Question about Canon FAXPHONE L80 Laser
Activity Report Is there a way to go back and print a activity report from a certain day in January?
    Scholar:
  • 141 Answers
Http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=337&modelid=9986
fallow this link and download the file : L80_userGuide.pdf
On page 146 you will see how to get a activity report...But i think you can have only the latest 20 transactions...
Posted on Mar 26, 2008
SOURCE:
How to stop automatic "activity report" printing
in the menu section search for activity report and turn it off
Apr 18, 2016 | Canon PIXMA MX452 Wireless Office All In...
Printing an activity report
You should be able to get an activity report through the menu key. Push the menu key and scroll to reports Push ok/set key and scroll to actitvity report. Push set/ok key, one or the other, and an activity report should print out.
Jan 24, 2011 | Canon FAX-L1000 Plain Paper Laser
How to do an activity report
Set activity report ON, under report sett. under user mode (MENU), then the report is automatically printed after 20 TXs or RXs.
I think that there must be some kind of button with triangle with "eye", there must be counter, status, and if I recall activity report printout.
Hope that helped
Mar 15, 2010 | Canon L120 Fax Laser Printer
Can a sharp ux-p410 retrieve old sent faxes from its memory
No, your fax machine only records the fax number of the last 50 transactions
Oct 19, 2009 | Sharp Office Equipment & Supplies
I faxed something last week and lost the transmisson verification report, can it be re-printed? does my fax keep it in memory?
It's possible to print a Fax Activity report which would show both incoming and outgoing fax activity. To do this, do the following:
  1. Press Reports
  2. Use arrow keys < > to select 3. Fax Activity
  3. Press Set
If Fax Activity hasn't been set up, do the following:
Setting the Fax Activity Report Interval
You can set the machine to print activity reports at specific intervals (EVERY 50 FAXES, 6, 12, 24 hours, 2 or 7 days). If you set the interval to OFF, you can print the report by following the Steps in the next page.
  1. Press Menu, 2, 4, 2.
  2. Press or to choose an interval,
    and then press Set.
    (If you choose 7 days, the LCD prompts you to choose a day at which to begin
    the 7-day countdown.)
I hope this enables you to recover your transmission report. Please post back with any questions or just to rate the solution. Thank you very much.
Greg
Aug 11, 2009 | Brother IntelliFAX 4100 Laser Fax
How do I print an Activity Report for faxes sent on the Canon Pixma MX310?
Hi ...
The fax machine prints an activity report automatically after every 20 transactions. To print a report manually, follow these instructions:
1 . Press <FAX>, then press <Menu>.
2 . Use leftright.gif to select [PRNT REPORT/LIST], then press <OK>.
3. Use leftright.gif to select [ACTIVITY REPORT], then press <OK>. The ACTIVITY REPORT is printed.
Don't forget to vote if this helps ... Cheers :)
Aug 02, 2009 | Canon PIXMA MX300 All-in-One Printer
Cannon laser 3175 ,after copies it print activity report
yes you can go into additional fuctions button then go into reports and turn off error reporting and activity reporting, or its under communication settings
Jan 13, 2009 | Canon imageRUNNER C3200 Copier
Fax history
Depending on your model, You need to press the MENU button, or check if there is a REPORTS button. For either case, scroll through the display until you come to the PRINT REPORTS mode. It may be worded differently on your machine, but what you are looking for is the FAX ACTIVITY report. You can also get printouts of TRANSMISSON OR RECEIVE ACTIVITY, and also CALLER ID, iIf you encounter a command called PROTOCAL DUMP, this also is a printout of fax activity.. Whether your activity report goes back to july 2007 is unknown. Normally an activity report shows a certain number of activities per printout, say the last 50 fax operations. It is not based on a certain timefrane.
Jan 09, 2008 | HP 920 Plain Paper Fax
Report Printing
Seeing old already printed report is your only hope i'm afraid,
once activity report is printed the memory is reset to allow it to remember next lot of fax's for you.
Oct 25, 2007 | OKIFAX 5400 Plain Paper LED Fax
Print Report for Specific Date
I haven't found a way to print a TX report for a specific date. However there is a way to set the machine to generate an activity report at a certain time each day. Press "MENU" , 2-4-2, and you should be able to select the interval for your report by pressing the "OR" key (24 HOURS in this case). Hit "MENU" again and then enter the time you wish the report to print (24 hr format). "MENU", "STOP" and that should give you a report you can use each day.
Apr 23, 2007 | Brother IntelliFAX 2800 Laser Fax
Canon FAXPHONE L80 Laser Logo
160 people viewed this question
Clive
Clive
old marine
old marine
Ekse
