Question about Frigidaire GLER341A Electric Dryer
Dryer repair when installing the bearing kit how is the silver ball secured in the white cup?
  • Frigidaire Master
  • 8,220 Answers
The ball gets bolted to the drum first. Then the white bearing gets installed on the back of the dryer. Then It all goes back together when you install the drum into the dryer.
Posted on May 04, 2010
Model fde336resi loose drum
There are 2 areas to check for this dryer drum. The back center bearing looks like a small trailer hitch ball which is attached to the drum. It fits into a plastic socket on the back wall of the dryer. To remove the drum, you need to take the dryer front off and disconnect the belt that goes around the drum. Then use the belt as a handle and yank up the back of the drum to lift the ball of the drum out of the socket. The plastic socket is what usually wears but you can get a complete kit including the ball and socket for about $20. While the drum is out, look at the inside edge of the drum opening. Should be a white plastic bearing strip completely around the opening.If cracked or missing replace those also. Should be 2 strips. Thats all that supports the drum in the front.
Mar 24, 2012 | Frigidaire Electric Dryer
Squeaking when dryer runs
Yes. Replace the rear bearing cup that the drum sits down into. Do not oil. This cup takes a special grease that you can get with the cup. Also don't let anyone try to sell you the whole bearing kit. All you need is the cup and the grease.
Feb 01, 2010 | Frigidaire Electric Dryer
My Tappan electric drier make a loud screeching sound like an axle with no grease. I can't figure out how to get the front panel off to locate the source. Model MDE336RES1
These are known for this. You will need to replace the rear drum bearing. Go to http://www.partselect.com/PartDetail.aspx?Inventory=459829&SourceCode=1 this is the part you will need. ($22.32 + shipping) It's located at the back of the drum. The round silver piece goes on the drum and the white plastic piece goes on the back panel of the dryer. (Notice the round silver ball. Make sure to not loose or forget to put it in when repairing) You get into this machine by going through the top and front. Not the rear. Good luck
Nov 16, 2009 | Dryers
Dryer make a squeeling noise when going, how do I fix and get the back off the dryer
Nothing could be easier to work on than these beautys. After unplugging the machine start by popping the top so you can get to the screws holding the front panel on. As pictured gently push the springclips in on each side about 2 or 3 inchs from each end to release the top: top%20removal.jpg Pop that top with a putty knife. After removing the 2 phillips screws holding the front to the frame (near the top on each side) and taking the wires loose from the door switch, lift the front panel out yer way.
Remove the rear hatch and take the idler loose. Then you can get the drum out. Grab the belt and yank upwards on the drum and remove it out the front.
INSPECTING THE DRYER Look for broken glides on the front panel: 5303937139.jpg?height=147&width=200 5303937139 glide kit $24 The rear drum has a big trailer ball type mount that holds it into place, over time the plastic bearing wears out and the support under it squeals, (it is telling you serious stuff is going to happen) The metal mount under the by now thin, failed, and gone bye-bye plastic bearing, will eat into the ball and cut it off causing the drum to fall into the heater element AND break the belt. YIKES! NOT GOOD! a%20frigidaire%20dryer%20bearing%20failure.jpg?height=150&width=200
Failed bearing with missing ball
The kit (5303281153) comes with everything you need to repair the bearing. It is about $25 bucks or less. With the drum removed and the bearing inspected you want to take a gander at the heating element. If the element is broken, there is no need to buy the whole pan for $100. You can get a restring kit for about $25. Just remember to evenly space the new wire so it will not burn out quickly. Remove all lint from the dryer and the drum. This is the main killer of a heater element. Lint on it causes a hot spot. gibsonfrig%20elec%20coil.jpg 5300622032 Restring kit $25 The fuse mounts on the rear wall of the dryer in the upper right hand corner. If it blows the dryer will not run. Clean out the vent and any lint in the dryer or the fuse will continue to blow. gibson%20rear%20wall.jpg 134120900 Fuse $12 The belt part # is 5303281154 $10 The Idler is part # 131863007 $12 For routing info see Belt routing above on anotha page my friend. LOL Or better yet how about the repair manual? Here is a newer repair manual. The innards of the dryer is the same as always but the newer models have a thermister and assorted goodies: ELECTROLUX REPAIR MANUAL
Oct 24, 2009 | Frigidaire FDE336RE Dryer
DRUM BEARING REPLACEMENT KIT Frigidaire GLER341AS2 Dryer
Hi. I don't work on many Frigidaire's, but that pesky ball bearing does not go into any of those grooves. It goes in the very back center of the cradle, sandwiched between the ball and a metal strip on the back side of the cradle. (It is suppose to drain off static electricity from the drum. If it gets lost, it's not a major loss) As for lube, just put a gob of the stuff that comes with the kit in the bottom of the cradle before reinstalling drum.
