Question about Kenmore 24902 Top Load Washer
Leaking water from botom - Kenmore 24902 Top Load Washer
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the section for the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
I'd also check the gaskets at the bottom of the tub.
If you're reasonably mechanically inclined, these are easy fixes.
If you have to get to the gaskets at the bottom of the tub, see the following for how to remove the agitators, pump, motor, transmission, spin tube and basket.
(It sounds a bit complicated but it's not really that difficult.)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
You don't have to buy a special spanner wrench to remove the spanner nut. I've used a short 10" pipe wrench hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Depending on the problem (hoses or gasket) it's certainly less expensive than calling in a repair person.
Posted on May 04, 2010
Water sometimes leaks out the side of the door
Give the seals a good clean all around the door sometimes these will clog and cause a leak through the door, mainly the seals at the botom of the door on the inside.
Hope this helps
Mar 19, 2010 | Whirlpool DU912 Dishwasher
Finding a puddle of water each morning under the left front of frig--does not leak during the day?
YOUR DRAIN IS CLOGED.LOOK AT THE BOTOM BACK PORTION OF YOUR FREEZER. (INSIDE) WHEN YOUR FREEZER GOES INTO DEFROST THE WATER HAS TO GO SOMEWHERE. IF THE DRAIN IS CLOGGED IT WILL FLOW OUT THE FREEZER DOOR.
Mar 16, 2010 | Refrigerators
Water dripping from front left side of dishwasher
feel the botom of the door is it leaking from a plastic tube on the left between the door shell,if ti is you need a vent ***. good luck!
ERIC
Jan 26, 2010 | LG Dishwashers
Leaking water out of botom of machine
Time for a water pump. Look up washing machine repair on youtube.
Nov 02, 2009 | Kenmore 24032\24036 Top Load Washer
Leaking water from bottom
Hi there......leaks can come from many sources......leakage from the botom could be due to torn door seal...leaking drain pump...leaking soap dispenser to tub hose...or simply a hole in the outer tub
regards Sir Galahad
Aug 21, 2009 | Washing Machines
Got water leak worse when running in front
I would assume that it would be your water pump. Check to see if the fluid is comming off of the water pump in the front of your motor, you should be abe to see a drip on the botom of the pully.
Feb 18, 2009 | 1999 GMC Yukon
Bissell spotbot: leaking the dirty water from bottom. I took the bottom plate off and there is a really crappy rubber seal. I think it is leaking from there.
I had the same issue. After some research, I determined I was missing a black "duckbill" gasket on the bottom of the dirty water collection tank.
This caused reduced suction, and for the water to pool at the botom of the spotbot, thus leaking.
I purchased the gasket at Bissell for 1.39. The part number is 203-6646.
I purchased my SpotBot new from Target, and never remember seeing this black gasket, but the difference is night and day.
Sep 07, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
Washer leaking some after everything is done washing? why ?
The most common source of leaks from the bottom on a regular basis is a bad pump. Add a little water into the unit. Pull it forward and tilt it back about 45 degrees resting the top against the wall. On the botom center towards the front, you should see a white plastic looking thing. This is the pump and usually where the water leaks from. You can get a replacement on from the manufactures web site or from local appliance parts stores.
May 31, 2008 | Whirlpool GSC9455 Top Load Washer
Kenmore 24902 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
