Question about Pioneer VSX-108
Front display light out...no sound
The receiver was on when one of the speaker wires slipped into the top of my satellite box.....sound when out and display messed up
    Genius:
  • Pioneer Master
  • 1,550 Answers
Check the fuse feed,and the audio amplifier fuses two
Posted on May 04, 2010
Denon receiver not working surround output
If everything is connected correct, the only thing I can think of, is you don't put in a surround signal. If you only feed 2 way stereo, only two speaker will work. Also if you switch to stereo, the other channels will stop working. Check the cables, the settings and the input.
Jun 15, 2014 | Pioneer VSX-D511 Receiver
HTS9800W/12 and rear speakers
click this site:
http://www.avforums.com/forums/archive/index.php/t-378942.html
Jul 10, 2008 | Philips Cineos HTS9800W System
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
No sound
When you don't have sound on any television there are basic troubleshooting steps you perform before looking at it being a service issue.
First make sure mute has not been pressed on the remote. If you are connected to a cable box or satellite receiver you unplug it for 30 seconds to reboot it. You make sure the audio output settings on the cable box or satellite receiver are correct. Next you check your cables by changing them to see if they are the cause of the problem. If you have another cable box or satellite receiver in the house bring it over to the television and swap it out with the other one. If you have cable and not satellite bypass the cable box and connect the coaxial cable directly from the cable feed to the television and use your television's tuner. Before you do any of that you will want to check a VCR or DVD Player that is connected to a different input from the cable to see if you are getting sound on it then you will know whether or not the cable box or satellite receiver or the one input is at fault.
If there is no sound whatsoever you might have a pinched wire in the speakers or may need to replace them altogether. If you can get a service manual for the television online you can get the service menu instructions and try a reboot before going into the speakers to look for a pinched wire to see if that is all that needs to be done.
Feb 09, 2011 | Norcent Technologies PM-4203 42 in....
What's the proper way to wire 2 sets of speakers,
the center speaker is easy just wire it to the center main posts (connections are near the middle of the box) (just match up the colours)
and the powered speakers do they have their own amplifier or are they just speakers
if they have their own amplifiers then use the pre out connections near the top of the box
if they are just speakers then
wire them to the front main speaker connections near the right of the box
May 10, 2010 | Denon AVR-1700 Receiver
Rear speakers not working on STR-K740P
The only way your surround sound will work is if you have either the coaxial or fiber optic digital hookups attached to a PS3/Blueray/DVD/Cable box/Satellite box that have digital sound outputs. If you are just using the 1970's version of the red/white audio cables that is stero only.
Mar 02, 2008 | Sony STR-DE625
No display info on receiver
Try plugging a video monitor AKA your TV into that monitor output connector on the rear of the yamaha.
Select video in on the TV and see if anything shows up from the yamaha
Sounds though like the receiver has serious issues. If you can get your moeny back , do so
Feb 24, 2008 | Yamaha RX-V661 Receiver
Center speaker will not work
If you had the Speakers Set to A (not B) and no headphones connected when you pressed the TEST TONE button on the Onkyo HT-R540 (also known as the HTS-790) remote, and you had no sound from the Center Speaker then try the following steps. 1) Check the Center Speaker wiring at both ends under a bright light and make sure that there is not a strand of wire touching the Receiver Chassis or another speaker post. Check both + and - . If that looks okay, 2) unscrew the Center Speaker Post connections on the Receiver and verify that the bare stripped wire is making contact. Often, the insulation is too far into the connector. When screwed down, the wire's insulation is crushed and keeps the bare wire from making contact. If this looks okay and the unit is under Warranty, your last test is to: 3) temporarily swap the wires from the Center Speaker with the Right Front Speaker. Turn the volume down low and try the TEST TONE button again. If you now hear sound from the Center Speaker box itself and none from the Right Speaker box, then the Receiver is the problem. If you still do not hear sound from the Center Speaker box, then the Center speaker itself is defective.
Sep 25, 2007 | Televison & Video
Pioneer VSX-108 Logo
89 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
