Question about LG 47LH55 47 in. LCD HDTV
Ghosting I have the LG 47LH5000 when first installed picture quality was fantastic now there appears to be ghosting. Curry's support talked me through factory reset but this has not solved problem, can you help?
  • jm_williams1 May 05, 2010
    Thanks for this although there is no Auto Focus option in the set up menu. Using SKY+ HD does this make a difference?
  • 111 Answers
A lot of these set have auto focus which may just need to be run through the menu or setup on the remote. Are you using a cable box or antenna? this can make a difference as well.
Posted on May 04, 2010
LG 47LH5000
set-up codes to LG are: 1275 1439 1052 1203 1288 1476 1225 1231 1012. If you wish to get more, try the sites linked here. http://electrohelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Mosaic / Timeslide option. Try this link too. http://electronicshelponline.blogspot.com/
Jul 26, 2013 | Televison & Video
Ghost / Overlapping Image
ok you have defective convergence crrection circuit! or maybe the RF Box is defective! can you describe the color of the ghost?
Oct 12, 2007 | Samsung HCN4226W 42" Rear Projection...
When I connectlaptop with a vga cable I get ghosting It gets better when I use a shorter 6'cable But the room has a 50' cable installed. I did try a new 50' cable and it did not help
long cables should be of perfect quality with low electric capicitance.
otherise echoes will occure and shadows in picture.
Try a good quality IP- converter set i.e. from EXTRON
You used a shorter cable with better results, so don't look for a cause inside the projector. Picture quality stands with cables !!
There is a lot of cheap rubbish in the market.....
Nov 19, 2009 | Eiki LC-XG110 Multimedia Projector
Red and blue ghosting,
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 12, 2009 | LG RU-52SZ51D 52" Rear Projection...
Ghosting problems with a Samsung-LN32B360
I think your cable box is old version together with weak signal caused this problem. I guess you are using coaxial cable hooked up to the TV at TV cable input jack.
At the TV there are some better quality inputs which are real digital transmission (audio and video) HDMI and components (digital video and analog audio).
The most simple and best quality is HDMI provided the box has HDMI output.
Secondly is component inputs. There are 5 cable trends in which 3 of them (red, blue, green) for video and the rest 2 are for audio (red , white). The cable box should have same color accordingly as ouput. Please note that the color must be matched otherwise you will see the screen has one color only.
Playing a DVD player to see picture good or not. If picture is good, TV has no problem at all.
May 25, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Un-Clear picture
what types is it
Jun 06, 2008 | LG 42PC5D Television
Ghosting
hi there, see the micro switches, do some test and look for some cold solder at the board of the unit. ty
Jan 01, 2008 | Televison & Video
HV-175 LCD
Picture quality problems (such as lines, fuzzy image, or wrong colors)
  1. Check the cables and connections: Make sure that cable connections are securely fastened to the connectors and try reaseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degredation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
  2. Check the  display issue with  a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal. For example: if the image quality issues occur while viewing TV , switch the source to a DVD player to see if the image quality problems go away. If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and . If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem. NOTE: Higher resolution TVs will make it much easier to view signal problems coming from source signals - especially TV signals. For example, if your TV cable company experiences heavy load on their system, you may be able to detect small miscolored squares that briefly scatter across the screen (macro-blocking). On a smaller standard TV, this type of quality problem is much less noticeable on a standard TV, but can become very annoying when viewed with greater detail.
  4. Try to Reset the TV ( LCD) quality options. Please look in to User Guide to make the TV to factory Defaults..
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV . If the image quality problems still exists across all types of signal sources, the TV should be serviced.
I hope that this should resolve the issue. However, if the issue still persists then please contact LCD manufacturer for further more on the issue.
Bye.
Oct 17, 2007 | Proview HV-177 17 in. HD-Ready LCD...
LG 47LH55 47 in. LCD HDTV Logo
201 people viewed this question
Computer Repairing
Computer Repairing
