Question about Samsung DV448AGE Gas Dryer
Gas Dryer wont get hot enough
We recently put in a gas dryer. It seemed that it was drying or a week or 2. Now it takes about 4-5 times to get the clothes dry. They are barely warm when we check on them. What should we do?
  • Samsung Master
  • 43,501 Answers
Here is a tip about dryers that don't heat right and somethings you can do and check...
Dryer Maintenance
http://www.fixya.com/support/r4312805-dryer_maintenance
heatman101
Posted on May 06, 2010
It dries great and doesn't continue to run, however, on/off light still stays on even after it's done.
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
Jan 25, 2016 | Amana NED7200TW Electric Dryer
Have samsong front loader dryer running for short periods of time and it is shutdown and will not start for short periods of time
Bad motor windings
Thermal Fuse
Air Flow and Heat
Warning
Jan 19, 2016 | Dryers
Why wont my gas dryer get hot?
Thermal Fuse
Air Flow and Heat
Warning
Aug 12, 2014 | Kenmore Dryers
Kenmore Elite HE4 Gas Dryer Shuts off prematurely in the Auto Dry cycle and the Timed dry cycle
Thermal Fuse
Air Flow and Heat
Warning
Jul 19, 2014 | Kenmore Dryers
My dryer seems like it takes a long time to dry it gets hot but not hot enough
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 30, 2011 | Dryers
Dryer gets hot close wont dry cleaned vent as well
how long is the vent run,anything over 15 feet will slow drying process
Mar 18, 2010 | Maytag Neptune MDG5500AW Gas Dryer
There is no heat when dryer is on
you need chek :
if your apliance is gas dryer:
1-thermal fuse.
2-sensor flame.
3-ignitor.
4-gas valve.
if is electric dryer:
1-thermal fuse.
2-heater element.
Oct 05, 2009 | Dryers
I have a Whirlpool gold Ultimate Care II gas dryer and 2/3 times the ignitor glows and lights the gas, 1/3 times it won't. When the gas does light, it doesn't seem like it's getting hot enough to do...
I would suggest the coils on the gas valve . Also check the vent to make sure good air flow is getting out of the dryer . Try disconnecting the vent hose and drying a load to determine if maybe the vent is the problem .
Jul 14, 2009 | Whirlpool LGB6300 Gas Dryer
Maytag LDE412 Dryer
the vent that takes the air from the dryer out of the house is clogged. not the part right behind the dryer but from where it goes into the wall to where it leaves the house needs to be cleaned. when the air cant leave the dryer at normal speed it takes for ever to dry a load of clothes
Nov 26, 2007 | Maytag MDG7600AW Gas Dryer
Clothes dryer not getting hot enough to dry in a good time frame
I have the same issue with my DLG3788W dryer. It seem to have only one setting for heat, rather than multiple heat settings. What can I do or do I have to call someone to repair this.
Oct 03, 2007 | LG DLE0332 Gas Dryer
Samsung DV448AGE Gas Dryer Logo
255 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
