Question about NEC Replacment Lamp Projector Lamp for VT470&VT670 - 3000Hrs Eco/2000Hrs Std 180W [ VT75LP
Nec470 projector has no power - NEC Replacment Lamp Projector Lamp for VT470&VT670 - 3000Hrs Eco/2000Hrs Std 180W [ VT75LP
  • 382 Answers
Does the standby light come on when you plug it in?
Does it indicate that it is powering up? Any fan noise?
If so it has a burnt out bulb, failing that your power-supply board is shot.
Cheers,
Kevin
Posted on May 04, 2010
Why does my Dell 1510X Projector not shut off when I push the off button ?
This projector as with most high power projectors will have a cool down period for the lamp once the power button is pushed from on to off. For this model, the cool down period is 120 seconds after which the unit will fully power down. You can override this cool down period by pushing and holding the power button for 1 seconds. If you use this procedure though, you should not power up the projector again for at least 60 seconds to allow the internal temperatures to stabilize.
Feb 27, 2015 | Dell 1510X Projector Projector
My viewSonic PJD6241 Projector Model VS12476 DLP is not connected by power
1,is the power line is OK?
2,if the power line is ok, it means that the projector is defective
3,the mainboard or main power of the projector is defective?
Feb 09, 2014 | ViewSonic PJD6241 3D DLP Projector
Runco CL710 projector. Had power outage and projector won't turn on. Project was plugged into surge protector. Surge protector is working, green light is on. Checked all electrical breakers, they are...
The capacitors on the power supply need to be replaced. When you take apart the projector, and then remove the power supply (it's the section that the power cord goes to) and open it up. Look for the little can capacitors and see if any of them are bulging on top. That is the sign that they've blown. Replace the big ones (about 5) for about $5 in parts. Reassemble and test by turning it on. Search for YouTube video for this.
Aug 25, 2013 | Runco CL-410 Multimedia Projector
Projector posted error, "replace bulb" Projector
Your projector need replacement of lamp unit if you don't want yet you just reset the lamp counter
procedure:
Power on projector
press MENU key
Press right arrow key to select Option
Press down arrow key to select lamp Hours
Press and hold down the ENTER key 5 second (lamp hour counter show red)
press POWER button to turns off the projector
now you power on your projector and no error displaed and no itself turn off after 15 minutes
Apr 13, 2011 | Panasonic PT-L785U Multimedia Projector
This projector was given to me by a friend. The control buttons on the top of the projector do not seem to work. The projector seems to work fine otherwise. Any idea what the problem could be?
The projector was in security mode B which lock all of the projectors controls. I found the solution to this problem in an online manual for the projector. The solution is this button sequence: power-- enter-- power--enter-- power--- enter-- menu. This sequence unlocks the projector controls by resetting the security password.
Dec 17, 2009 | Sharp Notevision PG-M20X Multimedia...
Projector powers down and re starts over and over
the colorwheel, the ballast, or the power supply are not working properly.
Apr 16, 2009 | Eiki LC-XB20 Projector Multimedia...
PROJECTOR WILL NOT POWER ON
1-bad power cable 2-blown fuse 3-defective power supply.4-serious trouble in main board.
Mar 06, 2008 | Toshiba TDP-MT200 Multimedia Projector
Projector
Other than the usual stuff (power cord etc.), check that the lamp cover (not the lens cover) is securely covered. There's a safety mechanism preventing projectors from powering up if it isn't.
Jan 13, 2008 | Panasonic PT-AE700U Multimedia Projector
LCD shutting off automatically
Hi there
Check if your blowerfan that cools the lamp - sits in front of Projector is running.
Nov 06, 2007 | BenQ PB2140 Multimedia Projector
35 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
