inspiron 5160 Notebook
Dell Inspiron 5160 Notebook Logo
823 people viewed this question
Alun Cox
