Question about Dell Inspiron 531s Desktop Computer
Dell Inspiron 531 keeps shutting itself off. After a few moments, tries to restart. and shuts down, almost like it's hibernating, or overheating. New PSU and re-thermal'd the processor/fan
  • wrl8 May 05, 2010
    I already replaced the PSU after the original PSU tested bad. Also cleaned and re-seated the CPU and the CPU Fan. I'll try re-seating and cleaning all other components. FYI none of the capacitors have 'popped' caps.
    Thanks,
    Bill
You have a bad on button wire.
Dell Inspiron 530 531 Vostro Power Button Cable NT294.
Find it on Ebay. I did.
Posted on Apr 07, 2011
  • Kathy Shuller Apr 07, 2011
    You can remove this part after taking off the cover on the front of your computer. There are two wires attached to the switch at the top. One of them is going to be hanging on by a thread. Easy to see.
    President:
  • 1,851 Answers
Try removing every single thing in the box you are comfortable with removing - reinstalling.
Take each piece starting with one stick of ram - clean the connectors -[ shiny copper or gold looking area] with a clean pencil eraser.
Install each one - one at a time.
First one stick of ram.
Then another - then a removed card - one at a time.
If this problem continues after reinstalling only the first stick of ram - you may have to re-seat the processor - jell- fan. It takes some doing sometimes to hunt this down - so do not eliminate the power supply either - think about removing it and trying another if all of the above fails to fix the problem.
One last thing - if you have Windows 7 and didn't buy it retail - Windows 7 is shutting down because it is not a legit copy.
Best of it
Gary
Posted on May 05, 2010
  • Gary Rice
    Gary Rice May 09, 2010
    Try a fresh install of something - if it boots to the system attempt - then you know you have an operating system problem and not a hardware issue.
  • 3 Answers
If it's overheating, then u should try to put it in a cooler place. : )
Posted on May 15, 2010
Why does my Dell Inspiron 531 keep shutting down?
cpu maybe overheating, check all fans are working, maybe a fault in motherboard. There should also before an error report log on your operating system which might give you a clue. try putting your hard drive into another pc (as a slave drive) and scan it for viruses before putting it back into your pc as the master again.
Feb 14, 2014 | Dell (Inspiron 531) PC Desktop
Why does My Dell Inspiron 531 computer keep turning off
There are several possible causes for this. Laptops are notorious for dust buildup and overheat issues. Take compressed air and blast out the vent areas. If you can push enough air through the vent leading to the CPU cooling fan, that may clear out dust clogging the fan, preventing proper CPU cooling.
The next possible issue is a threat.
Boot into safe mode - keep repeatidly pressing F8 key as soon as you power on - until a menu comes up. Using keyboard up/down arrow, select "Safe Mode" (with networking if available).
Next, install Malwarebytes (free version) and perform a full scan. Also scan using your current antivirus.
hope this helps,
Danny
SYSTEM TRIES TO COME ON BUT ONLY MAKES IT TO THE CONFIGURING SCREEN THEN IT SHUTS ITSELF BACK DOWN, THIS IS CONTINUOUS. I have a Dell Inspiron 531. Please advise. Thank you, Candace
It sounds like it could be a problem with overheating, which is causing the machine to turn itself off. Try opening the side cover, and carefully cleaning the motherboard and especially the CPU fan - which is the large fan probably on top of a silver box with loads of fins on it. Carefully remove the dust, and see if this clears up the problem. It may be worth removing and refitting the memory whilst the computer is open, to reduce the problems of bad connections between the cards.
If it doesn't fix it, then reply here with any error messages that pop up on the screen.
Aug 04, 2011 | Dell Inspiron 531s Desktop Computer
My Dell Photo AIO Printer 924 only prints out my print request after I restart my Dell Inspiron 531 PC, which has a Vista operating system. How do I fix this?
u just need to uninstall and reinstall the drivers and even before that try shutting the printer down and taking power brick out for a while.. will solve it..
Dec 30, 2009 | Dell Office Equipment & Supplies
Overusage of computer HELP!!
yes hibernate is as good asd a shut down
u need to remember it is better to shut your comp down always when you are not using it
Jun 16, 2009 | Dell Inspiron 1521 Notebook
Computer is not starting up in standard windows mode. dell media keeps popping up and when i exit the program my pc shuts down. i tried ctrl and f8 it brings me to a short menu. (1) continue restart...
Are you running Window XP? Is your computer set to hibernate? If so, you may have a hibernation error...
If I understand correctly, while pressing F8 during bootup you received a message that states:
"System restart has been paused:
Continue with system restart.
Delete restoration data and proceed to system boot menu"
You may wish to read this article about the error. http://support.microsoft.com/kb/294427
Then, go ahead and do that second option. What hibernate does is write a big file to the HD with the exact state of Windows. That is a "restoration" file. If hibernate doesn't work, deleting the restoration file will often allow the computer to restart normally.
Good luck! Please post back with your results.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Mar 31, 2009 | Dell Inspiron 1420 Notebook
Dell shut down automaticly can someone help
Sounds like the laptop is shutting down as a safety feature from overheating. Look to see if the fan is running underneath the laptop/notebook. It's possible that the fan is defective. If not, are you blocking the vents? Make sure this is room for air to circulate.
If it's not the overheating issue, do you have the power management system software set to hibernate? Maybe it is shutting down at the time interval set.
Hope this helps.
Dec 24, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 531s Desktop Computer   Logo
1,319 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
