Question about Sharp AR-168D Copier
Systen Error L1-00
Our copier will not copy - it gives us a message - System Error L1-00 - Refer to User Guide. We just had the copier worked on.
    Problem Solver:
  • 11 Answers
When [L1-00] appears, the scan head
locking switch is locked. Turn off the
power, release the scan head locking
switch, and turn the power back on.
If this don't work, turn off the power
and wait 10 seconds to reset.
Posted on Sep 04, 2009
    President:
  • 2,072 Answers
L1 means the lamp carriage movement is not being detected.
If the optics were cleaned, it is quite likely that one of the screws over the seal glass was put in the wrong hole. Or just slightly over tightened and is contacting the lamp causing it not to move.
Very easy to do.
The carriage could also be hitting the sensor, but, since you say it had just been serviced, I would say that carriage is hitting one of the screws. I have done that a few times. Normally it will do it when you are there. sometimes however, your unfortunate enoug to walk out the door before it catches.
Posted on Mar 26, 2008
  • Rick Kasper Mar 26, 2008
    Problem:
    L1:Indicates that the Main PWB sensed that the carriage did not leave home after power up or after start is pressed.
SOURCE:
I am using Sharp AR-M201 photo copier machine. I just came across a error message ` System Error F2-02 Refer to user guide' Can anyone guide me to solve this problem? Thanks K K Mendon
F2 -02 Toner supply failure
cause :-
- developer unit trouble
- Toner supply abnormality caused by
installation of unpacked toner cartridge
Dec 26, 2010 | Sharp AR-M205 Copier
Trying to copy something and this error 2200 pops up and states refer to user guide
Hi
This is a scanner lock issue. You may try the following:
Power off the All-In-One (AIO) off and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Try a test scan now. If the error reoccurs, then try the below:
Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover and check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid.
Open the top cover of the AIO and using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
If the error still occurs, you may insert the cartridges one at a time and re-check..
hope the above info is of use to you.. try out..!!
Apr 22, 2009 | Lexmark X7170 All-In-One InkJet Printer
MESSAGE: SYSTEM ERROR (H4-00) REFER TU USER GUIDE
We had this problem when the power was fluctuating in our building. I called Sharp and they told me to clear this condition with the following code: #*C* and when the screen shows 00-00 enter 14 and press the green copy buton. This worked on the AL-1655CS. On the AL-1631 we had to do a similar thing: C<auto>C<auto> 14 <copy>
Jun 06, 2008 | Sharp AL-1655CS Laser Printer
Having unable to clean error message
your dcp needs a new waist ink tank (absorber).
Search brother homepage of your country for a service dealer near your home and buy an ink absorber. post here again when done. will give you the instruction then.
Jan 08, 2008 | Brother DCP-110C All-In-One InkJet Printer
Cant get rid of blinking error message, nothing works
The [H4-00] system error popped up when the power went out of the house. I called Sharp tech support (1-630-378-3590) and was talking to their tech support in less than a minute.
The FIX? Just press the following keystrokes:
# * C * This will clear the display error, now press…14, then press the green button twice. This should let your printer start to warm up and you have fixed your problem.
Dec 20, 2007 | Office Equipment & Supplies
H4-00 is a fuser related service code. you need to get into the simulation programs and run sim 14 to reset the code. Make sure there is no paper jammed in the fuser. (The hot part on the right side inside the door)
Dec 02, 2007 | Sharp AL-1655CS Copier
Error message; no printing of text
What application were you trying to print from at the time. Does the printer give this error message all the time or only from this program? I need this info to assist you bzoe...lilacgerry
Aug 30, 2007 | Xerox WorkCentre M940 InkJet Printer
Sharp AR-168D Copier Logo
616 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
amir hamza
amir hamza
k24674
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
