Question about Whirlpool LGR5636L Gas Dryer
No heat Disconnected gas line to move f=dryer, have reconnected but now no heat.
    President:
  • 1,382 Answers
Hi, On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on May 05, 2010
Gas dryer wont stay lit
I'm assuming it "starts" to heat but then cuts off. Usually after the first minute of running you can open dryer door and feel heat but after awhile it doesn't heat.
1st, most common problem on a gas dryer not heating is "airflow" . They will "short-cycle" if there isn't near perfect airflow. Turn dryer on and go to outside exhaust vent. It should blow about as hard as you can blow into your hand. If any doubt disconnect dryer vent line from wall and let blow into your laundry room for one cycle and see if it is now working correctly. If it does work correctly when vent line is disconnected at wall you KNOW there is blockage somewhere in your vent line.
2nd, most common problem are gas coils. Easy to replace. 99% of all gas coils are the same so here is the part# (WE04X10020) (write it down.
Below is link where you can purchase appliance parts. Thanks for reading!
Appliance Parts
Feb 07, 2015 | Dryers
How do i replace the thermal fuse
Hello there
Unplug your dryer from its electrical outlet. make sure that all electricity has been disconnected from your dryer before moving on
turn off the gas valve that supplies gas to your dryer. Remove the gas flex line at the shut-off valve using an adjustable wrench.
Remove your dryer's back panel. take out the screws on the back of the dryer and the panel will come free. set the panel and screws aside until you are ready to replace them.
locate the thermal fuse between the dryer's blower housing and exhaust. the thermal fuse looks like a white plastic strip with two connected wires.
unplug the wires connected to the thermal fuse.
remove the screw that secures the thermal fuse to your dryer. set the screw aside and discard the broken thermal fuse.
replace the thermal fuse screw to attach the new replacement thermal fuse to your dryer.
reconnect the wires to the thermal fuse.
Mar 08, 2011 | Kenmore 77082 Gas Dryer
Gas line had to be disconnected to house last week for a gas leak repair. Everything is fixed and gas is back. Now gas dryer will not heat up. It runs fine, just no heat. Is there something I have to...
most gas dryers have what is called a ignitor on them that will glow when the unit is turned on and after they get red hot then a milivolt signal is sent back to the gas valve to open and fire up... i would check to see if the ignitor is glowing first... you will have to gain access to the bottom of unit in order to see this. you will have to remove front of dryer and most likely the tub,some of the newer maytags have a bracket that will hold the tub in place while working on it... before i did al this though it is possible there is still air in the line and will require bleeding the line at dryer... alot of people are afraid of gas but if common sense used you will be fine... you should have a gas stop at dryer gas supply line if not you need to install one. either way take a wrench and remove gas line at one of the closest connections to dryer and on purpose bleed a small amount of gas out.this will do 2 things (1) it will bleed any air in line going toward dryer and (2) confirm you still have gas pressure and gas going to dryer after your disconnection last week nothing happened to line.then reconnect and try again. if you ran dryer for an extended time it would eventually bleed the line also. not sure how long you ran it,but this will prove you still have gas at dryer . if after that no cure check the ignitor on unit to see if it is working if it is and no flame the gas regulator may be faulty after the disconnection last week/.... good luck to you
Feb 10, 2011 | Kenmore Dryers
I have an Kenmore gas dryer model 110.87174100 which was disconnected temporarily. Now it is reconnected to the gas line. How is it ignited?
this unit, and most dryers nowadays, uses an ignitor.  it is an electronic glowbar that will ignite the gas.  nothing to light just, if the gas connection is good and you are sure of no leaks, go ahead and start drying...
Aug 06, 2010 | Kenmore Dryers
Whirlpool gas dryer
check new gas line for foreign objects
May 06, 2009 | Whirlpool LGR5634L Gas Dryer
I just moved and my LG dryer does not heat up.
Your ignitor (glow bar) got broken during the move. They are more fragile than your grandmother's fine china
Dec 16, 2008 | LG DLG9588 Dryer
Dryer not heating
If you jarred it , you probably broke the ignitor I can help you with this and help you get the parts
Dec 14, 2008 | Roper RGX4634KQ Gas Dryer
Dryer stpped working
with power disconnected
if any wire disconnected before any test, reconnect & test dryer, reconnect wires after each test
disconnect wires from start button and test, conduct when pushed, no conduct when release
if fail replace start button test dryer
disconnect wires from door switch and test, conduct when pushed, no conduct when release
if fail replace door switch test dryer
follow leads from start button to relay(relay is first device connected to start button), and make sure all wires connected at both ends. If any wires disconnected, test dryer
locate thermostats and thermal fuses on fan housing and ducts
individually disconnect wires from each and test. conduct good, no conduct fail
replace any failed thermal fuse or thermostat test dryer
if all prior test OK
replace relay, test dryer
Oct 10, 2008 | Magic Chef CYE4000AWW Electric Dryer
Whirlpool Gas Dryer
you will need to let it cycle a few times in order to bleed the air out of the gas line to the valve it should start up after a few attempts let me know
Jun 09, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LGR5636L Gas Dryer Logo
75 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
