Question about Xante CL30 HSE Laser Printer
Xante Cl30 laser printer error
Do you know what fatal error 125 means?
  • bogor May 23, 2008
    I get the following error message sram missing e
    I have tried change memory but not that
    Have about a year and half, light use
No, but just been told its a P/U issue and going to cost about 300 .replbq{width:100%} var LetterVals = { UIStrings : { __last : 'not used' }, StateDynamic : true, yplus_browser : true, premium_user : true, smsintl : "", SidebarSyncActionType : "read", SidebarSyncAuxActionType : "", SidebarSyncUID : "57", SidebarSyncAuxUID : "", getString : function(id) { var result = this.UIStrings[id]; if ( result == null ) { return "Not translated: '" + id + "'"; } return result; } }
Posted on May 28, 2008
    Problem Solver:
  • 6 Answers
Error 125 is indicating an error detected at MT home position, which means the transfer belt may not be returning to the proper start position. The normal solution to this, if it persists after a restart, is to replace the transfer belt.
What is a Fatal Error: 140 on a Xante HSE?
That error is image yellow drum up/down senser. Shut down your printer and reseat the drum make sure it is loose and not tight when placing it into the unit.
Oct 02, 2014 | Xante CL30 HSE Laser Printer
Fatal error 20
this is a memory issue. remove the memories an dopen the printer if it open ok, close it and try putting one memoery at the time.
Dec 07, 2013 | Xante CL30 HSE Laser Printer
Fatal error 142 xante Cl30
it's a problem with cyan ID. clean the cyan drurum's contact and the cointacts inside the printer where cyan drum ''sits''. if not try with a used drum.
Aug 22, 2012 | Xante CL30 HSE Laser Printer
Xante cl30 printer drivers for windows7 32bit & 64bit
go to www.xante.com -->support -->drivers & docs -->legacy products -->cl30
Aug 20, 2012 | Xante CL30 HSE Laser Printer
Fatal error 153
check with a different black drum
Jan 17, 2012 | Xante CL30 HSE Laser Printer
Fatal error 133 xante cl 21. Course for this
yellow led head. swap yellow with cyan and see if the error changes
Feb 14, 2011 | Xante CL30 HSE Laser Printer
177 Fatal Error
Error 177: Thermistor indicates Low Temperature (COLD) Error.
Usualy the fuser has overheated first (error 172/176) and tripped the thermal protection causing the fuser not to heat up anymore.
Normal procedure if a restart doesn't fix it is to replace the fuser unit.
Dec 29, 2010 | Xante CL30 HSE Laser Printer
What does error code 032 fatal error mean and how can I fix it
Here's the link to your 500 page Manual. I used the search function at the top of the Abobe Doc which it is formatted as and typed in your error.
It won't call up anything about 032 but Fatal Error recommends only "Call For Service".
Not very helpful is it?
Oh well, please don't thrash my rating with 2 blue thumbs or less. I tried. :(
Regards,
MArcus
Sep 16, 2010 | Xante CL30 HSE Laser Printer
Xante CL30 Fatal Error 177
I think that's a buffer overflow error, but if you get that error no matter what you print I would check to make sure your memory isn't bad.
Feb 13, 2009 | Xante CL30 HSE Laser Printer
Xante CL30 Fatal Error 127 Code
When to many consumable is low at the same time.
Oct 08, 2008 | Xante CL30 HSE Laser Printer
Xante CL30 HSE Laser Printer Logo
493 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Igor Studennikoff
Igor Studennikoff
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