Feb 22, 2009 | Frigidaire GLER341A Electric Dryer
Squeaky dryer
The tub rides on a ball in the rear center. The ball sits in a plastic bearing with a metal mount. When the plastic wears down the bearing begins to rub the metal mount. WARNING: procrastination can cause this metal mount to eat into the ball and litterally cut it off causing the drum to fall into the heating element. To repair simply pop the top using a putty knife, remove the front and take the idler loose from a small hatch in the rear. Use the belt to help you get the drum out the front. NOTE. the kit comes with everything needed to make the repairs. If you are frugal the bearing it sold seperately. cd5464b.jpg
Dec 14, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Clothes get lodged between dryer barrel and dryer frame
you need a new rear bearing kit and a new top front felt yes this is something you cand yourself. Frist unplug the dryer, with a stiff putty knife releace the clips on each side of the top at front to pop open the top. next on the inside of the front cover on each side is a philips head screw remove both screws ( I find it easier to use a #2 square head for this ) now remove the front panell diconect the door switch.now reach under the dryer drum behind the motor and release the belt by removing the tention on the idler pulley and slipping the belt off the motor shaft (you may be able to do this better fromt the rear of the dryer. there is an access panell remove the two screws and you can see the belt and idler pulley ) now using the belt in one hand and the front of the drum in the other lift up on the rear of the drum ( you are lifting the bearing out of the scocket you will feel it pop out ) now slid the drum out of the cabnet. Now you can repace the bearing put a piece of duct tape over the clip on back center of the dryer ( on the outside ) now remove the two 5/16 screws holding the bearing cup on remove the tape from the clip put ne clip on tape in place set new steel ball in cup i put a dab of the greace supplyed in the kit to hold it in put cup on new bracket. set in place and put screws in you may have to reach around the back to line up the clip teghten screws snug. now in the center of the drum is the bearing on the inside are three philips head screws remove all three some timse you can use a #2 square headi lossen all the screws frist almost completly the remove them one at a time or you will have to hold the bearing with one hand to keep it from spinning. Putting the new bearing on you have to put the screw in one hole hold it with one hand and line the bearing up with the other or get some one to leand you a helping hand makes it alot easier.tighten all three screws good and tight now reinstall dryer drum besure to seat the bearing in the bearing cup again you will feel it pop in put the belt back around the drum. Now on the dryer front you will see the felt support the fron of the drum glides on pull it off just the top felt only with a putty knife clean off as much of the old felt as possable. Apply a genurious amount of the glue provided in the kit to the new felt i always put a good line of glue on the dryer front also press the new felt to the front (be sure if the new felt has plastic glides the overhang should be toward the front not the drum if the new felt does not have these glides you don't have to worrie) put dryer front back on when putting the drum back on the top felt you may need to hold the new felt to keep it from moving. reconect door switch put the two screws back in the front. now go back to the back and putthe belt back on the motor pull the idler to tighten the spring put belt around motor shaft and ease pulley back to belt. Put access cover back on and secure. close the top plug it and test don't let dryer run long just a few seconds I like to let the dryer set 24 hour befor putting back to use to give the glue time to set.
Nov 23, 2008 | Frigidaire FEQ332E Electric Dryer
Fridgidare dryer problem
Frigidaire dryers use a post and bearing support system. The noise you hear is the post grinding away on the support.00069740.jpg This is the kit to fix that dryer and a link to the kit
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1851&PPStack=1
It cost 24 bucks and ships overnight.
Now to fix it requires a phillip screw driver to undo all those screws, I would start with unplugging the unit, removing the two screws in back for the top panel, two screws for the bottom kick panel, located all the way down, hard to see so tilt unit back to access. Next is four screws at the front corners above the user panel and two inside at front left and right sides about nine inches down, now there are two more at the bottom of this door panel where you pulled the kick panel off. After this there is two wire harness clips, squeeze and pull they come off and gently pull at the top sides as there is retainer clips which secure the panel. Ok? Alright now you see the drum with belt attached, get a flashlight at memorize how the belt loops on the tensioner to the motor pulley and take a photo if needed:) Remove the belt and one more screw top middle in front holding a yellow bumper for the drum. The drum while come off by lifting the back of the drum firmly as it clips in place on the bearing support. Now pull the drum out and if I didnt warn you watch out for sharp edges. You will see the flange with shaft on the drum to replace and the bearing support on the back. The back portion screws together with two screws through a retainer to hold a small ball bearing in, I suggest getting a buddy to hold the back clip when replacing as it is a stretch. In the photo above you will see all the pieces on right go in this order metal clip, plastic cup, ball bearing onto panel and hold clip on back and insert two screws, with a buddy and some grease to hold the ball bearing this is the easy part. The flange has three screws and you must thread them with out stripping the heads off. A buddy again to share the moment is best to hold the drum while you insert the screws. The last part is putting a 1/2 tsp of grease in the plastic cup and following the instructions in reverse. Dont forget the wire harness as you reassemble or the belt looping on the tensioner.
Searstechtoo
Sep 13, 2008 | Frigidaire FGR341AC Electric Dryer
Dryer bearing
you need to oinstall the bearing little ball and bearing first then install the drum and belt the last thing is to rinstall the 3 screws inside the back of the drum to the bearing this is the easy way rather than tryingto get the bearing in the scoket while on the drum
May 14, 2008 | Frigidaire GLER341A Electric Dryer
REAR BEARINGS
YOU GO!!!! thetube of grease(lube) is going to be used after your done installing the plastic cup that holds the rear bearing, your gonna fill that plastic "cup" with the lube fill it to the top you wont need it for anmything else so use as much as youd like. and for the little ball bearing in the kit, that actually goes behind the "cup" ( youll see a little impression om the back of the cup to allow it to sit. adn is held in by the pressure of the rear mounted clip..I use a little dab of the lube on the ball bearning to hold it in place while securing it
hopefully this if a free standing dryer adn not part of alaundry unit. getting acess to thje rear of the unit will greatly ease the changing of the kit.youll see that as you remove the 2 5/16 screws hoolding hte old mounting braket in place , you nee to sorta staddle the mahine in order to hold the cup and reach the rear screrws at the same time., the only other tricky part is trying to screw th e3 screws holding the bearing post to the rear of drum, i have found that it is much easier to thread the screws into the plate, before trying to install for the first time, and oh yea if at all possible irs actually not a phillips #2 screw, that will work but might strip out a little, the correct size is a roberts bit #2(square bit)
Apr 07, 2008 | Refrigerators
Frigidaire GLER341A Electric Dryer Logo
81 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
