Question about iSonic Cameras
Every time i insert my memory card it shuys off
  • 10,865 Answers
Hello. Not all memory cards will work with your camera. Check your manual to see which cards will work for you. If you find that the memory card is correct, or that it used to work, try a new memory card as yours may have gone bad. Once you eliminate the memory card as the culprit, if your camera is still shutting down, then the camera will have to go to the repair shop. Joe
Posted on May 04, 2010
How to solve the problem " please insert the disk into drive" of memory card
ok how did format get done? if not on computer then formatting needs to be done with card in computer and do a thorough format NOT quick format
May 26, 2012 | SanDisk 2GB microSD Memory Card
Hi - I am getting an error message when i switch on my Sony Cybershot dsc t9 saying access and then it flashes format error C13.01 - can you advise how to resolve?
It might be due to a bad contact of the placed memorycard.
1. Pull the memorycard out and in the camera several times and retry.
2. If not OK, format the card in the camera. If that does not work, format it in the computer.
3. Try another memorycard and recheck.
Sep 04, 2011 | Sony Cyber-shot DSC-T9 Digital Camera
When I turn my camera on it says internal memory is full and it really does not let me do anything. Oh this is a EasyShare C 813 What can I do and I pray I have not lost my pictures.
Have you insert a memory card in it ? If we don't insert the memory card, pictures that have been taken will automatically saved in camera internal memory, and this memory usually have low capacity so we won't make many pictures because the memory will full in no time. The solution is insert proper memory card (kind and capacity).
If you have insert the memory card the camera shows that notification, it means you need to transfer your pictures data in PC so you can delete them and make more space in your camera memory card.
Hope this help and RATE please !
Jan 17, 2011 | Cameras
My printer says insert memory card
Welcome to FixYa...
I assume the message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product.
  1. Locate the memory card slot on the front of the product that is compatible with the memory card to be printed from. Each type of memory card slot accepts only one type of memory card, and only one memory card can be inserted at a time.
  2. Insert the memory card into the appropriate memory card slot.
Some times you may be trying to print Some Data may be from Memory card , you Choose already-But actually your MMC not in/Not Properly in...Hope you find it.....Thanks for Contacting FixYa...
Jul 03, 2010 | HP Photosmart C6280 Printer
Memory card will not push in and stay engaged in memory card slot
This happens most of the time with digital camera and mobile phones, if you try to insert the memory card in a wrong direction. Before inserting your memory card, look into the slot hole and see the position of contact terminals and insert your card in such way that the card comes with contact with the terminals inside the slot. If your card already got struck into the slot, try removing it by pulling out using a small nose plier. Also try with another memory card of similar type to detect any problem due to your memory card. I hope this will help you out.
Aug 04, 2009 | Canon PowerShot A720 IS Digital Camera
My memory card won't work in my camerakeeps telling me to format the Lexar 2GB card every time I insert it
Use the camera to format the SD card not your computer. There should be a menu option to format it.
May 28, 2009 | Lexar Professional High-Speed 2GB Secure...
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital (SD)
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
Mar 18, 2009 | Lexmark X5495 All-in-One &USB...
I'm having a hard time inserting the memory card into my cell phones, any suggestions?
most cell phones use the mini sd. Try inserting the smallest one and if its asking fot the big one just put the small one into the big sd card and then insert the big sd card into the phone. What type of phone is it
Dec 08, 2008 | SanDisk 1GB microSD Memory Card
Cameras Logo
Top iSonic Cameras Experts
Jay Plesset
Tony Parsons
Tony Parsons
Are you an iSonic Camera Expert? Answer questions, earn points and help others
