I HAVE INSTALLED THE WIRELESS-G PCI ADAPTER THAT CONNECTS TO THE WRT54G ROUTER. I HAVE CONNECTED MY COMPUTER AND EVERYTHING SAYS THAT NOW MY COMPUTER IS WIRELESS. WHEN I GO WIRELESS I GET THE MESSAGE THAT IT CANNOT FIND THE ROUTER. WHAT AM I DOING WRONG
    Genius:
  • 1,027 Answers
Once everything is attached you have to reboot everything so your router can assign IP addresses.
If your wireless pciG has a static IP address that is not in the proper range e.g. (if the router is 192.168.0.1 and your desktop is 192.168.15.1 then you can not log into the router, the router has to assign IP addresses in its range of 0.2-0.50)
If your IP address is assigned dynamically, then everything has to be re-booted so the router can assign the address in it's range.
Posted on Mar 26, 2008
SOURCE:
Dell optiplex GX620 desktop has an ethernet port on it, that is not an adapter, I cannot connect to the internet, I downloaded and installed a driver for a wireless ethernet adapter, but that has not...
Okay,..........
1) You can download a wireless Ethernet adapter driver all day, but if you Do Not have a wireless adapter card installed in your computer, the drivers do you no good.
Or if you do not have a wireless USB adapter plugged into a USB port.
Example of a wireless adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4695358&CatId=2692
Example of a wireless USB device,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6367137&CatId=2692
Example of an Ethernet adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=686143&CatId=200
If you are just going to hardwire the computer, just buy an Ethernet adapter card, (PCI version), and install it in your computer, (On the motherboard), in any available white PCI slot.
IF it is the Mini Tower model.
The Desktop, Small Form Factor (SFF), and Ultra Small Form Factor (SFF) computers, are too small in width for a regular size Ethernet adapter card.
They need a Low-Profile Ethernet adapter card,
http://www.newegg.com/Product/Product.aspx?Item=N82E16833114034
This is for a Dell Optiplex GX620 Mini-Tower computer,
http://support.dell.com/support/edocs/systems/opgx620/en/ug/A02/mtabout0.htm#wp1051997
Scroll the page down until you come to the bold blue heading - System Board Components
This is an illustration of a Top view of the Mini-Tower's motherboard.
16 and 17 point to two PCI slots.
This is where an Ethernet adapter card that is the PCI version, will plug into.
PCI slots are White in color.
An example of a basic PCI slot, ( 3 are shown),
http://en.wikipedia.org/wiki/File:PCI_Slots_Digon3.JPG
If you do decide to go wireless;
1) Wireless networking operates at half of the speed of wired networking.
A computer that is wired directly to an Ethernet adapter card, is twice as fast on the internet, as a computer that is connected wireless.
2) Make sure your Router is capable of wireless.
Make sure the wireless router has a built-in Modem, or that you have a separate Modem.
[ For DSL.
Phone line connects to Filter. Filter has a place for a telephone cable, and an Ethernet cable.
Ethernet cable connects to Filter, and other end connects to Modem.
Ethernet cable goes from Modem to Wireless router that does not have a built-in Modem.
OR,
Phone line connects to Filter. Ethernet cable from Filter goes directly to wireless router, that has a built-in Modem.
Computer has to have a USB wireless device, or a wireless adapter card, installed.
For additional questions, or to clarify anything I have stated, please post in a Comment.
(Believe upper right of your page, blue Comment)
Regards,
joecoolvette
Sep 16, 2011 | Dell OptiPlex GX620 PC Desktop
Cannot get internet connection
You probably have to buy a wireless card and and install it in your computer...there wasn't much in the way of home wireless back in 2002.
Go to your device manager and look at the network adapters and see if you have a wireless adapter installed on your system. If not, you will have to put a wireless pci card in and install it and then you will be able to configure your computer to connect to your router with a wireless connection.
Mar 28, 2009 | Microsoft Windows XP Professional With...
Cannot associate with access point
trying updating the firmware of the wireless router...go to this link and just search for the version and download the latest version of your linksys router and then upgrade the firmware...
it shud work.........also try changing the channel number as well.......
http://www.linksysbycisco.com/US/en/support/WRT54G/download
vedhick
Feb 10, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
WRT54G
No. The same adapter should work. If it is USB try moving it to a different USB port. If it is internal then try reinstalling the CD that came with it.
Jan 24, 2009 | Linksys Wireless-G WRT54G Router
Cannot connect to WRT54g
think you have to connect a cable to the ethernet adapter of your desktop in order for you to connect to the wrt54g. uless you have a wireless lan on your desktop. also check your channels. and manually config your router through 192.168.1.1.......
Aug 31, 2008 | Linksys (WIFIDESKTOP) Wireless Adapter
Home networking.
do you have a pci network adapter intalled with the proper drivers ? did you plug in ethernet cable directly into current pci lan card it will be located on lower part of back of computer? this will eliminate the problems with the router just to see if pci lancard is working or not . if the lan card is working unplug cable and plug in router and then try with router plugged in u might need to reset the router in order for it to work with lan card . if ur using and onboard lan eg attached to the motherboard then you must go into computer bios and enable onboard lan and then the ethernet cable should work with no problem good luck i hope this helps you get up and going getback to me if there are future problems.
Jul 01, 2008 | Linksys Wireless-G WRT54G Router
My lap top connecting to my wireless system.
Your computer is not yet connected to the wireless network of the router. Also, make sure that your wireless computer has a wireless adapter installed on it. You may verify it on the Device Manager. If you're using a laptop with built in wireless adapter , make sure that the switch for the wireless connection is on so that it will detect the signal of the router.
Try configuring or verifying the wireless settings of the router first by following the steps on this link:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4585&p_created=1165894972&p_sid=RY2yXS3j&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTAwNiZwX3Byb2RzPTAmcF9jYXRzPTE3MjEsMTcyMyZwX3B2PSZwX2N2PTIuMTcyMyZwX3NjZl9sYW5nPTEmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD13aXJlbGVzcyBzZWN1cml0eQ**&p_li=&p_topview=1
After configuring or verifying the wireless settings of the router, connect your wireless computer by following the steps on this link:
http://linksys.custhelp.com/cgi-bin/linksys.cfg/php/enduser/std_adp.php?p_faqid=4055&p_created=1160185039&p_sid=RY2yXS3j&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTAyNSZwX3Byb2RzPTAmcF9jYXRzPTE3MjEsMTcyMyZwX3B2PSZwX2N2PTIuMTcyMyZwX3NjZl9sYW5nPTEmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1jb25uZWN0aW5n&p_li=&p_topview=1
If you cannot still connect wirelessly, let me know of the following:
- model number of the router
- operating system of the computer
- wireless adapter installed on the computer (built in or external)
- brand of wireless adapter installed
- wireless settings of the router (SSID, wireless security)
May 13, 2008 | Linksys Wireless-G WRT54G Router
I have an HP computer (Vista Home Premium Software) and Linksys wireless-G Broadband Router (WRT54G) installed and working. Problem--Trying to makea working wireless connection with a 2nd computer. An...
check that you have all updates for your linksys and cable modem and the new adapter you bought since your pc is old..
if that doesn't help then try the following:
i would shut down pc, uplug router power, turn off the cable modem and give it all at least 10-20 secs.. plug the other pc in the router then start up cable modem and router.. after that, then turn your pc on and see if it recognizes...
is the adapter for a desktop to make wireless of a laptop, just curious..
Feb 21, 2008 | Computers & Internet
Open Questions:
Computers & Internet Logo
75 people viewed this question
Ekse
Alun Cox
