Question about Frigidaire FAM186R2A Thru-Wall/Window Air Conditioner
A/C stopped working, front panel had power. Front
A/C stopped working, front panel had power. Front panel then went blank - looked to have no power anywhere. Which electronic board is likely problem, or how to check the boards?
  • dwvercher May 04, 2010
    Main power is fine. There is a board where the power comes into the unit and undere that one is another set of components. Where should I begin checking or replacing? Should I replace the small board where the power comes in or check the componentsd under it?
  • 382 Answers
What make and model?
First check your mains power, these are notorious for blowing breakers. Once you confirmed you have power unplug for a min and replug to reset the electronics.
If that doesn't help there should be only one control board inside. Take the unit apart and start checking all components with a meter.
Cheers,
Kevin
Posted on May 04, 2010
Front panel went blank, was intermittent could get to come on if door was in certain position, but now completely blank.
If all is connected, check connections between P/J of the board for a broken wire with an multimeter. Check the Plug, and the Jack on the board for a broken contact.
Mar 30, 2016 | HP ENVY 120 Wireless e-All-In-One Printer
Why is my GE front load washer is non responsive. The control panel went blank. Not a power issue since the outet is good. Model GBVH5140HWW
It could still be a plug or wire problem but if not a power problem inside the machine or a printed circuit board or other internal failure. It will not be possible to diagnose the problem without a lot more inforamtion.
Sep 12, 2014 | Washing Machines
Home air condition thermostat is blank. My home's central air condition stopped working. So the first thing I did was check the thermostat and it was blank. I then went down to the basement and got the...
Put new batteries in the thermostat. Make sure that the switch that power the furnace is in the "on" position. Sometimes people mistake that switch for a light switch and turn it off.
May 23, 2014 | Heating & Cooling
The input function is not working and the t.v. is on but no picture. Blank screen. Was working last night just fine we tried to hook up Xbox and when the input button was pressed screen went blank. any...
Perform Reset From Front panel of Tv, wait until green light stops blinking, set is running self diagnostic. If that doesn't work, it could be something in the DMD Panel containing the Digital Micromirror Device
Oct 10, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
The buttons on the front stopped working, no display
It is still under warrantee if under a year. Contact your dealer who you bought it from-it should be repaired or replaced free of charge.
Oct 03, 2009 | Microwave Ovens
Jenn-Air JMC7000 Microwave Stopped working
take the trim off of the microwave and on the top of the oven on the right side all the way in the back there should be a reset button just like a surge protector.
Dec 01, 2008 | Ovens
LG WD-1290RD FRONT LOAD WASHER/DRYER chimes with blank front panel
Unplug the unit to reset the computer.  Wait 5 minutes.  If the problem still occurs, you will need to have the control board replaced.
May 18, 2008 | LG WM-2277HW Front Load Washer
HK AVR 225 front display not working
thats not good power transformers in it went bad do u have it on a nice power strip or direct to wall
Jan 19, 2008 | Harman Kardon AVR 225 Receiver
The display shows all the icons of the sytem and wont clear...
$38 part from Sears PartsDirect took about 30 mins to install.  Part # AH92-02673A Ay pcb-front.  There are actually 2 boards to this setup, I went ahead and replaced both but the power button side of the board has some wiring that requires you to remove the disc changer which is only 4 screws and 2 screws for the piece that holds the disc above the reader.
I couldn't find an easy way to get the knob off on the front it required me to force it, nothing borke but your replacing the board anyways..
Jan 09, 2008 | Samsung HT-X50 System
Frigidaire FAM186R2A Thru-Wall/Window Air Conditioner Logo
56 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
