Question about Indesit W 123 Front Load Washer
Selector switch The program selector switch will not stay on its washing and spinning cycle and keeps turning on its own. I think the program selector switch is worn. If you agree how do I dismantle it and get a replacement. Kind Regards R K
  • 67 Answers
The clicking of your selector is telling you that you have a fault but it does'nt tell you what type of fault . It could be anything from not being reset to a control board , or a motor to pump my advice to you would be to call an expert . goodluck
Posted on Mar 31, 2008
SOURCE:
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
Pump runs when door is shut and does not first program
May be the selector switch is off of the programming. May have been slightly pulled out on last cycle being used. Try pushing selector switch inward and turn to wash cycle, should feel and hear clicking sound as you turn selector switch
Sep 23, 2014 | Beko DW602 600 mm Silver Built-In...
Is there a spin ony program?
Broken washing machine Will only offer spin option Try turning off at the main switch and wait for 5 minutes then turn it back on and try again - sometimes they seem to have a mental block
Apr 30, 2011 | Washing Machines
I have a Kenmore 24852300 washer. My issue is that it fails to spin out intermittently. By that i mean when it gets to the spin cycle and it fails, we can turn it off, rotate the selector knob, and pop the...
I think it is most likelt in the dial switch selector. It would almost have to be if you can get it to work by turning the dial aroun afew times. I would replace the selector switch.
Jan 22, 2010 | Washing Machines
My washing machine overflowed and would not drain. When it is on water keeps coming in even though the machine is full iof water but there is no movement of the agitator and I could not get it to...
H i there.....sounds like you've got either a failed water inlet valve....or a disconnected /ruptured capillary hose from the pressure switch to the tub....or a failed pressure switch........turn water to appliance off.....turn program selector to drain or drain /spin..is drain pump running...if not it may be blocked or burned out....or with machine empty of water.....turn program to spin....if no spin...check motor....
regards Sir Galahad
Aug 21, 2009 | Washing Machines
Doesnt go through programs
sounds like you have a bad timer or lid switch. does it finish a cycle but not advance or does it just keep washing or does it wash then stop and get stuck? if it just keeps doing one cycle like wash wash wash you would have a bad timer. if it washes then stops and gets stuck you have a bad lid switch. But then again if you had a bad lid switch it would never spin. What is the brand name of this washer?
Jun 10, 2009 | Washing Machines
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
Washing machine just keeps spinning
al indesit washer have a reset pattern
switch of with on/off button
turn selector to a large 'off dot' position
wait a couple of mins then switch back on
wait 2 mins
then switch off again and turn selector to a cycle start position
wait 2 mins turn back on and let it run the FULL cycle do not mess it about.
Sometimes it takes 2 or3 attempts so be patient
If there is a fault it will appear again within the cycle and give you an error code eg E7/E1 etc note this and call a repair man he will track it from this code.
Jan 22, 2008 | Indesit W 123 Front Load Washer
Selector switch
it is telling you, your machine has a problem you need to tell me what program are you putting it on. if you put it on a spin only and it keep going round What you need to do is turn the machine of and open the door leave the door open and put the machine back on set the program to the spin only and then shut the door press start do touch the machine till its finished that should help Its called a reset. if you have the same problem get back to me and i will help you ok.
Jan 05, 2008 | Washing Machines
Stuck in wash cycle
check if heating by putting on as hot wash and feeling the door. if no heat, check continuity thro the heater - modern heaters have a non-resettable cut-out in them which can cause problems. no heat then no program advance
May 08, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Indesit W 123 Front Load Washer Logo
165 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
