Question about Toshiba TZ50V51 50" Rear Projection Television
65 S 500 HITACHI
Outer protective screen
  • Toshiba Master
  • 8,617 Answers
I would suggest contacting the local Tv repair shops in your area to see if one is available used, as many shops save the screen assembly when they disassemble a set that isnt worth repairing. It may be available through Hitachi, but doubtful. I have sources for screen assemblies but unfortunately not the 65 in screens.
Posted on Mar 26, 2008
How to remove screen protector from a hitachi 50ux52b
The entire screen comes off from the front.
Remove front speaker grill (should pull off)
Behind it at the bottom of the screen are a row of screws that secure the screen with frame to the cabinet.
the entire unit pulls out (bottom right and left first) and when free lifts up to pull off.
With the entire frame and screens off--you have to take the inner screens out first---careful to note which is facing forward and upwards---you can put them in backwards or upside down--will not work right.
Most of the Hitachi's the two inner screens are taped together along the edges but if not you have to be real CAREFUL- THE thin outer one is easily shattered or damaged.
You may have to take the frame apart to get the other (outer one) out as it is usually in a slot or track.
Screens have to go back in at exactly same direction and position as when you started.
The inner ones usually are held in place with strips of plastic or metal secured with screws--careful not to strip the holes out with a screw gun.
Clear one is (outer) only protective but does have an anti-glare coating so that can be an issue--picture will be brighter.
for questions or information press the "make a comment button" on this page.
Mar 25, 2012 | Hitachi Televison & Video
I need to replace the dust cover on my Hitachi 53SDX01B
the problem here is Hitachi usually if it still has it sells all three screens as a unit---expensive.
You may want to search with GOOGLE the internet as some companies sell replacement "protective" screen replacements.
I have even seen one time someone found a piece of plexi-glass and had it cut to the exact size and thickness for a replacement.
Mar 21, 2012 | Hitachi 53SDX01B 53" Rear Projection...
TV screen Repair
Good luck trying to find one used. This model was first produced and sold in 2006 and is one of the last projection sets Hitachi made.
Part number for the screen unit is: UX26082 and retails for 251.38 not counting shipping etc.
Replacement requires removing the entire front screen with the plastic frame it is mounted into.
It consists of three separate parts--outer or clear protective screen and the two inner ones and all three are only sold as a complete unit.
You have the part number and if you Google it may find some vendors on the internet who have it.
Let me know if I can be of help.
SD TECH
May 06, 2010 | Hitachi 57F59 57" HDTV
I need both panels of the screen for a Hitachi 55VS69A. I don't really want to pay that much if possible.
You can find a new OEM Hitachi replacement lenticular screen and Fresnal screen (availble together as the screen assembly) for a model # 55VS69A from a major Hitachi distributor at the following links:
Hitachi 55VS69A Replacement Part Screen Assembly (Fresnal Screen w/ Lenticular Screen)
And here's a link for the protection screen if needed:
Hitachi 55VS69A Replacement Part Protection Screen / Super Shield
Apr 22, 2009 | Hitachi 55VS69 55" Projection HDTV
Can I replace the screen on a hitachi 57f510 myself?
You can find a new OEM Hitachi replacement lenticular screen and Fresnal screen (availble together as the screen assembly) for a model # 57F510 from a major Hitachi distributor at the following links:
Hitachi 57F510 Replacement Part Screen Assembly (Fresnal Screen w/ Lenticular Screen)
Hitachi 57F510 Replacement Part Protection Screen / Super Shield
You should be able to replace it yourself with basic electrical knowledge.
Apr 13, 2009 | Hitachi 57F510 57" Rear Projection...
Need screen protecter
Here's a link to order the original Hitachi protective screen for this model (57F59A) from a major parts distributor:
Hitachi 57F59A Replacement Part Protective Screen / Ultra Shield
Mar 03, 2009 | Hitachi 57F510 57" Rear Projection...
My wife let the Wii remote and broke the front plexi-glass.
You can find a new Hitachi replacement protective screen and screen assembly for a model # 46F500 from a major Hitachi distributor at the following links:
Hitachi 46F500 Replacement Part Screen Assembly
Hitachi 46F500 Replacement Part Protective Screen / Ultra Shield
Feb 03, 2009 | Hitachi 46F500 46" Rear Projection...
My nephew threw a wii control and tore my screen..
they cost around 300 new, can order it off the hitachi web site, but i would look on craigs list and watch for someone getting rid of a 57 inch tv, and snag that one , use the screen off that, doesnt have to be same brand
Jan 07, 2009 | Hitachi 57F500 57" Rear Projection...
Help
Please check HERE for front screen of your Hitachi projection tv.
Oct 18, 2008 | Hitachi Televison & Video
57S715 Hitachi HD RPTV protective screen removal & cleaning help.
Research at www.HitachiServiceUSA.com ...........
Generally, front speaker grill cover comes off , then
screen frame assy. off , then take apart, remove protect
glare screen. Reassemble ( keep same order - position )....T.
Please rate solution to problem........
Aug 21, 2007 | Hitachi 57S715 57" Rear Projection HDTV
Toshiba TZ50V51 50" Rear Projection Television Logo
60 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
