Question about Tascam 2488mkii 24 Track Recording Workstation
How can i assign diferent effects to indivdual tracks?
  • 3 Answers
It's tough. For all that TASCAM touts this is not a user friendly system. I find that assigning compression to one track, removes my reverb from every track. It seems only one effect can be used at a time, and that effect effects them all. Tascam sucks. Never again!
Posted on Aug 17, 2010
Difference between multi effects guitar pedal and pedal board?
Assuming I understand you correctly, both setups have their advantages. Multi-effects pedals generally are cheaper than arranging a number of individual pedals, and they'll only need one power supply. However, you'll them be stuck with that one brands version of the fx, and in most cases, the order the effects are in the device. If you do your own pedalboard, you can have various companies fx and line them up as you like. You can buy expensive ones and inexpensive ones and then change them out as your budget and needs change.
May 31, 2016 | Road Ready 17" Lightweight Guitar Effects...
Where can i get a replacement assign knob for a djx700
Behringer fired their USA distributed a few weeks ago. You'll have to call Behringer directly and request the part. Or email.goto th website
Nov 04, 2011 | Behringer DJx700 5-Channel Pro DJ Mixer...
Pmp4000 unit. can i designate different effects to different channels at the same time?
only 2 effects can be used at a time. you assign the effects in your lil digital section in the master part of the board by turning the black knobs so the lit up numbers change to the effect you want then push the black button to lock it in. at which 2 of your aux's ( the last 2 i think its 5 and 6 ) control the SEND to your EFFECTS and the fader below the selections control the amount of effects goes into the MIX.
Aug 31, 2011 | Behringer PMP4000/B1520 PRO Mains &...
When i play the keyboard and record it. it does not playback what i just performed when i record drums it plays back fine only the keyboard. im using the mpk49
I'm not familiar with Reason 5, but many midi track recorders need each instrument assigned to different midi chanels to be heard back. Check the manual in how to assign the midi tracks. Also, the playback has to be through a unit that is multi timbrel capable. Good luck!
Aug 17, 2011 | Propellerhead Reason 5
I am trying to record in multi track mode-want to know how to record for example vocals on track one then without erasing the vocals add for example harmony or guitar so i get two things on one track. At...
How multitrack recording works is assigning each recording to a different track. A way around this is to record the vocals to track one, then your harmony to track two. Save that as a single recording, or mixdown, then open that saved mixdown to track one. You may need to be connected to a computer to do this.
I use the same technique when using Cool Edit Pro (outdated, yes, but I've been using it for 4 years, and I know most of the ins and outs), especially on the guitar tracks, where for studio sound, you've gotta use 4 total tracks. Putting two tracks together frees up your processor, and uses less in the way of effects, as well.
Hope that helps!
Feb 07, 2011 | Samson Technology Zoom H4n Handy Recorder
I have a MIDI problem with the Obey 40 - basically it's very erratic in accepting midi instructions. I have about a dozen banks of scenes created and one chase and I'm trying to set up my MIDI files to...
I am assuming that you are imbedding the changes in the midi sound files themselves. They will need to be on a separate track with the correct midi channel assigned at the beginning of the track.
Dec 09, 2010 | Chauvet Obey3 3 Channel Dmx-512 Controller...
How do i set the control for the crossfader on the djx700
u should b able to use it so long as you change the mode from stereo to split, then you can just use the panel at the bottom that says "crossfader:" :P
Feb 11, 2010 | Behringer DJx700 5-Channel Pro DJ Mixer...
How to use an external effects processor on the tascam neo
Manual here:http://www.fullcompass.com/common/files/10255-Tascam%202488-neo%20manual.pdf If you look at the back you will see two effects sends. Apparently from the manual you can use the line inputs for returns. This is where it might become confusing. Each line in is also a TRS jack. That means that using a common guitar or unbalanced cable will make the jack act as an input. If you use a shielded !/4" stereo cable( stereo jacks on each end) then the jacks can send a signal and receive a signal. If your effects unit has one of these jacks also you just need the proper cable. If not you use a cable with ends that match your unit and the Tascam. There are several combinations of effects assignment available and you should consult the manual carefully. I would recommend joining a support or users forum for this unit. Try this one:http://www.sweetwater.com/forums/showthread.php?t=25978 or this one:http://homerecording.com/bbs/showthread.php?t=276889 The last one is a site worth joining and I highly recommend it.
Feb 04, 2010 | Tascam 2488mkii 24 Track Recording...
Can't get Casio CTK 601 / 611 to function as MIDI Contrller
I'm not at home right now where all my manuals are so I'll try to explain with out. You will have to set it so that the keyboard is the slave device. Try setting it to Omni receive. It has to be able to listen for all midi channels at once. You have to write a sequence on your computer and hook it to your keyboard by using midi out on the computer to midi in on the keyboard in order for you to use the computer as a controller. If you need the keyboard to create the sequences then you have to hook the midi send on the keyboard to the midi in on the computer play/enter your notes into individual tracks in your software then assign channels, voices etc to each track and save the sequence. Then when you hook it up the other way the sequence will play just like an audio recording except the sound w2on't be there. What you have recorded by creating a sequence is a series of midi messages that the keyboard will receive if you have it set properly and hooked up ptroperly which it will translate into sound. This is a minimalist explanation at best. You will have to have a better understanding of not only your keyboard but also your software and midi in general. There are some pretty amazing things you can do with midi. For instance if you have a lighting controller that is midi capable you can i,mbed all the lighting scene changes for your song in order on one track. You can also control your guitar effects pedal to change effects automatically while your playing. Once you get a handle on it you are only limited by your imagination and your budget. Hope this helps in some way.
Jun 01, 2009 | Music
Problems setting midi channels using KN3000 and Cubase
If you are sequencing midi tracks you can imbed the patch change in the track and the midi channel assignment and when the sequence plays the info will be sent to the keyboard. Do you have it set to receive Omni?
Apr 23, 2009 | Music
Tascam 2488mkii 24 Track Recording Workstation Logo
77 people viewed this question
Top Tascam Music Experts
Computer Links
drivealot
Norma Garcia
Norma Garcia
Are you a Tascam Music Expert? Answer questions, earn points and help others
