Question about LG 32LG30 32 in. LCD HDTV
My tv has no sound, fine in other respects...it was manufactured in 2008.
  • 10 more comments
  • goodrich_lyn May 04, 2010
    Nothing yet...more advice? Where in the menu does it show internal speakers?
    Nothing yet...
    It is LG 32LG30.
    Thanks, but I'm not having any luck getting sound on my tv yet.
    I'm not finding that pane with my menu...what am I doing wrong?
    The menu I get has:
    Search for Shows
    Manage Autotunes
    Caller ID
    TV Mail
    Parental Faves and Set Up
    (From Parental Faves and Set Up there are drop-down boxes to
    include Audio.)
    That menu looks like this:
    --Audio
    Language
    Sound Effects
    Dolby Digital
    It shows Dolby is on, for what that's worth....
    When I press Menu, nothing comes up looking like what you describe.
    It's hooked up to a DirectTV Receiver, replaced yesterday because we thought that was the source of the problem.
    The technician didin't have a clue beyond "issues with our tv."
    Found the correct menu, did the prompts, shows ON.
    No sound.
    No positive outcome yet.
    Like take the whole tv in?
    Thanks for your help and patience!
    Thanks for your patience...I learned a lot!
  • 10,594 Answers
Please check sound settings in menu and make sure internal speaker are On/ enable.
Do you get no sound in all inputs of tv, like dvd input etc?
Thanks.
Posted on May 04, 2010
  • 6 more comments
  • Shahid Electronics
    Shahid Electronics May 04, 2010
    Is it LG 32LG30 tv or any other model?
    Press Menu on remote.
    Select Audio and then select TV Speaker as shown in below image.
    Turn TV Speaker On.
    I was typing info for you and got rejected my assistance.
    OK, no problem.
    If tv is LG 32LG30 then its correct info.
    Audio menu would have TV Speaker On-Off option.
    Is this tv hooked with some receiver or amplifier?
    This tv has no option of Dolby sound etc, it is suppose to be in receiver that has surround speakers.
    No sound
    OK, still no sound that means sound output chip got fried in your tv main board and need to take in for fix. Contact local tv repair shop for an estimate of repair.
    Thanks.
    Yes, whole tv will go to repair shop for fix.
    I'm afraid, there is no way to fix hardware issues, no one can replace defective IC over internet.
I have a blu-ray disk/dvd player. I'm not connected to the internet. Can I play a DVD, yes however I have no sound. What am I doing wrong? TV is just an old regular one. Thank you, Julie Berriman
without knowing the brand and model of the cd-player and your tv, there is virtually not possible to answer your question.
what connection is between tv and player?
hdma? sound will be fine automatically, if no sound, check cable connection and select appropriate source on your tv, but if you have pix and no sound - we can safely assume that this is not...
coax? same remarks like for hdma
any other connection require more than single cable or special configuration... too many possibilities and you did not give a chance... no brand and no model...
i would suggest going to the tv and dvd player manufacturers site and check they respective owners manual
Jan 15, 2015 | Philips Televison & Video
I have a proscan model # 32LB30QD it was manufactured in 2008-10-11. I can watch picture just fine but audio only comes out trough the yellow red white chords. not directly from the tv itself. Sad that i...
Without getting too technical, it sounds like you may have an internal connection issue. Have you tried using external speakers with it? That might be ab easy fix.
Nov 28, 2013 | Proscan 32LB30QD 32 in. LCD TV
Sound distortion has developed while listening to a DVD or using Skype
Because I do not know your particular computer in detail, I will answer generically.
Because of the complexity of design where the interaction between software drivers and the hardware are very inter-dependent, it is difficult to determine the fault directly. I would suggest to uninstall the sound card drivers using the device properties manager, re-start the computer, and let it re-install them. If they do not auto install, then do it manually using the respective installation source location.
You can also try downloading the sound drivers directly from the Acer site and re-installing them, or from the respective sound card (chipset) manufacture to see if this fixes the fault.
I am assuming you tried listing to the sound using several headsets or external speakers to test it. I know of cases where a person was complaining about distorted sound from their computer. It turned out to be the speakers were defective and not the computer.
Jerry G.
May 11, 2012 | Acer Aspire 5735 Notebook
I got multiple thin colors on the middle of the screen
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display issue (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Further info, pics, comments, and updates on my Facebook page at
http://on.fb.me/mVwhVN
I already swapped out the TCON board with no improvement and replugged the TCON board cables with no improvement.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further updates will be on my Facebook page.
Aug 17, 2011 | Toshiba REGZA 52RV530U LCD TV
2/5 of the screen has vertical lines multi colors. Is this a fixable problem?
My 3-year old 52-inch Toshiba flat panel TV (Model # 52RV53U, Serial # AM409000295) developed a display problem (purchased Aug. 2008, manufactured July 2008). Vertical multicolored lines appeared on the screen just left of center. The band of thin vertical bars is 5.5 inches wide. The lines are about 1/16-inch wide. They are stationary, always exactly in same place. They over-ride any other picture on the screen (no transparency). They are there all time even with no video inputs to the TV after the unit is turned on. See picture #1. The TV works well in every other respect, but, obviously, it is annoying to watch the picture with the color band blocking about 1/6 of the picture.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further resolution updates will be on my Facebook page.
Jul 24, 2011 | Toshiba REGZA 52RV530U LCD TV
The screen has colored vertical lines and becomes to a dark black band about 6 inches of width.The tv is exactly two years old by today.
Most likely it is the flat panel tab bond failure (panel made by Samsung). Further solution updates will be on my Facebook page.
Apr 11, 2011 | Toshiba REGZA 52RV530U LCD TV
How to conect a PROSCAN MODEL 32LB30Q to a curtis DVD1098B
Buy an HDMI cable, plug one end to the Curtis DVD1098B's HDMI Output, and the other end plug into the TV's HDMI IN 1, or 2.
Using the remote control, and the assistance of the manufacturer's manual change the tv's input to HDMI 1, or 2 respectively.
Verify the input, and output of each device if you do not want to use HDMI, then using the same process connect the output of the DVD to the respective Input of the TV, i'm unsure of the TV's input but the television appears to support Component, RCA, and Coaxial.
Mar 01, 2011 | Computers & Internet
No sound is heard, nd cannot play games
install the driver of your vga and sound, download cpu-z to determine your product number and manufacturer then download the driver in their respective manufacturer, your computer also comes with a cd installer/driver.
Sep 27, 2010 | Computers & Internet
I purchased this hdtv new from Best Buy in February 2008. Last week a crackling sound began to develop and now the sound has gone completely, although the picture is fine.
Insignia T.V. 50" Model; NS-PDP50, Plasma T.V.
T.V. comes on, there is sound but no picture.
T.V. is les than 18 months old. We use the T.V. when we come to our Condo in Daytona Beach for vacation, so it hasn't been used very much.
Jan 10, 2010 | Insignia LCDTV26 26 in. Television
LG 32LG30 32 in. LCD HDTV Logo
54 people viewed this question
Computer Repairing
Computer Repairing
