Question about Tefal FR4008002 Pro Fry Deep Fryer
Whats the easist way to remove grease when cleaning
  • 21 Answers
Hot soapy water to start. Anything left after that I recommend Tough Stuff. It's sold at the auto parts store and comes in a yellow spray can. Be sure to follow the instructions spray and wait 40 seconds then wipe.
Posted on Jul 29, 2010
Replace oil pan gasket
really ? this is one of the easist jobs you can do on this car....drain the oil , remove the oil pan bolts, replace the gasket, clean the pan and the block of all debrie, hand tighten the pan bolts, and dont forget to put the oil back in, this is always a good time to do an oil change service.
Nov 27, 2012 | 1996 Volkswagen Jetta
MY OVEN HAS GREASE SPILLAGE IN THE BOTTOM. I WAS BAKING AND IT STARTED TO SMOKE. I want to remove the grease first before I start the self cleaning. What should I use to best remove the grease without...
best way to loosen grease in the oven area is to place an oven safe pan with some water in it and run the oven at 200 degrees for thirty minutes. This help in the removal grease without using anything but water.
Dec 17, 2010 | Thermador PRDS366US Dual Fuel (Electric...
How do i service the grease trap without calling a service man to do it?
Be clear that an in-ground grease interceptor cannot be cleaned without a grease trap pumping company. We are referring to a metal grease trap that sits under the 3-compartment sink. Yes it can be cleaned by anyone (crazy enough). I still suggest a professional service company perform the task. I have full directions or instructions now at www.greasetrap.ca/grease-trap-cleaning.htm . Old clothes and a mask are a must.
Grease Trap Cleaning
Sep 20, 2010 | Dishwashers
How to set it to high, med or low
Grease filters can be cleaned, according to your manual.
If you've misplaced yours, it's online here.
Charcoal filters cannot be cleaned and must be repaired.
From the manual:
Reusable Grease Filters
The reusable grease filters should be cleaned at
least once a month. Never operate the
microwave without the filters in place. In
situations where flaming might occur on
surfaces below the hood, filters will stop the
entry of flames into the unit.
To Remove Grease Filter
To remove grease filter, grasp the “finger hold”
on the filter and slide to the rear. Then pull filter
downward and to the front. The filter will drop
out.
To clean Grease Filter
To clean grease filters, soak and then agitate
filter in solution of hot water and detergent. Do
not use ammonia or ammonia products because
they will darken the metal. Light brushing can
be used to remove embedded dirt. Rinse, shake
and remove moisture before replacing.
To Replace Grease Filter
To replace grease filter, slide the filter in the
frame slot on the back of the opening. Pull filter
upward and to the front to lock into place.
May 27, 2010 | Microwave Ovens
Yearly maintenance
Great bike...
I race hare scrambles, and they are tough on a bike, this is what I do yearly, sometimes two to three times.
Completely disassemble swing arm and clean and re-grease.
Same with the steering head bearings.
I remove all wheel bearings, clean and re-grease.
(I remove the outer seal of the bearings and pump in fresh grease, re-install the seal)
Disassemble, clean the brake levers, throttle assembly, and clutch lever.
(Basically everything on the bike that pivots)
I refresh fork oil and shock oil and nitrogen yearly if raced.
You can freshen up the top end of the engine, unless you are happy with the performance.
Dec 03, 2009 | 2003 kawasaki KDX 220 R
Need oil/grease for Hobart 20 qt. mixer
Hi. Your A200 is in need of service. The grease's lifespan has expired. There are two ways of doing this. First, the expensive way. Call for a Hobart Tech to come and service the mixer. This will take about 4-5hrs to service at a rate around $100.00usd per hour, plus the cost of parts. He/she will need to change all seals, remove old grease and oil, check all bearings and gears for excessive wear and replace as necessary, this includes the planetary gear.
Now for the affordable solution. Unplug the mixer, remove the top cover. Gently use a small screwdriver to pry off the two circular metal dust caps found on the transmission housing, use a good flashlight to determine, through these openings, the quality, quantity and condition of the grease inside the transmission case. If there's a lot of oil you can remove much of it a bit at a time by using a wire coat hanger to which you can attach bits of cloth to absorb as much oil as you can. Once oil is removed, add new grease through these same holes until full (Chevron FM ALC EP-2, food grade lube). Run the mixer for a couple of minutes to distribute the new grease. Fill to the top once again and replace dust covers. Remove planetary, clean, inspect change seal and re-grease.
OPTION (mechanically challenging) You can do a more thorough job by removing the trans. cover completely, removing the 3 gear shafts inspect all bearings and gears, change seals on mainshaft and planetary. Remove old grease and oil, clean gearshafts and gears. Parts drawings are available from www.hobartservice.com It's free to register and then locate your parts drawings. Be sure that you have the correct files for your Model #, ML# if there is one and Spec.#, all found on the info plate.
When disassembling, take a digital photo of every step and lay the removed components on a piece of cardboard in the removed sequence. These practices will become valuable during re-assembly.
If this solution has assisted you, please rate it. ricardok45
Mar 19, 2009 | Hobart HL200C Mixer
Have lost some oil out of it in moving, what oil
Hi. The oil you see used to be mixed into the grease base. It's time to change the grease in your mixer. Remove the silver band, Remove the top cover. Remove the transmission cover. Clean out the transmission, remove all grease and oil. Replace with Chevron FM ALC EP-2 grease. This grease is an edible food grade..
Remove the planetary gear, clean and re-grease. If this solution has assisted you, please rate it. ricardok45
Mar 15, 2009 | KitchenAid Food Mixers
Diff Removal
take gearbox and transfer box out and take d sub frame out,i took mine out the other day 3 and half hours had them out
Sep 03, 2008 | 2005 Mitsubishi Lancer Evolution
Tefal FR4008002 Pro Fry Deep Fryer Logo
145 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
