Question about HP Business Notebook 550
Can not enable wireless
We can not enable wireless on our lap top. It worked fine for months , now it just tells us its inabled.
  • HP Master
  • 1,606 Answers
Usually if there is a problem with the hardware it shows up wth a differant error. Usually disabled means it is switched off or you have the cable plugged in.
On a laptop we have the often annoying option of switching the wireless off to save the battery. On your model the off/on switch or button is located just above the keyboard. There should be three buttons near the bottom of the screen. The left most button is the one we want. Just push it and your wifi should start if this is how it was turned off.
If it doesn't then we may need to check the network connections window. can not enable wireless - moz-screenshot.png Here we can make sure it is enabled. Unplug the cable connection if its plugged in. Some drivers will auto switch to the faster speed ie the cable while others go to the wireless. Unplugging it forces it to try the wireless.
Click on start then look for something called network connection along the right side. If it is there then click on it and it will bring up a window called network connections. You may have to go to settings then control panel and network connections which is the other way of getting here.
This should show 3 things. A cable connection ie something like Broadcom 10/100, your wireless connection called something like Athero's and usually something called 1394 which is Firewire. Right click on the wireless one and if it says ENABLE click that and your wireless should startup.
Posted on May 04, 2010
Lap top will not conect to the wireless internet connection
If you are on a laptop: (windows)
1. check to make sure your physical on off switch for the wireless card is turned on. Windows will sometimes still show it as being active while the switch is physically still off.
2. Disable/re inable the software connection to the wi fi
(MAC) Disable reinable the wireless card in dropdown menu
3. restart the wi fi router
Jan 16, 2011 | WiFlyer - Portable, shareable WiFi base...
Acquiring network address
all that you need to do is to delete the preferred networks list from the computer,
and try to scan and connect to the network again....make sure that you are typing the correct security key.
still if the problem exixts, then add the network manually...the problem will get off for sure....
also if there is any facility like wi-fi protected security is enabled in the wireless router, go ahead and disable it...
Apr 03, 2010 | Linksys WRT54G2 Wireless Router
No Internet via zoom X6 wireless router to desk top, lap top ok.
Access your zoom router by using the laptop which still has access to the router.
Your going to have to open your Wireless Network Connection Status window located under your network settings.
If you see this window your going to left click the (details) button
Now you should see a IP DNS server address
for example: 192.168.1.xxx
Type that address onto the address bar of your web browser.
it should take you to your router setup page.
There you will need to check if the lan port is enabled
Feb 04, 2010 | Zoom X6 Adsl Modem/router Rohs...
Have 2 lap tops,1 desk top. Desk top and 1 lap
For the 2nd laptop, first upgrade the LAN card driver, then reinstall the driver if the problem is not resolved with the driver upgrade.
Hope this helps.
Aug 29, 2009 | D-Link 802.11g Wireless Router WBR-1310...
My wireles not detect by my lap top
Common problem with motherboard. Needs service.
Jan 16, 2009 | HP Compaq nr3610 Rugged (PN686AW) PC...
My lap top won't detect wireless
Make sure that the program used to monitor your wireless card doesn't have a virus, or with windows, either you have to let windows enable your wireless or you have to use the program.. if you have both trying that could be the problem.
Any further questions tiffani.ross@gmail.com
Jan 16, 2009 | Microsoft Windows Vista Home Premium with...
Cannot install D-Link router
You may try typing admin on the username field. Just leave the password field empty.
Once you're in the setup page, click on WIRELESS tab which on the left side of the page. On the Wireless page, you will see the wireless settings set in the router. You may also enable the wireless security on that page if there is not security enabled yet.
Please check this for your reference http://support.dlink.com/Emulators/di524/h_wireless.html
Hope this helps!
Nov 12, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Wireless connection to lap top
try opening network connections disable the default connection and enable linksystems
Jul 13, 2008 | Linksys Wireless-G WRT54G Router
Wireless router keeps loosing connection
go to wireless device and re-configure it
Jun 14, 2008 | Dell Wireless 2350 Router
HP Business Notebook 550 Logo
74 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
