Question about Goldstar DH304 Dehumidifier
Humidifier just not working!
We were given a brand new Goldstar dehumidifier that worked great in our basement for about 6 months. Now, when we need it the most, it won't turn on at all. We plug it in and turn the dial but get no response. Is it blown or is there a way to find out if a part needs replacing?
  • Goldstar Master
  • 43,501 Answers
There are many reasons for a dehumidifierhumidifier just not working! - 2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on May 17, 2010
Runs but does not humidify
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
heatman101
Sep 16, 2011 | Goldstar DH2510A Dehumidifier
I have a customer who has a model 1700 dehumidifier Connected to ductwork with a/c only air handler. Not Sure why this is needed or correct way to wire. Also There is no remote humidifier & unit is...
I have to agree with you. I don't see the need for the dehumidifier either. As the AC unit alone, does have some dehumidifying capability.
Your customer would be better served using an independent Low Temp dehumidifier in the basement. If that's the area they are trying to dehumidify because of dampness in the basement.. It certainly would be less costly to operate. But, any unit that is not a Low Temp unit won't work well in a basement.
I hope this helps and good luck convincing your customer of this.
Thanks for choosing FixYa.
Aug 24, 2011 | Aprilaire 1700 Dehumidifier
My dehumidifier runs but no water will collect in the bucket. I ahve tried increasing the percentage. My basement is plenty damp!! Model504EL
Mine had the same problem: ran, sounded great, no water. Feel the coils. Mine never cooled down - stayed at room temp. No refridgerant left in the coils. It's a gas and can leak out. Expensive to recharge. Get a new one.
Jun 19, 2011 | Goldstar DH504EL Dehumidifier
I have a goldstar just like the one on the front a friend gave it to me i only hear it once in a while is that what it is suppose to do,, to **** water out of a basement...
heatman101
Jun 01, 2011 | Goldstar DH304 Dehumidifier
My humidifier will not remove water from the air anymore. The unit will run for hours with no water in the bucket. Temperature in the basement is about 63 degrees with a humidity level about 55%. But now...
heatman101
May 07, 2011 | Goldstar Dehumidifiers
Dehumidifier runs but collects no water - coils are clean there is no obstruction the humidifier worked until a few weeks ago
There are many reasons why a dehumidifier will not work or collect water.
heatman101
Jun 17, 2010 | Goldstar DH504EL Dehumidifier
Goldstar dehumidifier model DH305Y6 is there an outlet on this model for a hose so can drain into sump pump?
I have a Goldstar dehumidifier, Model DH305Y6. I bought it about 5 years ago at a local Walmart. During the summer I run it in the basement, here in south-central Pa. When it was brand new it worked very well, for about 2 yrs. Then it began turning on & off very irregularly. At first I thought it was the sensor on the front of the coils. So I moved it to the lower left side of the coils, and had the same results. The other day the water heater in the basement developed a leak. About 300 gals. of water covered the floor. After sumping/wet-vac'ing down to a wet carpet, I pulled out the dehumidifier and plugged it in,(the filter was cleaned before put away last summer). It began its on/off cycling again. It runs for about 2-3 mins., then shuts off for about 5-10 mins. So, I took the On/Off switch apart and read the resistance. It read 48k, for the 50k switch. I turned the switch all the way left to all the way right and it went from 48k, down to about 8k. The two wires to the switch were attached to the #2 and #3 poles,(only 3 poles). I did some testing, then removed the wires and re-soldered them to the #1 and #3 poles. I put everything back together, and now it works. It runs constantly, but it works/runs just fine. I need to get the basement dry, so I will let it run until the job is done. In the Spring I will get a new 50k potentiometer,(on/off switch), and see if that works. I will post results if I remember to.
Sep 29, 2009 | Goldstar Dehumidifiers
Looking for floor drain hole cover that accepts a hose
yep home depot get one with holes and a plastic tie will keep it in place
Jun 16, 2009 | Goldstar DH304 Dehumidifier
Goldstar dehumidifier won't stay on
Check the relative humidity in the room or space where you are operating the dehumidifier. Damp feeling and actual humidity level are two separated items. Humidifiers will run for a few minutes until it is signaled that the humidity is already low enough and then shut down.
Oct 27, 2007 | Goldstar DH504EL Dehumidifier
Humidifier stopeed working
You have a bad fan motor. Put your hand against the grill to see if there any air movement. You need to buy a new fan motor assembly, it is attached by two long
bolts, easy to swap, except the wiring may not be easy. May have to cut the 3 wires and resolder. Get to the motor by removing the back panel and then the fan. Removing the fan may not be easy, they put some gunk on the spidle thread.
The cheapest price I have seen for the motor is $27-$28, shipping about $8 and tax
about $1.5.
Sep 18, 2006 | LG Goldstar LD65EL Dehumidifier
Goldstar DH304 Dehumidifier Logo
682 people viewed this question
Top Goldstar Dehumidifiers Experts
Gil Shultz
Michael Youngman
Michael Youngman
Jerry Greenberg
Jerry Greenberg
Are you a Goldstar Dehumidifier Expert? Answer questions, earn points and help others
