Question about Cameras
Every time i insert my memory card it shuts off
  • 10,594 Answers
This kind of symptom shows that either memory card is defective or connector of memory card slot in camera got bad.
Check that memory card in another camera that use similar memory card and put another/ tested/ new memory card in your camera to narrow down problem cause.
If memory card found bad, new card will solve your issue.
and if camera has internal problem (memory card slot connector) then local camera repair shop will help you to get it fixed.
Hope this info will help you.
Thanks.
Posted on May 04, 2010
DC shuts off when memory card is inserted
reformat the card. the card is corrupted.
Mar 23, 2014 | Cameras
Screen blacks when i insert my memory card
Only insert and remove memory cards when the camera is shut down. Before you go on with this memory card, check in a PC with a cardreader if the memory card is ok. Onlty when you are sure it is working good, go on. Perhaps you have another memory card to test in your camera. Please switch it of and check if the battery (ies) having enough capacity.
Oct 31, 2013 | Canon PowerShot A495 Digital Camera
Camera still reads full and will not work when new memery card installed
I had the same problem. Your memory card likely has too much memory. I put in a 4G card and it would not take a photo. Every time the camera went off it said "Error - Card Full".
You have 2 options.
1.) You can remove the memory card and use the internal memory to take photos (it will only hold 20 pics) and transfer them onto the memory card by shutting the camera off, inserting the card, turning the camera on, wait for the menu to clear and then shutting the camera off again and removing the card. This does work, but you are limited in the number and quality of photos that you will get.
2.) Get a smaller capacity memory card. I went out and bought a 2G card. Funny thing is that the camera wouldn't even recognize it at first. When I turned the camera on a message saying "Please wait" kept flashing on the screen. I waited 10 minutes and just shut it off and pulled the card again. I took the card home and formatted it on my PC. When I put it in the camera the next time it worked fine. So to save you some trouble, buy a smaller card and FORMAT it on your computer before trying it in the camera. It will save you a headache. After all of that BS I finally got the stupid thing to work. It takes beautiful pics but I will not be buying another Cuddeback. My next trail cam will be a different brand for sure. Not worth the hassle IMO.
Sep 02, 2010 | Buck Cuddeback Expert Game Camera
My printer says insert memory card
Welcome to FixYa...
I assume the message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product.
  1. Locate the memory card slot on the front of the product that is compatible with the memory card to be printed from. Each type of memory card slot accepts only one type of memory card, and only one memory card can be inserted at a time.
  2. Insert the memory card into the appropriate memory card slot.
Some times you may be trying to print Some Data may be from Memory card , you Choose already-But actually your MMC not in/Not Properly in...Hope you find it.....Thanks for Contacting FixYa...
Jul 03, 2010 | HP Photosmart C6280 Printer
Every time i insert my memory card it shuys off
Hello. Not all memory cards will work with your camera. Check your manual to see which cards will work for you. If you find that the memory card is correct, or that it used to work, try a new memory card as yours may have gone bad. Once you eliminate the memory card as the culprit, if your camera is still shutting down, then the camera will have to go to the repair shop. Joe
May 04, 2010 | iSonic Cameras
No card message when card inserted
the contacts for the sd card side camera is dirty, or the it may be shut off in the setup menu
Aug 14, 2008 | Konica Minolta DiMAGE Z6 Digital Camera
Shut down
You may have damaged the memory card not the camera. Try the card in a card reader and also a different card in the camera.
Good luck
Apr 14, 2008 | Canon DC20 DVD Camcorder
Camera wont work when memory card is inserted
I suggest you try to use a different memory card. If it doesn't happen again then it's probably a bad memory card.
Mar 06, 2007 | HP Photosmart M417 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
