Question about Poulan Garden
I bought my husband a poulin chian saw but he can get it stated but the chain won't move
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 28 Answers
Buy your husband a Stihl chainsaw. He'll be better off.
Posted on Feb 22, 2014
    President:
  • 2,220 Answers
Did you ensure the chain brake is disengaged? Grasp the forward most upper handle (hand guard) and move it toward the nose of the bar (forward). Did it click? If no the brake is engaged. Move it slowly aft (it may require some force at the rear extreme to latch) until it clicks. Wear gloves and try to rotate the chain. If it latched and you still cannot rotate the chain please post back (below), and we will explore further.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 04, 2010
  • dontbother10
    dontbother10 May 05, 2010
    Char NEVER touch the chain on any saw with the engine running or connected to an electric outlet!!!
Compatable parts for a 3750 poulin chain saw
Poulan 3100 Chainsaw Parts Ignition Coil Module 530039128 https://www.ebay.com/p/Poulan-3100-Chainsaw-Parts-Ignition-Coil-Module-530039128/1001674726
Apr 10, 2018 | Garden
Chian on saw heating up and no cuting wood properly
Andy it sounds silly but you need to put oil in the saw for it to cut properly and to stop it heating up. It sounds like the chain is also now blunt . Also check that the chain is on the right way and going with the teeth facing forward. If the chain is blunt you will need a new one.
Nov 02, 2013 | Makita Garden
My saw simply will not pump chain oil. Iv'e run it with the bar and chain off and the pump works.Put it back together and nothing. Before reinstalling the bar I blew the saw clean. I had a Sears Poulin a...
Check that the bar oil ports are clean; there should be a small hole or slot on each side of the bar and these can become pluged with sawdust. Also clean the groove in the bar with a small screwdriver or bar cleaning tool every 8 hrs of operation.
If this does not fix the problem check the oil sump screen in the oil tank(usually on the end of a rubber hose); if no screen in tank: remove oil pump and clean(screen is sometimes in oil pump assembly).
Oct 06, 2010 | Poulan Pro Chain Saw 46cc 20"
Installing recoil spring for Poulin P3314
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool. HTH
Lou
Oct 17, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
I need a drive sprocket for the chain on my poulin es350 chain saw
I checked Poulans website and they dont show a breakdown for this tool, but you can call 1-800-554-6723 and request assistance
Mar 02, 2009 | Poulan ES350 16" Chain Saw
My poulin chain saw wont run
Can you get it to run at all? if not pull it a few times and check if the plug is wet. Let me know
Feb 23, 2009 | Poulan Garden
Garden Logo
62 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
